Question about Lexmark 4039 Model 10Plus Laser Printer
Hi All Does anyone have or can anyone tell me where to get a lexmark 4039 power supply schematic diagram. This is the 240 volt version..... Thanks in advance for your reply.. Regards Bill
    Genius:
  • 1,354 Answers
Hi
u can buy from online from lexmark site or locale service provider
Posted on May 30, 2010
Lexmark 4039 laser printer is printing left side of the page faint
check the cartridge it has a toner pcr and cylinder inside maybe its defective or the ic chips
Feb 19, 2013 | Lexmark 4039P 4039 Plus Laser Printer...
Want to add 240volt outlet to generator
You CANNOT do this, USA 240V is derived from a poly phase scenario, IE 120V line to neautral and 240V line to line, UK 240V is derived from 1 line to neutral it will not work unless you power a transformer
May 16, 2012 | Coleman Powermate Powermate 5000W...
How many amps a fuse in breville mixer
Not knowing the model of the mixer you are talking about, or where you are in the world and the voltage you are running at, I can't tell you. But I can tell you how to figure it out. Simply do this:
You obviously know what your main power supply voltage is, either 240 volt or 110 volt
You can look at the mixer and there will be a data sticker with the wattage of the motor on it
Watts divided by volts = Amps
Therefore, if you have a 500 watt mixer on a 240 volt system 500/240 = 2.083 so use a 3 amp fuse
a 750 watt motor on 240 volts 750/240 = 3.12 so use a 5 amp fuse
a 500 watt motor on a 110 volt supply 500/110 = 4.5 so use a 5 amp fuse
etc etc etc.....
Hope this helps
Jul 26, 2011 | Microwave Ovens
I need a replacement power supply cable for my Lexmark Z2300 printer. Spec is 15 watt universal pwr supply, 100-240 volts AC, 50-60 Hz. Any good ideas on where to get one? (quickly & cheaply, if...
This may be hard to find in stores but I strongly suggest you contact Lexmark technical support to request this. They may require your contact info and the printer's serial number for documentation purposes. Thanks
Aug 04, 2010 | Lexmark X5470 All-In-One InkJet Printer
I need software and drivers for this printer. thanks.
Here's the link to the Lexmark website for the available Lexmark 4039 drivers. http://bit.ly/9d4tdC. Click on the Microsoft, Macintosh, Linux/Unix or Others dropdown found below the page to choose the version of the operating system of your computer. Download and install the software. Hope this helps.
Jun 15, 2010 | Lexmark 4039 Model 10Plus Laser Printer
Lexmark x75 all in one. Started with communications device error. could not print. went through troubleshooting-still wouldn't print. started printing randomly(not initiated by me). Couldn't clear print...
Hi. That's quite a problem you have there. Have your attention first on the power supply. It does get hot but it's unusual if it gets very hot. Take out the power supply (the black box behind the printer where the power cord is attached). Check the power specifications. Most of the Lexmark power supply has input ranging from 120-240 Volts and an output of 30 Volts. Make sure you're plugging it in the right voltage range. Check if you're using power surge protectors or power strip, disconnect it and plug directly into a properly grounded wall outlet. Power surge protectors can also draw power away from the printer. When everything's well, try printing again. Hope this helps.
Mar 18, 2010 | Lexmark X75 All-In-One InkJet Printer
55HDS69 Power Supply problem
I have found that the power supply is usually good, it's the other boards that tell it to shut down within a second. There are input called Vsego and VSago that tell the power supply to stay on.
Nov 05, 2008 | Hitachi 55HDS69 55 in. Plasma Television
PS36K power supply overload problem
Most of Pyramid's supplies are based on the LM723 voltage regulator. The DATASHEET should tell you most of what you'll need to know to repair it. THIS is the schematic diagram.
If the output voltage drives the voltmeter to the end of the scale, it likely has one or more shorted power transistors.
Dec 21, 2007 | Pyramid - PS21KX 20 Amp Power Supply Car...
Lexmark 4039 Model 10Plus Laser Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
