Question about Saeco Royal Professional Espresso Machine
When you have pressed pregrind, then med coffee button, hardly any coffee/water comes out of nozzle. sometimes takes 3 tries to get 1 coffee! (But I can hear water running in machine)
    President:
  • 1,618 Answers
The coffee grind that you are using is too fine.
Posted on May 31, 2010
I lost their measuring cup is it the same as a one cup measuring cup?
Here are the amounts - in teaspoons of water:
Soft Boiled Eggs
4 tsp 6 soft
5 tsp 5 soft
6 tsp 3 soft
7 tsp 1 soft
Medium Boiled Eggs
7 tsp 7 med
8 tsp 6 med
9 tsp 5 med
10 tsp 3 med
11 tsp 2 med
12 tsp 1 med
Hard Boiled Eggs
14 tsp 7 hard
15 tsp 6 hard
17 tsp 5 hard
18 tsp 4 hard
20 tsp 3 hard
21 tsp 2 hard
23 tsp 1 hard
Sep 18, 2014 | Egg Genie Electric Egg Cooker
Instruction manual is in french ,need it in english
Egg Genie cooks up to 7 eggs at once-with no guesswork, no underdone or overdone eggs.
Just add the indicated amount of water.
Press "on"and your work is done.
The Egg Genie automatically steams eggs and alerts you when they're ready.
Here are the amounts in teaspoons of water:
4 tsp = 6 soft boiled eggs
5 tsp = 5 soft boiled eggs
6 tsp = 3 soft boiled eggs
7 tsp = 1 soft or 7 med
8 tsp = 6 med boiled eggs
9 tsp = 5 med boiled eggs
10 tsp = 3 med boiled eggs
11 tsp = 2 med boiled eggs
12 tsp = 1 med boiled egg
14 tsp = 7 hard boiled eggs
15 tsp = 6 hard boiled eggs
17 tsp = 5 hard boiled eggs
18 tsp = 4 hard boiled eggs
20 tsp = 3 hard boiled eggs
21 tsp = 2 hard boiled eggs
23 tsp = 1 hard boiled egg
May 22, 2011 | Emson EggGenie Egg Genie Electric Egg...
Water not coming out of dispensing area, goes to drip tray instead Water comming out in drip tray instead of regular way
Try this, if the machine has a pregrind door(usually on the top front) then use the button to tell it you are using pre grind coffee, if water comes out the spout this way then the grind on the grinder is too fine, if it goes out the drain then the coffee passage is blocked, remove the brew unit and check/clear tubes, also clean the spouts on the door of the unit.
May 30, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
Spidem trevi digital plus coffee machine not working as it should
it sounds like you need to go into the programing mode. in there you can set the machine so it grinds when you select coffee. at the moment it is pregrinding this is so you can make lots of coffees 1 after the other
Jan 27, 2009 | Spidem Trevi Digital Coffee Maker,...
Please help
The Magic Comfort Plus machine has a selection for the temp through the menu for the three sizes of coffees buttons. Using the menu button, scroll through until you come to temp section, then select the coffee size button and and change the temp, example-- Select maximum. Press the menu button to set it.
If that does not help, when a machine gets full of calcium (needs descaling) that also will lower the temp. You might have to descale it three-four times.
And remember, when you descale, run the solution through the steam/hot water wand and also the espresso/coffee dispensing nozzle. Only doing it through the steam wand (like the manual says) will only do 1/2 of the machines water sections!!! I usually run 1 cup of solution through the steam wand and 3-4 cups through the espresso dispenser.
Dec 23, 2008 | Saeco Magic Comfort Plus Espresso Machine
Leaks at the hot water spout during coffee brew
I had the same problem. I ended up taking the coffee machine apart and found that the reason coffee trickles out around the hot water spout is that the two coffee nozzles were partially plugged. Since I Had parts of the coffee machine apart I was able to clean it easily. It may also be possible to clean the assembly using a pick of some sort and clean out the holes of the two normal coffee spouts. Inside it is just a open cavity so gentle poking around and using some steaming hot water may do the trick.
If you want to take the machine apart you need to do the following: 1) take of the warmer plate on the top - 2 storz screws but an allen key works as well 2) take off the top plate of the machine - another 4 or 5 screws - make sure you empty the beans first otherwise you will have a mess 3) remove one screw from the right hand side of the removable coffee ground tray. Once this screw is removed the front panel is free to swing open except for the pipes connecting the front 4) unclip the steam assembly - there are a couple of plastic catches on the top. this will free the steam assembly from the front panel and also free a pipe connections. The steam dispenser pipe will also come free from the steam assembly. 5) remove the coffee pipes from the up and down sliding coffee dispenser. This is a small whitish color clip with 2 pipes connecting into it. The white clip has a little plastic catch on the top that frees it. The front panel should now swing open freely. 6) remove the sliding coffee dispenser from the front door. There are 4 plastic catches, 2 on either side. the whole front sliding coffee displenser now comes free 7) Take the sliding dispenser apart by release the 4 plastic catches on the front curved planel. 8) Inside the sliding dispenser is a white plastic piece that connected to the piping released in step 5. There is a small plastic catch that needs to be pressed while pulling fairly hard on the plastic piece and bending the whole piece. 9) You will now see the plugged spouts. It goes back together really easily.
Aug 13, 2008 | Jura Capresso Impressa S8 Coffee Maker,...
Royal Professional machine
try to set the grinder to grind little more coarse, you have to make 2-3 cup to get the new settings to work.
To get off the ventilate you have to press the button for hot water and make a cup of water.
Hope this will help you.
/Mirran
Aug 11, 2008 | Saeco Royal Professional Espresso Machine
I have a Krup Orchestro Dialog Autocapuccino fully automatic espresso machine. When I try to use the machine, it warms up properly, rinces correctly, grinds the coffee, makes the usual noises, few drops...
Initially, have you tried a full hard reset? If not, pls unplug from the mains. Most current devices would reset and revert back to factory default settings (assuming no internal hardware fault) when unplugged for a considerable period of time (from a few minutes to a couple of hours). Of course doing a hard reset erases all glitches.
Pls post back for any development(s) or even the lack of it.
Hope this be of initial help/idea. Good luck and kind regards.
Thank you for using FixYa.
May 21, 2008 | Krups Orchestro Dialog FNF2 Espresso...
Descaling
Remove the filter holder (portafilter).
The manual says to unscrew the nozzle from the filter holder coupling and wash with hot water.
Mix a liquid decalcifier with water in tank at a 1:1 ratio. DO NOT USE VINEGAR! It says to fill the water reservoir.
Run the cleaniing solution through the machine - pressing the coffee button, 1 cup at a time. During each interval let the decalcifier act for 10 or 15 minutes by turning off the machine by the main switch.
Carefully wash the tank and fill with fresh water and empty 2/3 of this by pressing the coffee button.
Now let the machine warm up and empty the rest of the reservoir by rotating the hot water/steam knob.
Screw the nozzle in the filter holder coupling again.
Jan 06, 2008 | Saeco Magic De Luxe Espresso Machine
No coffee is coming out of the machine...
I suggest to throw the machine where it belongs : the rubbish bin. In fact, it IS making coffe, but the lower seal is not working properly and your coffee runs into the lower tray. You should change the seal, or do the first thing (like I did), and buy a Saeco.
Feb 18, 2007 | Krups Orchestro Dialog FNF2 Espresso...
Saeco Royal Professional Espresso Machine Logo
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
