Question about Nikon D50 Digital Camera
Black at the bottom of the pictures - Nikon D50 Digital Camera
  • 1,170 Answers
Possible causes :
1. dirt or dust in camera or lens
2. dirt on sensor
3. sensor is cracked
If you are using the built-in flash and a telephoto lens, the end of the lens can block some of the light from the flash and that appears as a slightly rounded black "hump" at the bottom of your picture.
Posted on May 30, 2010
What can be done to repair picture to my TV
Vertical scan output section circuit should be checked. Contact any service technician.
Aug 30, 2014 | Toshiba CF32H40 32" TV
Samsung TSL2793HF - Slight Right Side Pincushion and Horz Line Bottom to Top Until the TV Warms up
Yes, this is rare but I have seen it before--not fixable if it is what I think it is----It is what is called a Dome effect---the shadow mask in the picture tube is actually contracting and or expanding depending on temperature---
Directly behind the phosphor coating (the stripes that you see on the screen) is a metal screen--the holes or perforations in it line up with the stripes on the phosphor screen.
Some masks either have a material or a defect causing the dome effect----Not likely to be anything else---a Pin amp problem will not usually act the way you describe but a shadow mask inside the picture tube will act exactly that way.
Dec 02, 2012 | Televison & Video
Big black square in middle of screen picture top to bottom about 36 " wide good audio and picture 6" on right and left side displaying.
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 26, 2012 | Hitachi 55HDS69 55 in. Plasma Television
My screen is black at da top and bottom but its a pic in the middle.its just not showing the whole picture
it sounds like you have a widescreen video on your 4:3 tv. the black bars on top and bottom widen the screen picture.
Nov 05, 2011 | Symphonic ST419E TV
The picture is crunched like if you were watching a letterbox movie.(with the black at the top an bottom of the screen how do i correct this
Black on top of bottom is widescreen.. Some dvd's are made in only widescreen. Usually you have to buy a full screen disc to cover the entire screen or change to format to 16:9 or 6:9 or whatever it handles/
You may see the black on top and bottom, it is annoying at first, but the picture is so much wider and you can actually see more on a widescreen
Dec 01, 2009 | Panasonic PV-DM2792 Triple Play 27 in....
Black frame around picture
Toggle through the "Picture Format" settings from your tv remote.
Flip through cinema mode, too standard....etc
Jun 12, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sonykp46v15 bottom half picture is black
Check your +26 and -26 voltages on your ic's.
Mar 30, 2009 | Sony KP-46V35 TV
Visio LCD TV - Partial Picture blacked.
Hello! I have a 32" Vizio LCD...within 30 minutes of the tv being turned on, black lines start running through the bottom half of the screen and eventually blacking out the bottom half of the tv screen. It also doesn't have anything to do with the ratio as I have tried that. HELP!
Jan 06, 2009 | Toshiba 42HP66 42 in. LCD Television
Help black line on bottom of picture.
After a bit of experimenting, I have found a solution that works in my case. The problem was the shutter speed. At 1/200 I got the black line on the bottom of my pictures, but when I tried it at or below 1/100 it was gone. Hope this helps.
Jun 15, 2008 | Nikon D50 Digital Camera
Black bars in the picture
For Models: CC4352, CC4362, CC4393. Your camcorder has a wide format recording mode that lets you make recordings compatible with the 16x9 format. When 16x9 is activated, the camcorder records black bars at the top and bottom of the picture to produce the wide-screen (movie) effect. This is also known as "letterbox" recording. Do not use this mode unless you have a compatible 16x9 TV. When played on a regular TV, black bars appear on the screen. If the 16x9 feature is activated on your camcorder and you want to turn it off, press REC/PAUSE to pause recording, and repeatedly press DIGITAL EFFECTS until no digital effects display appears.
Sep 06, 2005 | RCA CC-432 Camcorder
Nikon D50 Digital Camera Logo
125 people viewed this question
Top Nikon Cameras Experts
Greg Cann
Greg Cann
Are you a Nikon Camera Expert? Answer questions, earn points and help others
