Question about Toshiba 1GB USB 2.0 High-Speed Flash Drive 1 GB USB Portable (PA1399U1MEMFT) Drive
Usb memory stick
I am trying to transfer data from a very old computer using the Toshiba 1GB USB 2.0 flash drive and the old computer doesn't have the driver software to run it. What do I do? Can I download a driver from the net? Could you please help?
  • Anonymous Jun 10, 2008
    I have an old computer too, Win Me and I can't get my Toshiba usb 2.0 flash drive to work either although it says it works for Me on the package.
  • geometry43 Aug 04, 2008
    Exact same problem except the 4-Gig model. I am running 98SE on the old machine, a Compaq, need to transfer important files. Stick runs perfectly on the new computer, an e-machine with XP on it. But on the Compaq, it first told me it needed a driver, then said the one I downloaded was insufficient. Toshiba has a site promising the correct one [Yahoo search "Toshiba 98SE flash drive driver"], but the site does not deliver. Call Toshiba and they'll tell you 98SE is no longer supported, even though the stick is said to be 98SE compatible. Apparently no help there.
    If anyone knows how to fix this, please let me know [[email protected]].
  • 156 Answers
If the old computer is running XP.. then patch it up with service pack 2 and then transfer the files!
Most often service pack does the job.. Also the transfer is fast with the SP2 installed
Posted on Apr 12, 2008
SOURCE:
Sony memory stick is damaged n i wants to recover my data from memory card is it possible?
once USB is damage there is no way to retrieve data from it. but you can try to get all data using DOS command.
Sep 11, 2011 | Sony 1GB Memory Stick PRO Duo Memory Card
I have lost the instruction to the memory stick and have no idea how to use it. The password etc is blanked out when you plug it in
im not sure what you wat to do or are referring to if you are try to remove the password download dr freeware i have never used or had to use it it reads like it can remove passwords from any usb drives and if you are trying to use it but dont the basics
insert this drive into a usb slot
click start click on my computer you should see your usb drive or
click start all programs accessories open windows explorer navigate to your usb memory stick then go to the information you want to back up select the information right click select copy then back to memory stick select then right click select paste
or select the imformation hold the cursor on then drag it to the memory stick and drop it into it
or select the imformation right click and send to the memory stick
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free.
Data Recovery/Data Backup: Supports Logical scan and Raw scan, Supports NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660 file sytem, Supports IDE/SATA/USB Hard Drives.
Data Recovery - Recover your lost data
Available in Live CD to run offline
Recover accidentally deleted files in your hard drive
Recover data from RAW Drive(partition table or file system is damaged)
Support NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660
Support IDE/SATA/USB Hard Drives, memory cards, "
USB Memory Drives"
Drive Dumper - Backup your hard drive
Available to run on Windows
Support Windows 2K / XP / 2003 / Vista / 7 (Windows Editition)
For data rescue, backup, migration, or computer forensics etc.
Transfer important important data from damaged Drive(partition table or file system is damaged, has lots of bad data blocks)
, "USB Memory Drives"
Windows Password Cleaner
This is a utility to blank the password of any user that has a valid (local) account on your Windows system.
You do not need to know the old password to blank the password.
Support Windows NT/2k/XP/Vista
Hope this helps you
Jul 28, 2011 | Maxell 8GB USB 360 USB 308 - 503202 Hard...
The problem is with my 1GB memory stick. I don't
Check your computer
with antivirus and antispyware program and format 1GB memory stick.
HP USB Disk/Drive Format Utility is a Windows based software
used to format drives to FAT, FAT32 and NTFS partition types.
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format 1GB memory stick
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Jan 21, 2010 | Electronics - Others
My memory stick has stopped working, nothing shows up when I insert it into the computer...I need some of the files which are stored on it, do you know how I can fix it?
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you may need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive this program may help: -
Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
Nov 12, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
Putting on Computer what I have on Memory stick. I have saved songs from a Tyros 3 Keyboard and have difficulty putting it on Computer so that I can burn it on a CD...H E L P
Make sure you are in the song mode so you transfer just the song and not all the other stuff. Copy a song in the song mode to your USB stick, then read it on the PC. To burn it as DATA (MIDI data is data) you must use a burning program like Nero...
If you are trying to make an audio CD that is a different story as you need to convert the MIDI file to an audio format such as MP3 or WAV before burning and AUDIO CD.
Oct 19, 2009 | SanDisk 1GB Cruzer Titanium USB Flash...
HOW DO YOU USE A USB STICK
There are various types of USB sticks or adapters. The most common is an USB memory stick and they come in memory capacities from 256Mb to 32Gb or more.
The USB memory sticks are use to transfer data from a computer to a memory stick and vice versa (ie. copy data from one computer to another computer).
To copy data to and from a USB memory stick, all you have to do is to plug the memory stick into the USB port of a computer, the computer will recognize it as an external memory device.
Wait a few seconds and click to open the memory stick, just like openning a folder on your hard disk. You can then open the hard disk and copy data files from the hard disk to the memory stick in the same way if you were copying data to a floppy disk.
Aug 31, 2009 | Toshiba 1GB USB 2.0 High-Speed Flash Drive...
My U3 Smart SanDisk Cruzer Micro 2.0GB USB Drive Not Recognized
We can fix it -- and recover the data (provided it is recoverable -- which it generally is). If we don't get your data back, we ship the drive back to you and you pay nothing. We've been recovering data for over 16 years and are successful about 85% of the time.
Craftsman Computer Services, Cudahy, Wisconsin
Aug 02, 2008 | SanDisk 1GB Cruzer Titanium USB Flash...
How is transfering Data and information from my computer into 1GB USB2.0(Data Traveler) done?. How do I start and how do I connect the USB2.0 on my computer to begin the transfering?. I am asking this...
FOR ADDITIONAL INFORMATION ABOUT FLASH DRIVES
USB (Universal Serial Bus) flash drives are high-speed, high-capacity memory devices designed for long-term data storage and easy transport among PCs. The host PC treats the device just like a drive, so you can transfer files of all types to and from the device. Because the device emulates a drive, it supports any type of file, including audio files (such as MP3s) and graphics files (such as JPEGs [Joint Photographic Experts Group] and BMPs [bit map]). In addition, USB flash drives can easily support applications, CAD (computer-aided design) drawings, and a wealth of personal information you'd rather not leave on any particular PC. Even so, most USB flash drives are smaller than a pack of gum and can easily fit onto a key ring.
Years ago, users often referred to the practice of using floppies to transport files among PCs as sneakernet. Because USB flash drive manufacturers designed these devices for transport among PCs, their increasing popularity has given rise to a "new sneakernet."
Mar 09, 2008 | Computers & Internet
ITunes download
The memory stick wouldn't change the ability to download with iTunes. You'd want to make sure you don't have a firewall blocking your iTunes internet access.
Jan 23, 2008 | Toshiba 1GB USB 2.0 High-Speed Flash Drive...
Computers & Internet Logo
189 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
