Question about Actron Digital Multimeter Tester
Im looking for trouble codes on a 1997 Ford Ranger 1443 came out severity unknown on the obd 2 scanner looking for the actron code book or something can u help ?
  • 553 Answers
P1443 - Evaporative Emission Control System - Vacuum System - Purge Control Solenoid or Purge Control Valve fault
This site has a free list of trouble codes:
http://www.obd-codes.com/trouble_codes/ford/
Posted on May 30, 2010
Ive got a 93 ford ranger.after it gets warm & u cut it off for about 5 mins,& start it back its like it floods
Ford Check Engine light Codes - FreeAutoMechanic
www.freeautomechanic.com/diagnostictroblecodes7.html
Full list of OBD I Diagnostic Trouble Codes for your Ford Vehicle. If your Check engine light is on you may have a serious problem. Scan your codes and follow ...
EEC-IV 2 and 3 digit trouble codes. - Ford Explorer and Ranger ...
www.explorerforum.com > ... > EEC IV
Feb 6, 2007 - Serious Explorations Ford Explorer and Ranger Message Board .... 3.8L AXOD - Message center data link circuit fault - See code 70 73 (O) Is FORD DEALER the only place who can read out ABS error ...
Dec 5, 2011
Error codes 186 & 539.
Aug 15, 2009
OBD-II Diagnostic Trouble Codes (DTCs)
Nov 8, 2008
Have a Code? OBD II Trouble Codes Here
Jan 19, 2006
More results from www.explorerforum.com
EEC-IV Diagnostic Trouble Codes - Diagnose problems in
Dec 19, 2015 | 1988 Ford Ranger
What does Obd 2 code 1443 mean on a 1996 ford ranger with a 4.0 ?
Read http://www.tomshints.com/FordRanger/FR_EPS.htm
Jun 22, 2015 | Ford Cars & Trucks
How much does it cost to purchase a OBD2 scanner tool ? my car seems something wrong.i want to fix it. my car is peugeot 307
An obd reader can run you as little as fifty bucks to several hundred I picked up an actron obd 2 from autozone fifty bucks ready to use and has a cd you can download on your computer. It has an erase code setting as well not bad for fifty bucks.
Mar 13, 2012 | Cars & Trucks
Where do you plug in a actron obd scanner ?
The connector is located on the drivers side just above the parking brake pedal.
Hope this helps.
Zeppelinx12
Mar 05, 2011 | 1994 Ford Explorer Limited
I have p1 auto codes p1506,p1443,p1744
the 1443 code is very common i just fixed it on my ranger. The canistger purge valve is defective, I found one at napa for about $46. It is located by the battery. After about 1/2 a day of driving or 4-5 starts that code will go away.
May 18, 2010 | 1997 Ford Ranger SuperCab
HOW DO YOU CLEAR THE YELLOW ENGINE LIGHT ON THE DASH
well first you must repair the problem that caused it to come on, u will have a trouble code stored, once the repair is completed the light will need to be cleared/turned off with a OBD 2 scanner.
Sep 29, 2009 | 2004 Dodge Stratus
Ford code 1443 problem
look for vacuum leaks in the system going from the purge valve all the way back to the fuel tank.
Jun 28, 2009 | 1997 Ford Ranger SuperCab
Check engine light 97 ford explorer. obd-II po141 bank 1 sensor 2. need to locate sensor
Looked up your OBD II code for your Explorer and got the following: Bank 1 Sensor 1
The possible causes are listed below per Chilton: *same result for all engines available on your vehicle
Trouble Code: P0141 (4.0L V6 VIN E Auto)
HO2S-11 Heater Circuit (Bank 1, Sensor 1) Print this code dataprint_icon_codes.gif
Number of Trips to Set Code: 2
OBD II Monitor Type: CCM Details
Indicators: MIL Details
Trouble Code Conditions:
During testing the heated oxygen sensor (HO2S) heaters are checked for open and short circuits and excessive current draw. The test fails when the current draw exceeds a calibrated limit or an open or short circuit is detected.
Possible Causes:
  • Vacuum hose disconnected on exhaust gas recirculation (EGR) system module (ESM) applications* Short to VPWR in the harness or HO2S
  • Water in the harness connector
  • Open VPWR circuit
  • Open GND circuit
  • Low battery voltage
  • Corrosion or incorrec
The sensors themselves appear in the illustration linked to below. The illustration is for the Ford Ranger but indications are that other models have similar locations. Hope this helps with your problem. Best of luck!
Greg
http://www.chiltonlibrary.com/content/images/8968/images/89684g23.pdf
May 17, 2009 | 1997 Ford Explorer AWD
Actron Digital Multimeter Tester Logo
417 people viewed this question
Top Actron Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Bill Boyd
Are you an Actron Measuring Tool and Sensor Expert? Answer questions, earn points and help others
