Question about Fisher and Paykel 23 in. DD-603 Built-in Dishwasher
Fisher and paykel dd603
F 1 problem
where is the flood switch located
  • 159 Answers
Flood switch is at the very bottom underneath the bottom draw in the base floor.Unplug cord.Open bottom draw all the way & squeeze a towel or sponge under the draw & soak up the water..The washer should work now..Why did it flood in first place?
Check that dishes are not stacked higher than top edge of the draw otherwise it can't seal.this can happen when children are asked to stack the dishwasher.Another cause is some models the seal is an inflatable tube that seals the top edge of the draws,it gets cut or sliced buy a plate that was stacked to high when you closed the draw.there should be no clunk of dished hitting when the draw is closed.
Posted on May 30, 2010
2 Suggested Answers
  • 125 Answers
SOURCE: Fisher& Paykel
Its under the bottom drawer dry out and re-assemble
Posted on Jan 12, 2008
Flood switch 920 model
Not sure what the actual model number is but usually the F1 error with Fisher and Paykel dishwasher means water has entered the flood switch located at the base. This could be due to leaky hoses or water leaking through the door or lid seal. Wait for a day or two until the water evaporates and try again. Otherwise you will have to dry out the flood switch and then try again. Location of flood switch will depend on your model. For double drawer dishwasher you will have to take the bottom drawer out from the housing and the switch is on the floor of housing. But make sure you take the mains power chord out before touching the insides of dishwasher. Will also need to find the cause of the leak. Other reason for F1 could be loss of power to top dishdrawer if you have double drawer. But in that case the top drawer will have no lights on. The power board is located on the base of housing under bottom drawer. Once again do not touch inside of dishwasher without shutting off mains power.
Jan 27, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
How to reset the flood switch on a fisher & paykel
Hi - unfortunately my good friend it cannot be reset as one would like quite easily anyhow... water has found its way to the base of the drwaers and have activated the flooding switch - one could pull it apart to dry it - tip the water out from the base but if the leaks not repaired you will have the same problem later and will be on-going.
5 Fault Codes
Fault Code LED Display Fault Possible Causes
F1 ----#
The flood switch has been activated.
A leak has occurred in the base of the dishwasher.
Cause
 The fill valve has failed open.
 The flood switch is faulty.
 Excessive water has been added to a wash sub cycle, indicating leaking seal or siphoning.
hope this is useful tp you - let me know if you require further asspstance...
Jul 16, 2011 | Fisher and Paykel DS602 Dishwasher
The dishwasher will start for two sec and then they both stop and a red light comes on and starts beeping with motors running.
This indicates the flood switch has been tripped. The video in the link below explains how to access and repair single and double drawer fisher and paykel dishwashers. Its a really good Fisher Paykel dishwasher repair video it really helped me.
Fisher Paykel Dishwasher Repair Video Link
Mar 09, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
Flood switch activated, intermittent beeping, motor will not turn off
Please confirm if it is a single or a double drawer.
How do you know the flood switch is activated? Do you have a display on your dishwasher and what is it showing? If no display then which lights if any on the panel are on?
Motor will not run if flood switch is activated in the fisher paykel drawer dishwwasher.
Nov 20, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
The flood switch has been activated on our Fisher & Paykel 2-drawer dishwasher. How do we reset the button?
Turn off the main power to the dishwasher.
I am assuming you are getting F1 error code flashing (if your drawers have LCD display) or the LEDs are flashing if you have intergrated drawers.
The flood switch is located at the base of the drawer tub. You will have to either extend the drawers out fully or take them out depending on the amount of water that would have collected at the base of the tubs. Get some towels and dry the base out. You may also need a hair dryer.
Once the flood switch dries off the drawer should work ok when you turn back the power.
The causes of the flood switch trriggering is either too much foam in detergent (use recommended detergent) or leak in water in or drain pipe.
Please remember to rate the solution if it helps or post a comment if not.
Jun 12, 2010 | Fisher and Paykel Dishwashers
Have Fisher and paykel Nautilus dishwasher showing F1 fault - what does this mean? Dishwasher was leaking water all over the floor dont think major problem as it starting draining when power was reset
f1 means u have a leak where pump and control module is. that is located under sump.the water has activated a flood switch near drain pump. need to find leak to fix problem. make sure power is off to unit b4 looking.please reply to how u go. good luck
Mar 16, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Hi Both drawers show error F1 flashing beeping with rinse light on and both pumps run after power is applied to machine
F1 error indicates flood switch in base has activated, meaning machine has leaked. This causes machine to drain continously, and can only be stopped by switching off power. Not easy to fix if you don't have experience- bottom drawer has to be removed to access flood switch, then machine needs to be test run and checked for leaks. Best to call the professionals!!
Oct 03, 2009 | Fisher and Paykel 23 in. DD603H SS...
Fisher paykel gwl15 overfills and will not advance
Is it filling so it is flooding your floor? Could be that too many suds are in the pressure switch tube ( are you using "he" soap? ) or the pressure switch is not registering the water level. Note the lights illuminated when it beeps and call F/P.
Jul 03, 2009 | Fisher Paykel EcoSmart GWL15
I have a fisher paykel soft touch dishwasher about 10 years old. The F1 message came on and we have taken out the inside filters and cleaned enitirely., Was working fine until it came on by itself during...
The flood sensor is located below the bottom drawer. If you take the bottom drawer out and there is water in the pan then the flood switch is probably tripped. Soak up the water with a towel and apply a hair dryer towards the rear left corner of the cabinet. The flood switch is part of the Mains Filter control board and should not be messed with (even with the dishwasher unplugged)... There is an underlying problem that caused the F1 fault and you should have a technician look at it.
Jun 17, 2009 | Fisher and Paykel 24 in. DS603H I Built-In...
Fisher-Paykel DD603 DishDrawer shows F1 fault code. The Flood Switch has been activated. I need instructions on how to re-set the flood switch. I have two drawers that are possitioned one above the...
Fisher-Paykel DD603 DishDrawer shows F1 fault code. The Flood Switch has been activated. I need instructions on how to re-set the flood switch. I have two drawers that are possitioned one above the other and the are both giving the error of the activated flood switch. Any advice or instruction is greatly appreciated.
Jul 22, 2008 | Dishwashers
Fisher and Paykel 23 in. DD-603 Built-in Dishwasher Logo
1,160 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
