Question about Air Tools & Compressors
Want to find repair/owners manual for 1986 Puma air compressor; 60 gal.,5hp electric, model FPV-50
dmftrucker
  • 1922 Answers
SOURCE: Wiring diagram to convert Craftsman 5HP Air compressor
look on the motor cover or on the wiring cvr on mtr or on the inside of the wire termination cvr
Posted on Oct 06, 2009
  • 1383 Answers
SOURCE: type of oil
Air compressor pumps can use different grades of oil depending on weather conditions and usage, however do not use engine oil. Some Ingersol Rand pumps use a synthetic oil available through WWGrainger on the web. (generally not model specific) If this pump is lightly used you can use the less expensive compressor oil sold at Lowes lumber made by Campbel Hausfeld. It sells for less than $3.00 a bottle. Generally speaking, under normal weather conditions and light duty use, do not worry about the weight of the oil; just make sure that it stays clean and at the right level. If your compressor is running hot, it may be due to other problems like the check valve, head gaskets leaking between cylinders or chambers or high usage. If, however you just want the best oil for your compressor, use the synthetic. It is usually colored blue or green. This oil is special formulation to prevent breakdown in high heat and will not allow carbon for form on parts or inside of the hoses. enjoy
Posted on Nov 29, 2008
  • 1383 Answers
SOURCE: No air pressure past 60PSI on a 125PSI Campbell Hausfield WL61110
Your comperssor is oilless type and suffers from short cylinder / piston life. When the compressor no longer reaches cycle pressure the cylinder / piston should be replaced. These parts are available at www.chpower.com I believe that the part number is wl210300aj. Not expensive, enjoy.
Posted on Dec 13, 2008
  • 497 Answers
SOURCE: I have a 5hp 26 gal upright cast iron.Moved lying on side
clean fuel tank, and lines. just do a standard tune up. check every componet for wear or rust.
Posted on Oct 26, 2009
SOURCE: I have a craftsman 6.5 60 gal horz compressor.
i have the same piece of junk, iv rebuilt it 3 times in the past 5 years always a piston rod snapped and then it was running on only one. they are built like ****. anyhow I finely got smart and bought a cast iron pump thats not only quieter but puts out twice the volume of air in half the time. it took some work but it was well worth it costing under 200.00. the rebuild kit from sears will cost over 100 and it wont last. the one from sears is a direct drive pump and you will be told no one makes a direct bolt on but all it takes is cutting the aluminum housing away from the motor and welding a pin or bolt to the end of the shaft and putting a pully on it, you will also have to turn the motor to the side but let me tell you this was the best move i ever made. you can pick I bought my new pump from a place called heavy dudy air in ga. 877-447-2485
Posted on Jan 18, 2010
I need to fix a leak in my pressure switch
You don't repair a pressure switch, you replace it.
Nov 28, 2014 | Puma Air Air Compressors Puma Air PK6060V...
Ingersol rand 80 gal 5 hp manual
follow the link
http://manualarchive.ingersollrandproducts.com/ir_pdfs/Compressed%20Air/Air%20Compressors/Reciprocating%20Compressor/SCD-877.pdf
Sep 07, 2014 | Ingersoll Rand SS5L5 Ir Electric...
I need to convert mu Puma PPH 30-10 air compressor from 220 Volt to 110 Volt wiring, but I do not have the owners manual or a wiring diagram for it. The Motor is a GE
If this is a 3HP I don't think you can switch it. However there is usually a wiring diagram under the square box on the side of the motor.
Sep 29, 2013 | Puma 3-HP 60-Gallon Belt Drive...
T30 model 242 Safety relief valve pops off at 50-60 lbs pressure. Put on a new one and still the same problem. Don't know what to look for next. Normal cut out is at 150-175. Thanks
From want you are describing sounds like the high pressure valves are leaking in the HP Head. there are 2 safeties on this unit . If the safety that's lifting is between the low and high pressure cylinders it's hp valves leaking. If the tank safety is lifting at 50-60 psi It should be replaced. It is a 200 psi safety.
May 26, 2011 | Ingersoll Rand TS4N5 Ir Electric...
Wiring installation for ss5l5 IR 5hp 60 gallon compressor
A #10AWG wire can be use and 40Amp breaker can be use also. Your 5hp/230V/1/60hz motor amp is 30A.
May 30, 2009 | Ingersoll Rand SS5L5 Ir Electric...
Air Tools & Compressors Logo
537 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
