Question about Linksys Wireless-G WRT54G Router
Linksys router, I do not know my own wep code to
I have a Linksys router, I do not know my own wep key code to allow me to use my laptop or my Wii?
    Genius:
  • 1,354 Answers
1. Step 1
Open your web browser, type " http://192.168.1.1/ " into the address bar and hit "Enter."
2. Step 2
Use "Admin" as the username in the pop-up box and leave the password blank.
3. Step 3
Connect to the Internet and click on "Internet Setup."
4. Step 4
Select your connection type from the drop-down menu. Choose "DHCP" for cable modems or "PPPoE" for most DSL modems. If you are unsure of these options, check with your ISP.
5. Step 5
Set a service set identifier (SSID) to identify the router and change the password.
6. Step 6
Encrypt your wireless connection using a Wireless Encryption Protocol (WEP) key. Under the "Wireless Security" option, enter a passphrase and click "Generate." This will generate a password which will need to be used by any client connecting to your router.
Posted on May 30, 2010
    Novelist:
  • 177 Answers
HI Friend,
As you mentioned that it is not accepting http://192.168.1.1, so you may follow these steps:
1.Connect the computer with a Ethernet cable to the WAN/INTERNET port of the router with an Ethernet cable(Blue/Grey/Yellow color cable) and also connect you computer and turn on the router.
2.Go to Start>Run>and type cmd (to open command prompt)
3.Now type ipconfig/all and hit enter
4.Note down the Default Gateway" (will be a umber with it)
5.Now type that number in the Web browser and hit enter.
6.Now do not type anything in the Username box(leave it blank) and type admin as the default password and hit enter.
7.On the Setup page,click "Wireless" tab and fill the sections as mentioned:
Wireless Network Mode:Mixed
Wireless Network Name:As per your choice
Wireless Channel-6-2.437GHz
Wireless SSID-Enabled and click Save Settings.
8.Now Click Wireless Security and fill the sections as mentioned
Security Mode-WEP
Default Key-1
WEP Encrypion-64 bits 10hex digits
Key1-Enter 10 digit password(e.g-your 10 digit telephone number) and click Save Settings
Please note the WEP key,this will help you to connect your wireless devices. Turn of the router for 30 seconds and turn it on again. Now you can connect your wireless devices.
Regards
Chiranjeet
Posted on Jun 08, 2010
I have been trying to connect my Wii to my Linksys wireless in my home and every time I try, I get the error code of 51330 with a mention of being unable to connect to the internet. What can I do to fix...
A. Do you have the SSID for your Linksys router as just "linksys"? That name is so common that someone nearby might have set up a new router and left it the same name as well... and your Wii is trying to connect to THEIR "linksys" instead of yours. Try changing the name broadcast by your router to something else, then try connecting using that new name.
B. Be sure you are typing in the WEP or WPA passphrase correctly, it is SO easy to mess up one simple letter in the code and nothing will work. I've gotten dozens of service calls for iPods and games where the customer said their code didn't work, but worked for me when I got there. I know, it's frustrating, just be SURE you have the code 100% correct.
Other reading material from Nintendo is below:
Wii error code 51330 It is unlikely that your Wii console needs any type of repair, as according to the Nintendo Error Code Lookup, the 51330 error code is "usually indicates a problem relating to wireless security."
Error Code: 51330 This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
  1. Are you using WEP or WPA security on your router?
    1. Log into the router using the default IP (consult your router's manual for assistance)
    2. Locate the "wireless security" section of your router settings and find the WEP or WPA key.
    3. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
    4. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
    5. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
    6. If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
    7. If you are using WPA, the Wii console is compatible with the following types:
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
  2. If your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
    1. From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model).
    2. If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings).
    3. If the Mac address filter was disabled, then continue troubleshooting.
  3. Try adjusting the "Channel" your wireless router broadcasts on. We highly recommend setting your wireless router to either channel 1 or 11. This can potentially increase the download speed. For information on accessing your router's settings, click here to select the brand name and model number of your router (if available).
  4. Check Nintendo's router info for special notes, if available, for your router.
    1. Click here to go to our Wireless Router lookup page.
    2. Use the drop-down box to select, if available, your router manufacturer.
    3. Click on your router's model number, if available.
    4. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
  5. Ensure that the router is set to broadcast in "mixed" or "b/g" mode. Routers set to "g only" may not be able to allow a successful connection from the Wii console. (The option to change this setting is typically found in the "Wireless" section of your router's settings. For information on accessing your router's settings, click here to select the brand name and model number of your router, if available.)
  6. Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
  7. Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response.
  8. If you are still receiving this error code, please click here for assistance.
But if the above information doesn't help correct this problem, then give a call to Nintendo's 1-800-255-3700 (6 am ~ 7 pm Pacific, everyday) Customer Service number, and one of the service representatives will do some over the phone troubleshooting to determine exactly what is causing this and then talk you through any needed steps to correct it.
May 25, 2011 | Computers & Internet
What is a WEP key for a Linksys WRT400N wireless router?
The WEP encryption key (network key) is in your wireless router, without this key the wireless router won't allow the computer or laptop to connect to this wireless router.
I recommend you use WPA or WPA2 encryption, it is much stronger than WEP.
The WEP, WPA, WPA2 encryption key is in your router's wireless settings. Log into your router and got to the wireless settings, you will need to get the SSID and the encryption key. Then go to your computer or laptop's wireless card and configure it with the router's SSID and encryption key, so it will then connect to the wireless router and the Internet.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jan 01, 2011 | Linksys WRT400N Router
Hi do you know how I can connect my lap top to the internet wireless with my linksys wireless router ? the lap top asks for an access code and I do not know what it is or how to find it do you know how to...
The access code or password is the encryption key in your wireless router, without this key the wireless router won't allow the laptop/computer to connect to this wireless router.
The WEP, WPA, WPA2 encryption key is in your router's wireless settings. Log into your router and got to the wireless settings, you will need to get the SSID and the encryption key. Then go to your computer/laptop's wireless card and configure it with the router's SSID and encryption key, so it will then connect to the wireless router and the Internet.
Dec 27, 2010 | Linksys Wireless-G Broadband Router
Cant get online through sky broadband
Wii Error Code 51331 means there is a problem with wireless security.
Make sure your router’s WEP/WPA (one or the other not both)key matches the WEP/WPA Key you entered in the Wii.
If you double checked the WEP/WPA key with the router and the Wii and they match, but you still receive the Wii Error Code 51331, then MAC filtering may be enabled in the router. You will have to add your Wii’s MAC address to the router’s allowed list. You can do this by logging into your router and going to the “access control, access list, or network filter” settings.
If you still have trouble with Wii Error Code 51331, try changing the wireless router’s channel to 1 or 11.
Jul 24, 2010 | Nintendo Wii Console
EROR CODE 52031 ON NINTENDO WII
Hi,If you’re using WEP or WPA for your router’s security, log into your router by typing its IP address in your internet browser and make sure your WEP or WPA key entered in the Wii matches the key in the wireless router. The WEP Key can only use characters 0-9 and A-F. If your router allows more than one WEP Key to be entered, make sure the key in slot #1 is the active key. The Wii can only use the key in slot 1.If you entered the correct key, then check to see if MAC filtering is enabled in the “access control, access list, or network filter” section of the wireless router. If MAC filtering is enabled, you will need to enter the Wii’s MAC address into the “allowed” list for MAC addresses.
If none of these were the problem and your connection used to work, try power cycling both the router and modem by unplugging both from the wall. Wait a couple of minutes before plugging the modem back in. Wait another couple of minutes for the modem to initialize, then plug the router back in and wait until the router initializes.
Ensure that your wireless router has the latest firmware installed. You will need to go the router manufacturer’s website to download the firmware.
If Wii Error Code 52031 is still a problem, try changing the broadcast channel of the wireless router to 1 or 11. This can help increase download speed.
You an also try manually entering the Wii’s internet settings. You will need to first get the network configurations from your PC.
On your PC, click “Start” and then “Run.”
Type “CMD” into the field that appears to open a new window.
Type “IPCONFIG/ALL” and press “Enter” to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Good luck
Jun 10, 2010 | Video Game Consoles & Games
My Linksys will not connect to my WII
Well the first thing is that you have WRT160N router. This router has issues with the firmware. So first you will need to upgrade the firmware of the router. Download the firmware of the router from the manufacturer's web site. Connect your computer to the router. Open the router page. Click on Administration tab. Just below administration you will find firmware upgrade subtab. If you click on it, you will find the browse option. Browse the file that you have downloaded from the web site. and Click upgrade.
For WII, you will also need to change the MTU to 1365 and open some port numbers on the router.
Apr 17, 2010 | Linksys WRT160N Wireless Router
Cant find my wifi code to open a network
Your WEP is the security key you set in your router to allow other authorised devices to access your network. When you set it up, you set the WEP to protect your network from others accessing it without the key. So now all you have to do is set the WEP (security) key in your laptop the same as your router and you're cookin'. The same key must be used to connect any thing, iPhone, Wii, Play Station, anything that has WiIFi capabilty.
Apr 07, 2010 | Toshiba Satellite Pro L300 Notebook
Cant get a wireless connection. error code is 51330
Set your router to Mixed Mode.
If it is set to G-Only it will not work.
Set the channel on your router to either 1 or 11
Both of these settings can be found in the wireless tab on a standard linksys router.
http://wiihacks.blogspot.com/2006/11/fix-for-wii-error-codes-51330-52030.html
Dec 02, 2009 | Nintendo Wii Console
Error Code 51331
Make sure your router’s WEP key matches the WEP Key you entered in the Wii.
If your router is using 64-bit encryption, the WEP Key must be 10 characters.
For 128-bit encryption, the WEP Key must be 26 characters.
WEP Keys can only use the characters 0-9 and A-F.
If your router allows more than one WEP key to be entered at a time, make sure the key you’re using is on slot one.
If you double checked the WEP or WPA key with the router and the Wii and they match, but you still receive the Wii Error Code 51331, then MAC filtering may be enabled in the router. You will have to add your Wii’s MAC address to the router’s allowed list. You can do this by logging into your router and going to the “access control, access list, or network filter” settings.
If you still have trouble with Wii Error Code 51331, try changing the wireless router’s channel to 1 or 11. This may increase download speed.
Check Nintendo’s router page for special notes on your router if available. Follow the instructions of the special notes.
Your wireless router must broadcast in mixed or b/g mode and cannot be set to “g” only mode.
If you still encounter the Wii Error Code 51331, try doing manually setting up the Wii’s internet connection. You can find your network information to enter into the Wii by doing this:
Power cycle the wireless router and modem by unplugging both from the wall. After waiting a minute, plug the modem back in and wait another couple of minutes for the modem to initialize. Plug the router in and wait for the router to initialize. Now try reconnecting the Wii to Nintendo WiFi Connection.
Hope this helps a little
Sep 10, 2008 | Nintendo Wii Console
Error code:51331
Jul 02, 2008 | Video Game Consoles & Games
Linksys Wireless-G WRT54G Router Logo
112 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
