Question about RIM BlackBerry Curve 8310 Smartphone
Track ball does not work
The track ball scrolls up but not down, and to the left but not to the right. Is there a way to clean the contacts without disassembling the phone? Because of this problem I cannot initiate text messages or emails, and cannot select many of menu items from the screen.
  • 76 Answers
Take out the plastic ring, then the trackball, submerge it in water and DRY it really good
Posted on Jun 06, 2010
Unable to scroll to the right allways
the track ball on the curve is very prone to such problems. we frequently use un-clean fingers when using the track ball. the dirt gets collected on the track ball and on the underside. use an alcohol swab to clean the track ball and your problem should get solved.
Apr 04, 2011 | T-Mobile Blackberry 8900CURVE Curve 8900...
The ball won't press down anymore.
take a cotton stick and dip it in petrol and then clean ur mouse with that cotton stick hope it would work . . .well mine did !!!
Mar 23, 2010 | RIM BlackBerry Pearl 8100
Rollerball will not go up it goes left and right and down
Trackball doesn't work if you have not selected the sensitivity. To select the sensitivity, kindly follow the steps: 1. Select menu. 2. Select option. 3. Select screen/key board. 4. Scroll down to find horizontal and verticle 5. Select horizontal-100 and verticle-100.
I Hope it helped you.
Thank you for using ' Fixya ' and have a nice day!!
Nov 16, 2009 | RIM BlackBerry Pearl 8100
My track ball scrolls on my blackberry curve but niether the keypad or the track ball works. how can this be soved without buying a new phone?
try cleaning the track ball with a qtip dipped in alcohol or nail polish remover.. It could be that the track ball isn't "reading" correctly due to oil, etc.
Nov 15, 2009 | RIM BlackBerry Curve 8310 Smartphone
When I roll the ball to the left, the cursor doesn't go to the left?
change the trackball sensitivity
Steps :
1. Click Menu Key
2. Go to options, under that select Screen/Keyboard
3. scroll down you will get track ball settings
Horizontal sensitivity
Vertical sensitivity
increase the sensivity to 100 then you will be able to roll track ball,it will work fine....
Oct 30, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
My scroll ball won't allow me to scroll DOWN; I can scroll up, across right and left, but NOT down................
pop the silver ring off from around the ball and remove the ball assembly. Be careful cause the ring only has connections on three sides and you must start on the side without the "pins". just keep messing with it and it will come out. then clean the rollers up and make sure the flap connector on the bottom is clean and intact. That should do ya for now and should hold you for several weeks
pls rate this fix
Oct 05, 2009 | RIM BlackBerry Curve 8310 Smartphone
The ball won't scroll down
Have you removed the ball at any time? If it is put back in wrong, it could cause this. If not, the ball assembly itself might be bad. You can find them fairly cheap on eBay.
May 30, 2009 | RIM BlackBerry 8800
Cannot scroll up with my Blackberry Curve 8310 trackball
It is a very common problem. You just need a new trackball. Should be about $25. If you want to make it work temporary, then just removed it and clean the trackball and the phone part under it (on the phone itself) with 99% alcohol. It might work for a while again
May 13, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Blackberry pearl
Common faults with Pearls, do you have warrenty on the Phone?
Send it back for replacement as its hardware fault.
I hope this helps,
Thanks.
Mar 07, 2009 | RIM BlackBerry Pearl 8100
Pop the ring around the track ball out with a small blade or your finger nail. Three double prongs hold it in place (bottom and both sides, none on top). Turn device over and gently tap the back. Track ball will release once ring is removed. At this point you can view the track ball and see exactely what is causing the block. Clean if needed with q-tip or remove lint/debris/etc... Just did this with my 8830. Working perfectly now. - {would not scroll down at all prior to}
Nov 25, 2008 | RIM BlackBerry 8800
RIM BlackBerry Curve 8310 Smartphone Logo
283 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
