Question about Samsung RF197ABRS Bottom Freezer French Door Refrigerator
"space compact icemaker" cover fell off. How to put it back?
When we tried to squeeze in bag of ice. A cover with engraving "space compact icemaker" and "test switch" fell off. I can not put it back on. Do you know how to do it?
Thanks.
  • 4 Answers
To replace this part, locate the two holes at the front of the top base of the ice maker, going up into the freezer ceiling. Place the two half-round 'pegs' at the top of the missing cover (above the vent holes) into these holes, then press the cover back into place. The peg protruding from the back of the piece should go into the hole in the ice maker housing, and the prongs will catch on the ice maker when you snap it into place by brute force. I wasn't strong enough to push it back on with one hand, but a stronger person did it in seconds once I explained how it should fit.
Posted on Nov 28, 2010
  • 1 more comment
  • stallam Jul 10, 2011
    Thank you so much for your detailed instructions. It was very helpful, as it happened to us earlier today.
  • Valerie Alessi Davis Dec 07, 2013
    I was going CRAZY trying to get that back on, thought it might be broken, called Samsung (no help) and then Lowe's extended warranty people who were going to send out a new one in case the part was broken thus not snapping on. Then found these instructions (while reading the part number to the warranty people). This did the trick! Worked like a charm. Thank you so much.
  • Anonymous Jan 09, 2016
    thanks. this worked for me also. i a sending back the new one. the old part isnt broken..
Ice maker arm fell off wouldnt go back on
Hello friend, thank you for your inquiry!
Based off the information you have provided the arm on the icemaker of your Frigidaire refrigerator will not go back on. It is possible that a component on the inside of your icemaker is faulty. If you could provide me with your model number I can check to see if any further information is available. You should be able to locate the serial tag on the inside wall of your refrigerator. I look forward to assisting you. -Matt
Feb 16, 2015 | Frigidaire Refrigerators
Ice maker shutoff bar fell off
This arm is called a "bale". There should be a small, round opening on the backside of the front of the ice maker. Use a mirror to look behind the square control box of the icemaker and you should see the opening. It is impossible to see it from the front when the icemaker is installed in the unit.
Oct 10, 2014 | Kenmore Refrigerators
Ps78139 icemaker not getting water to ice tray
Hello, Check the water line coming into the back of the refrigerator to make sure not kinked. First replace inline water filter. If that doesn't fix, then the icemaker will have to be replaced.
May 16, 2014 | Continental PS78111 Compact Refrigerator
Does anyone have a easy method for refilling lotion dispensers? Trying to pour lotion into a dispenser, I have been using a funnel. It's a very slow process.
You can try using pouring the lotion first in an icing bag then squeeze it into the lotion dispenser. If you don't have an icing bag use a sandwich bag or any plastic. Just cut a hole in the bag.
Jun 26, 2011 | Health & Beauty
I have a GE Profile refrigerator, Model PFSS6PKWBSS, with icemaker on door. Water is collecting under Deli-draw and leaking down freezer door onto floor. How do I fix leak?
Hi
Try and access the ice dispenser assembly and check from where the water is leaking. You would need to disassemble the ice dispenser and ice maker to check this. The ice dispenser is located in the upper portion of the freezer compartment. This assembly stores ice made by the icemaker and dispenses ice on demand from the door dispenser target switch.
1. Remove the upper ice bucket tray.
2. Slide out the ice dispenser assembly.
3. Remove the ice cube solenoid linkage Phillips head screw and slide the linkage back.
4. Remove the ice crusher cover Phillips head screws (2) and remove the cover.
5. With a pair of pliers, twist off the backing plate tabs located on either side of the crusher.
6. With 2 small flat-blade screwdrivers, unlock the ice crusher locking tabs located at either side of the ice crusher.
7. Lift the ice crusher out of the bucket.
8. Remove the ice crusher back cover.
9. Remove the locking ring from the ice crusher auger.
10. Remove the plastic nut with a pair of pliers by turning it clockwise.
11. Remove the spacers and blades. The blades are numbered for reassembly.
Icemaker--
The icemaker is located in the upper rear of the freezer compartment and supplies ice to the dispenser tub.
1. Disconnect the icemaker cable connector.
2. Remove 1/4-in. icemaker mounting screws and slide out the icemaker.
This refrigerator is equipped with an Electronic Icemaker.
Hope this helps... Please post back if you need more information.
Daniel
May 01, 2011 | Refrigerators
Have a HOTPOINT CTX18GI fridge. Automatic icemaker doesn't work, but don't know if it's the actual ice maker or any of the switches. Water is going to the line from the sink plumbing via a standard small...
Have you tried raising the arm of the ice maker and leaving it for awhile then push it back down and see if it will work? Should be a cover that is over the plug take the cover off and unplug the ice maker, shouldn't be that hard to take off. I believe you have to squeeze the top and bottom together to remove it but Im not positive.
Nov 09, 2009 | Hotpoint 18.2 cu. ft. Top Freezer No-Frost...
My icemaker comes unloose
Sounds like the scew or the screw hole in the revolving rod is stripped allowing it to come loose.
If either is stripped, replace it. It may be a good idea to replace both, because if onwe is stripped, the threads of the other are probably not to great either.
Dec 28, 2008 | Sub-Zero 695/O Side by Side Refrigerator
Ice maker leaks water into Ice bend. When it cycles I can watch it drip water from the ice maker.
not familuar with the brand but sounds like one of 2 issues
if it is overfilling making ice cubes larger than normal, adjust the ice maker fill time if it is possible
icemaker fills and cuts off but water valve seeps water after the fill causing the water overfill
one of the 2
Jun 23, 2008 | U-Line Icemaker
Kitchen Aid indoor ice maker
hi there,
i would recommend a technician to help you with this. this part that fell out is from the motor head off the icemaker. have the technician put it back together and make sure that there is nothing else loose.
Jun 14, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Whirlpool ed2fhexnq00 icemaker will not dispense filled with ice
can you see the ice maker's white cover?? try to pry that off , usually a little space for a ***** driver to be inserted into where the body of ice maker and the cover meet in lower right corner. after removing check the gear in center of ice machine. there should be 2 little tabs that hold that gear on." picture trying to snap that gear on , the tabs would hold it in place" do those tabs appear tobe broken?? at least one anyway(although small ther should be a distinct space between the tabs where they sprung back into place) if theyre broken, theres your problem you need to replace the ice maker assy,(entire unit)
Mar 13, 2008 | Whirlpool GD2SHGX Refrigerator
Samsung RF197ABRS Bottom Freezer French Door Refrigerator Logo
1,700 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
