Question about Samsung LN-T4061F 40 in. LCD HDTV
Turning on the Power
When I push the power button, using the remote or TV, the TV used to turn on automatically...now it clicks approximately 10 times before it turns on this has gotten progressively worse. It used to be a couple of clicks a few weeks ago.
    Sniper:
  • 67 Answers
Your power supply board needs to be REPAIRED not REPLACED, replacing the board will just make the problem happen again in two years or less, if you can use a screwdriver you can send me the board and I will repair it for less than it would cost you to do it yourself ($50) with the correct components. Email for further instructions! Cory Schindler cschindler24@yahoo.com
Posted on May 30, 2010
Need code to program rca remote to my rca t.v.
rca technical support is sadly lacking... I used youtube to search for the remote model number to find a video that taught me how to search with the remote to get the proper code. ..try this, for tv hold tv button and power button on remote till power button turns red, next point remote at tv which is already on and press the play button on the remote. This causes the remote to try 10 codes. wait for the power button to quit winking at you, if the device (tv) turns off, it means that one of the 10 codes was correct. If the device stays on press play again to try the next set of 10 codes. It may take several tries. When it responds by turning off, we need to back up to the exact code by pressing the << reverse button one press at a time. When power comes on you have found the code. Now use the stop button to lock it in.:) I'll include a link to a vid. Programming an RCA Universal Remote If this helps please 'like' my answer.:P Mikee
Oct 13, 2014 | Televison & Video
Bush lcd42f1080p100hz remote will not turn tv on
I had come home about a week ago and pushed the power button from my remote but my tv did not respond. So I just went to the front panel and pushed power but once the tv turned on, the volume was on full blast! I used the front panel volume decrease to get the volume down, but when I stopped pushing the button, the tv increased its volume to full blast again by itself! Naturally I just turned the tv off for a few moments. I tried the remote again, no response again, so I used the panel power button. The tv volume was still full blast when it turned on but after I decreased the volume it stayed this time. The picture is and has been perfectly fine and the tv was working fine. The next day the problem started all over and now once we turned it off from frustration of having to manually use the panel to change channels, it now will not turn on at all. I have changed batteries from my remote, reprogrammed my remote, pushed system reset several times, unplugged it for a while, bought a new surge charge, and even held the menu and device panel buttons for 10 sec and tried to turn the t.v. on again! What other options do I have or what may be the issue at hand and possible parts that may need to be replaced?? Thanks!!
Nov 02, 2012 | Televison & Video
Have a proscan ps50700 that wont show the picture, will turn on but turns itself right back off. what could it be
TV Doesn't Turn On
  • Your RCA rear projection TV may not turn on from time to time for several reasons. First, check that the power cord is plugged into a working power outlet. Check that the outlet is receiving electricity by plugging a different device into the outlet. If the other device doesn't work, you may need to replace a fuse or reset a circuit breaker in your home.
    If you tried using the remote control to turn on the TV, press the "Power" button on the front of the TV. You may have a problem with the remote control if the TV turns on.
    If you tried using the front control panels and haven't tried the remote, press the "Power" button on the remote control. The television controls are blocked if the TV turns on with the remote. To unlock the controls, open the "Parental Control" menu and remove the check mark next to "Front Panel Block."
    Finally, your TV may be performing a diagnostic check. These checks are used to find any errors in your TV. Wait a few minutes before trying to turn on the TV again.
TV Turns Off By Itself
  • You may find that your RCA TV turns off by itself on occasion. This is often because the "Sleep Timer" feature was enabled. This feature allows you to place a timer on the television that will turn it off after a specific amount of time has passed. The feature allows you to save on your energy bill and extend the life of your television.
    If the "Sleep Timer" wasn't set, the television may have detected a power surge in your home and shut off automatically to protect the components of the television. Wait at least 30 seconds before turning the TV on again.
    Finally, if you suspect the television is turning off for a reason other than a power surge, unplug the television and let it sit for at least 10 minutes. This will clear any errors in the television. After 10 minutes, plug the television back into the outlet and resume normal use.
  • Blank Screen
  • A blank screen on an RCA rear projection television is usually caused by a loose connection or an incorrect setting. Check that the coaxial connection on the back of the television is secure or, if you're using an external device such as a DVD player, the video cables are secure. Press the "Ant/Cable" button to switch between tuners if you are watching television, or the "Input" button to switch between input channels if you're watching something from an external device.
Apr 21, 2012 | Proscan PS60690 60" Rear Projection...
When i turn it on it clicks and the goes right back off
New set?
If you're turning almost any TV on by the manual power switch on it, thats Standby mode.
The next step it's waiting for is the ON command from the remote control.
There are two main methods remotes use to go to ON from Standby:
Press the Power button for both on and off commands
Press any 1-10 (or 1-0) button for on, press power button for off.
Sep 24, 2011 | Sanyo DP42848 LCD TV
My TV remote comtrol will not work when I try. I need the code.
Hi.
Manual Programming:
1. Turn on the device with which you want to use the remote control.
2. Locate a 3-digit code for your device.
3. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) for approximately three seconds unitl the POWER INDICATOR illuminates.
4. Enter the 3-digit code for your device within 30 seconds. The POWER INDICATOR shuts off.
5. Press power button to verify correct code entry. If the device shuts off, the code was entered correctly. If the device does not shut off, repeat steps 3-4, using a different code.
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control(TV, VCR, SAT, DVD, CAB or AUD) until the POWER INDICATOR illuminates. The remote control is in programming mode.
3.Press and release power button. The POWER INDICATOR flashes once and stays on
indicating the unit is in Power Scan mode.
3. Press CHANNEL UP or CHANNEL DOWN repeatedly until the device turns on.
4. When the device turns on, press OK to store the code.
5. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Codes for orion TV are
096,10,146
Thanx
Jul 27, 2010 | Brookstone 538744 Remote Control
Model: 32A43 Problem: Volume goes UP automatically. Channel scolls automatically. I tried using the remote and the buttons on the tv panel but neither works. I tried turning the TV off with the remote and...
check the front button plate on the front of the tv very carefully.if it has been hit with something and either or any button is pushed in,it will not listen to other commands.make sure each button has a distinct click when pushed.a frozen button will cause other things not to work.it sounds to me like two buttons are making contact,and they are beside each other,so the button plate is crooked or warped.
Jul 18, 2009 | Toshiba 32AF43 32" TV
Connecting Nintendo Wii to JVC television
every time im using my wii in my jvc tv i keep clicking channel the when i click the tv button on the rca remote then a code. i keep forgething the code
Dec 28, 2007 | Televison & Video
Magnavox lcd tv
Setting the Sleep Timer sleeptimer.gif The sleep timer allows your LCD TV to automatically turn OFF after a given amount of time. You can set the sleep timer using your remote control or through the onscreen display (OSD).
TO SET THE SLEEP TIMER USING THE REMOTE CONTROL
1. Press the SLEEP button on the remote control. The sleep timer appears at
the top of your screen.
2. Press the SLEEP button one or more times to select the time you want.
3. Press the EXIT button to hide the sleep timer display. Your sleep timer is now running in the background. The sleep timer will be hidden after 10 seconds.
Turning On the LCD TV.
1. Press the MAIN POWER switch in the back of the unit (see Back Connectors for location). The Status LED on the front turns orange
and your LCD TV is ready to turn on.
2. Press the POWER button on the front of your LCD TV or on your
remote control. The Status LED on the front turns green.moz-screenshot-6.jpgmoz-screenshot-5.jpg
Dec 18, 2007 | Televison & Video
TV won't turn on
I am having problems turning on the tv. I had lost the remote control so I bought a universal remote which was not working at the time I unpluged the tv form the powersocket then I tryed to turn on the tv the green power light stays on for a few seconds then it blinks two times then there isn't a power light on after that what is wrong
Jul 26, 2007 | Mitsubishi WS-48613 48" Rear Projection...
Samsung LN-T4061F 40 in. LCD HDTV Logo
186 people viewed this question
Henry  Thomas
Henry Thomas
