My computer has power, but when turned on it will not boot to windows. I followed your trouble shooting instructions as to ""turn the computer off and remove the power cord from the computer. Hold the power button down for 30 seconds, and released the power button and plug the power cord back in to unit. Than turn the unit back on."" This does not solve the problem, Any other solutions???? Don
  • 3 more comments
  • donjin5 Apr 08, 2008
    Here's the problem:
    If the computer is left and not use for a long duration ie:(4hours)
    When attempting to turned on the computer, it would not boot into windows, the powered red and green indicator lights would light up but will not boot into windows and no beeping noises. It seems to freeze at this stage with no screen display.
    At this stage I would have to unplug the power cord from the back of the computer and replug into the system and than turn on the computer again. This always work on the second try. This problem started last fall.
  • donjin5 Apr 14, 2008
    This did not fix the problem. Any other solutions?
    Thanks for your help
  • donjin5 Apr 22, 2008
    Hey fix ya group
    It took several days of manually turning the power button off and on as the computer was used. It must have been in a deep coma, but finally woke up and is operating normal.
    Thanks again for the help and Happy Earth Day
  • trangvu5 Feb 17, 2009
    When attempting to turn on the computer. Its boot into window and it seem to freeze at this stage with desktop background display without any desktop icons.
  • Georgia B
    Georgia B May 11, 2010
    Do you get anything? Beeps? Post boot screen?
My hp compact d530 cmt will not turn on. it just blinks green once then red four times. help ?
Posted on Oct 29, 2008
  • 1,342 Answers
Your PC may also be going into hibernation. Press the power button to wake it up.
Posted on Apr 09, 2008
  • Georgia B
    Georgia B Apr 22, 2008
    Congrats Don.
    Thanks for voting.
How to stop Windows 10 from automatically restarting after idle for around 5-15 minutes.
The kernel power event ID 41 error occurs when the computer is shut down, or it restarts unexpectedly. When a computer that is running Windows starts, a check is performed to determine whether the computer was shut down cleanly. If the computer was not shut down cleanly, a Kernel Power Event 41 message is generated.
Before we proceed with the troubleshooting steps, please answer the questions given below.
a)Do you remember making any changes prior to this issue?
b)Did you check if all the drivers are up to date?
Let us follow the methods given below.
Method 1: Run System maintenance troubleshooter.
Follow these steps:
a) Press Windows key + W on the keyboard
b) Type Troubleshooter then click on Settings under the Search field
c) In Settings click on Find and Fix Problems
d) Click on System and security
e) Click System maintenance follow the prompts from there.
Method 2: Try booting the computer in safe mode and perform a clean boot.
Step 1: Perform Safe Mode
Click the link and follow the steps "Windows Startup Settings (including safe mode)"
Check if you face the same issue in safe mode. If the issue doesn't persists in safe mode, the place the computer in clean boot and check.
Step 2: Perform Clean Boot.
To help troubleshoot error messages and other issues, you can start Windows 8 by using a minimal set of drivers and startup programs. This kind of startup is known as a "clean boot." A clean boot helps eliminate software conflicts.
Important: Reset the computer to start as usual.
Note: After you have finished troubleshooting, follow these steps to boot to normal startup.
a) Press the 'Windows + R' key on the keyboard.
b) In the 'Run' windows type 'MSCONFIG' and click 'Ok'.
c) On the 'General' tab, click the 'Normal Startup' option, and then click 'OK'.
d) When you are prompted to restart the computer, click 'Restart'.
If the issue persists, I would suggest you to perform a system restore and check if it helps.
Method 3: Perform a system restore.
Refer to the link given below and follow the instructions for system restore.
How to restore, refresh, or reset your PC
Also refer to the article given below.
Windows Kernel event ID 41 error "The system has rebooted without cleanly shutting down first" in Windows 8, Windows Server 2012, Windows 7, or Windows Server 2008 R2
hope this helps
Jan 13, 2016 | Computers & Internet
Error code 0x800B010E wont connect wireless to internet, trouble shoot wont work. path c:\windows\diagnostics\system\networking. content restricted. please help......
I am assuming you are running Vista or Windows 7. According to Microsoft this error is an issue with .NET framework. They suggest you turn off .Net, restart your computer, then turn .NET back on. Here are the instructions they give you.
Error code 0x80131700 is usually relevant to the old version of .NETFramework installed on your system. By default, the built-in version ofMicorosoft .NET Framework is 3.5.1. You can reinstall Microsoft .NETFramework 3.5 Service Pack 1 through the following steps:
Step 1:
a) Click the Start and type: "features" in the Search box.
b) Select "Turn Windows Features on or off " and click Enter.
c) Find Microsoft .NET Framework 3.5.1 and uncheck the box.
d) Restart the computer.
e) Repeat the step 1) to step 2.
f) Check the box before Microsoft .NET Framework 3.5.1.
g) Restart the computer.
Step 2:
If the issue persists, then I suggest you to perform the process by booting the computer in Clean Boot and check.
Note: Follow the step 7 to restart your computer as usual.
Jul 02, 2011 | D-Link Computers & Internet
Please oh please help me. Acer laptop aspire 5920 Windows vista Home premium OEMAct First it shut down and this message came on: Broad com UNDI PXE-2. 1 v9.4.5 Then I shut it down and turn it on pressed...
Your computer tries to "boot" from several sources:
* your disk-drive
* your CD-ROM drive
* any USB device
* from a "boot-server" computer connected to your computer via an Ethernet cable
So, you computer tried to boot from the Broadcom Ethernet adapter, trying to "talk" to that "network boot server", via PXE ("Pre eXecution Environment").
What this probably means is that the computer failed to boot from the disk-drive, and so it tried the "alternate" boot-devices. If the disk-drive is disconnected (no power and/or no data cable) or if the disk-drive is "dead", then Windows cannot be loaded from it.
Take your computer to a qualified technician for professional trouble-shooting.
Apr 03, 2011 | Acer Computers & Internet
The Acer freezes all the time right when I turn it on. I can't get further than the message: Windows is starting now. Tried trouble shooting over the phone with an acer technician. I need to send it...
Before you send the computer for repair, please follow the below steps:
It may happen due to hardware failure, BIOS mismatch or due to static charge. Let us try the basic troubleshooting. Turn Off the Computer, remove all the devices attached to the computer, the power cable and battrey, now holdon the power button for 15 secs (make sure adpater and battery are uplugged) it will drain out all the static charge. Now, restart the computer and keep on tapping F2, you will enter to BIOS setup utility, press F9 (click "Yes", if you are prompted) and then press F10 (Click "Yes", if you are prompted), it will restart the computer. If still it is not booting to normal mode, then we have to perform a full system recovery & it is a distructive process as you will loose all the datas on the computer. To do so, Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
Jun 28, 2010 | Acer Aspire One PC Notebook
I want to undo a windows 7 upgrade and revert it to vista
If you have a recovery disk for windows Vista you can downgrade.
Follow this trouble shooting:
Boot from Disk
1. Insert the Recovery CD in to the ODD of the computer
2. Turn off the computer
3. Turn it back on and keep tapping F12 to access the boot menu
4. Once you're in the boot menu select ODD/CD/DVD and keep tapping enter until the file is loading
5. Just follow on the standard procedures of installation until it finished.
6. reboot the system
7. now ready to use...
Hope it helps you.. please rate it.
thank you.
May 12, 2010 | Toshiba Satellite L45-S7423 Notebook
My toshiba L500 wont boot up when i turn it on it starts to load files then stops and tries to repair the problem but it does not
There are so many reasons boot up; i.e if system files corrupted by virus or hard disk index tables corruption or hdd partions corruption.
So as a initial trouble shooting try to do following things to resolve problem.
Option 1:
1. Power ON your computer and Press F8 key to have Windows boot menu option
2. Select "Safe Mode with Command Prompt" and Press Enter
3. When command prompt loaded then type follwing command and press enter
chkdsk /r c:
(If this command is not working in "safe mode with command prompt" then start computer with Bootable CD and Press "R" key when first time asked. It will open recovery console and type this "chkdsk /r "command again to repair disk.)
This command will scan your hdd and repair disk errors.
Option 2 :
To repair your windows without losing your data.
Start Computer with bootable CD
Press R when it is asked to press.
It will repair windows.
Note : Please read Status Bar and screen messages /nstructions carfully (while Booting computer thru Bootable CD)
Mar 28, 2010 | Toshiba Satellite L505ES5015 NoteBook
New machine, following instructions, but water will not pour thro
Make sure there is water in the reservoir. Take the water reservoir out of the back and reposition it. Turn the power button on - wait for the heating light to go off - then turn the dial to the icon that looks like a coffee cup. Water should come through.
Dec 25, 2008 | Cuisinart Programmable Espresso Maker
Boot Issues
I've seen the same problem fixed it with new power supply. The old one was losing full power.
Oct 08, 2007 | EliteGroup NFORCE4-A939 (NFORCE4A93910)...
Iriver PMP-140 boot failure message
when i turn on my Iriver PMP-140 it comes up with a message reading
Boot Failure
System file has an error.
To solve the problem, connect the device to computor.
(refer to 'trouble shooting' on the manuel)
Filmware Ver. 1.24
I dont have a manual though.
May 13, 2007 | iRiver PMP-140 Digital Media Player
Computers & Internet Logo
173 people viewed this question
David Payne
David Payne
