Question about Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune will not start.
I put too large of a load in the Maytag Neptune and it will not start. I have unplugged it and checked our circuit breaker in the house. The circuit breaker is okay. I may have burnt out the wall outlet. Not sure. Turned it off for a while and will try again later. Any recommendations?
  • 526 Answers
""The circuit breaker is okay."" that is a good 1st check.
""I may have burnt out the wall outlet. "" Plug a 120VAC device to the washer outlet and see if it works. Why do you think you burnt out/damaged the outlet?
""Turned it off for a while and will try again later."" When you power up the washer do you have any Console indications that the machine is on. I will assume your machine is a FAV6800A TL. Do you have any LED display indicators turned on?
That is all I can help with for now. I'm a technical owner of the FAV6800A machine and will try t help if uour machine is a FAV6800A or FAV9800A.
Most important what is the model number of your machine. This forum fails big time to ask members for Model# and Serial # of their machine.
Here is the Service Manual for the FAV6800A/FAV9800A
Rich
Posted on May 30, 2010
My maytag neptune front load washer wont start the cycle
you do know that this is the washer that put maytag out of bussiness,if you're having problems with it i wouldn't put a dime into it,replace it.
Aug 02, 2014 | Maytag Neptune MAH5500B Front Load Washer
Is neptune maytag washer belt driven
yes,you need to remove the 12 x 12 inch access panel in the rear of the machine and the belt has to be put on the smaller motor pulley first and forced on by rotating the large pulley around to work it on as there is no adjustment be careful not to pinch your fingers putting it on
Jan 16, 2011 | Maytag Neptune MAH5500B Front Load Washer
The washer will not complete the wash cycle. Lr
http://www.servicematters.com/maytag_library/docs/TDL-0044B-B.pdf
If all else fails, replace motor control board, and/or motor.
Jul 09, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washer trips circuit breaker during spin cycle
try unplugging the motor then put onto spin it will pump out ok and run othewise spin if all else is fine ,next reconnect the motor if it trips again then motor ' fault; repair /replace.
Apr 08, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag front loader washer--door won't open but lock light off
Open the soap dispenser. Look down in front of the fabric softener dish.
You should see a yellowy-green plastic cord (like weed-whacker line). Pull it.
The door should open.
If you don't see the cord, remove the four screws that hold the dispenser lid in place to find it. Just don't lose it when you put the cover back on.
Mar 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Front load washer poured water from bottom
Check for loose hoses or broken connection underneath washer .Unplug machines first before opening up the bottom
Dec 28, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Maytag neptune model# mah5500b
Unplug from the outlet and wait about 5-10 minutes. When you put the plug back into the outlet, the door should unlock.
Aug 23, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Wont do anything
It is a long shot, but better than nothing...unplug your unit for a full two minutes (recommended by manufacturer's owners manual). This will allow any stored energy in the circuit board to dissipate and may allow your circuit board to "reset" when you plug it back in. Then give it a try.
Dec 15, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
141 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
