Question about LG 24 in. LDF 7811 Built-in Dishwasher
Bosch dishwasher the string on the door tensioner has broken I have the new part but dont know how to got out the lower part. Do I have to take off the hole door or is there an easy way to change it? It seems odd that as its string and must be prone to breaking that there is not a simple way to fix it.
  • neil29 Apr 08, 2008
    I have got into where the part is but without takeing off the door I cant see a way of changing the lower part. Am I right or should I get an engineer. neil
  • 135 Answers
You have to remove the entire dishwasher from under the counter. Then locate the broken cable. There is a panel you need to remove to access it. It attaches to a spring which goes to the underside of the dishwasher. Not an easy repair. Need alot of patience for this but it is doable.
Posted on Apr 08, 2008
How do I adjust the door tension on a Bosch SHU 6802 undercounter dishwasher to keep it from falling open
you cant change the tension more likely one of the ropes attached to door spring has snapped so you are only getting counterbalance from one spring not two.
Feb 04, 2017 | Bosch Dishwashers
Bosch dishwasher door tension
Most dishwashers have big springs that run front to back at the bottom sides of the body. These are the door springs. Tension is adjusted by moving the spring to one of several holes in the frame. One way will give you less tension on the door the other way will increase it. If the dishwasher is new, why not call service and let them deal with it. Should be under warranty.
Mar 24, 2015 | Bosch Dishwashers
Shu43 cycle runs normally but at the end it continues to fill - and then drain. continues to do that till inlet water is turned off.
underneath are 2 L-brackets with the springs attached. Pull those out (with the door closed) and tension will be released. Shorten the strings attached to the springs and reinsert the L-brackets.
Oct 31, 2013 | Bosch 24 in. SHU43 Built-in Dishwasher
Door hinge tension adjustment
You have to change the springs at the bottom back.It; s easy.You must buy the item 0509 at this page or anyother you like http://www.searspartsdirect.com/partsdirect/part-model/Bosch-Parts/All-Products-Parts/Model-SHX45P05UC60/1794/0130000/1010702P/00005?blt=06&prst=&shdMod=
Then you must access the bottom side of the base of dishwasher and with a screwdriver pull off the old springs.After this you will see a cordon that you must remove it and connect this to the new springs.
Sep 05, 2013 | Bosch Dishwashers
Adjusting door spring tension on a Bosch dishwasher
Nov 18, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Leaking door on Bosch dishwasher
I DONT THINK THERE IS A ASSEMBLY MANUAL BUT THE DOOR HINGES IS LOCATED UNDER THE LEFT AND RIGHT SIDE OF THE MACHINE. YOU HAVE TO CHECK THE HINGE PULLEY THEN CHECK THE LOCK.
Sep 23, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Replace lower door seal
Well, job done. I tried using cable ties to hold the hinges down without success, string would have broken immediately. The only way to do it without a specially made tool is to insert screwdrivers in the narrow gaps between the hinge and the frame with the handle held in place by the bottom of the door and the seal that is being replaced. The problem with this is that when the door is fully removed the screwdrivers are likely to slip and the hinges slam shut, disastrous if any body part is in the way. What is needed is another pair of hands to hold both screwdrivers in place. Apart from having to work around your helper( get a thin one if possible) the rest is easy. Fit the seal to the frame first, then position the fixing plates and hod in place with a paper clip in the lower screw hole. Re-attach the door to the hinge fixing the top screws first, remove the paper clips and fit the lower screws. Your helper can now make the tea whilst you re-fit the rest of the door.
Jun 28, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Dishwasher detergent door spring
I ordered and received the new Bosch dishwasher detergent door, but do not know how to repalce it!
Jan 23, 2008 | Dishwashers
Door Drops Open - How to Fix
Today my father and I solved this problem permanently for about four dollars. Yes only $4!!! I priced out the total repair for a Kitchenaid repair guy with parts and labor to be at least $250 and that was just too much for a $1500 dishwasher. Here's how we did it and here's how kitchenaid should have done it in the first place...
After searching the internet and diagnosing the problem with my kitchenaid superba dishwasher, I also found that my nylon pulley spring system on one side had ruptured. Door made loud explosive sound one day when opening and then would just drop open real hard once unlatched after that day. I really didn't care too much about it until my three year old almost opened the door on my one year old's head. I took off the bottom panel and found a broken nylon string and a couple of white plastic pieces.
That lead me to this website.
So I looked into fixing this myself and got ready to order the part from here
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1059756&PPStack=1
and found it would be about $25 with shipping and handling and would arrive in about a week. I figured that there has to be a better way than nylon string to absorb the transition from metal spring to metal door. This problem was bound to recur in a short period of time because nylon is not made to take that tensile force. We went to Lowe's, bought four feet of 1/16 inch galvanized woven steel cable (total cost of $1) and two sets of ferrule and stops ($3 for both). 7_9_2012_4_05_45_am.jpg
Then we unscrewed the two side fasteners holding the dishwasher to the cabinets (We had already unscrewed the two screws and removed the base board). We placed masking tape on the floor to prevent the foot pads from scratching as we pulled out the dishwasher. With a little upward lift, my father was able to turn the foot pads and create more room and we then placed felt pads under them to padd additional protection from scratching.
Here is the broken nylon and its plastic pieces and the spring
close up of the poor construction that this heavy door relies on
We then measured out the distance from the end of the spring through the pulleys and to the hook on the door to be 17 inches, and thus, constructed a steel replica 16.5 inches to keep everything tight.
So, from then end of one loop to the end of the other loop measured 16.5 inches. We double crimped each end with the ferrules.
The other side was intact, but we just went ahead and removed it and replaced it with our new steel cable replicas. Here is the final insertion showing the steel cable going through the pulleys and hooking on the door.
The door works great. My wife can't believe it. Most of all, my children are safe from head injuries from the heavy door. This whole escapade took about 45 minutes to do and literally only cost $4, yes four dollars. I suggest two people to do the job as my father was helpful in holding the flashlight and making sure we had enough slack on the water lines when we pulled out and pushed the washer back in. I hope this helps anyone that googles 'kitchenaid superba door' or 'kitchenaid superba broken heavy door'. Eat your heart out kitchenaid, make the next line of washers with a steel cable instead of nylon.
Jan 18, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Door Tension
just about the most difficult job to do on a dishwasher, not normally a job for the home mechanic, i am an appliance engineer of 20 years and often shy away from jobs like this,
there is often no adjustment, the hinges are sprained, more often that not by people either putting weight on the door to stand back up, or children climbing on to get higher
the only thing i think you can do is to check the springs are in place and nothing is broken or just come off that can be put back?? sorry
Oct 14, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
LG 24 in. LDF 7811 Built-in Dishwasher Logo
135 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
