Question about Archos 704 WiFi Digital Media Player
Archos 704wifi not starting up
I press start button and i get the green and yellow Archos logo and thats all. The HDD indicator lights up, flickers on and off then stays on.When placed in the DVR station the charge indicator is not on, but the logo is still on screen.Have tried implementing the system recovery, but still shows green logo all the time. Have tried the master reset function behind the battery but still showing the green archos logo all the time. I can hear the hard drive working inside, but still only the logo on screen at all times. The Archos was working o.k. no problems until i stopped midway in a film and turned it off and now cannot get it started. Help....
    Genius:
  • 1,142 Answers
Specify the model and the make
Posted on Apr 09, 2008
  • 1 more comment
  • Maanita Chadha
    Maanita Chadha Apr 09, 2008
    First take a look if your battery is fully charged.
    You can also make a long press on the on/off button for 15 seconds; it will switch off the unit and your data will be not erased
    If your device continues to stop and freeze, you have the
    possibility to format it from the settings menu; you can do this into
    settings, then select system and repair and format tools.
    Before doing this, you have to save all your files on your computer
  • Maanita Chadha
    Recovery mode, and this menu allows you to:
    -Format your hard drive
    -Restore your system
    In case of repair disk is selected :
    For the first step you have to go on our website, and download the latest firmware update for your product.
    Plug your Archos 604 Wifi on the computer and copy the firmware previously downloaded at the root of your device.
    Disconnect your device as usual, and select done on the screen.
    You have to plug the dc adaptor to update successfully, press a button to reboot your device
  • Maanita Chadha
    Download the firmware from the Website.
    Connect the device to the PC.
    Go in “My Computer”, you should see “Archos 604 WiFi”.
    Copy/Paste the firmware downloaded on “Archos 604 WiFi”
    Disconnect the device safely.
    Go to Setup > System > Update Firmware.
    You can also copy the firmware update file to the root of the
    device, and select while browsing the hard drive content with the
    “Browser”.
    http://www.archos.com/home.html?country=...
I need to reset factory settings, forgot all passwords
To access Recovery mode on the Archos 97:
1. Hold down the Home button and press the ON/OFF button.
2. Once the Archos boot logo is displayed, release the Home button.
The ANDROID green robot is displayed.
3. Once the ANDROID green robot is displayed, press simultaneously the volume button + and the ON/OFF button.
The Android system recovery screen is displayed.
a. Use the volume buttons to navigate
b. Use the ON/OFF button to select an option
To restore the default parameters of your tablet:
1. In the Android system recovery, select Wipe data/factory reset;
2. Select Yes -delete all user data.
3. Select Reboot system now.
Your tablet reboots. Redefine your parameters through the wizard.
Your tablet is restored to its default settings.
Aug 24, 2013 | Archos 16GB 97 Carbon 9.7" Tablet
Archos 704
Did you try power cycling the unit?
Feb 05, 2008 | Archos 704 WiFi Digital Media Player
The unit appears to be dead but the green and yellow channel LED's continuously flicker.
I am guessing that the lights are near the network cable plug? This simply shows that there is a signal on the network cable that is plugged-in. The laptop may be dead. Is there a light on the power supply? If you remove the battery, plug the power in and press the power button, what happens?
Dec 15, 2012 | Computers & Internet
Canon pixma ip4200 green & yellow light blinks 12 times and cannot print. what am I to do? pc connected, cable connect.
You might need to reset your printer so it can work again. please follow the steps below. It is important to familiarize yourself to the steps before doing it.
Here it is.
With the printer plugged in and powered off, press and hold the Resume/Cancel button, then press and hold the Power button.
Do not release the buttons. The LED light should be green to indicate that a function is selectable
While holding the Power button, release the Resume/Cancel button, do not release the Power button
While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.
When the LED light is green, press the Resume/Cancel button 4 times. Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.
Press the Power button. The LED lights in green, and the reset is performed.
When the operation completes, the printer returns to the menu selection mode automatically
Press the power button to exit service mode.
Hope this helps.
Apr 24, 2011 | Canon Office Equipment & Supplies
My archos is showing recovery code 101
It is indicating that there is a hard drive fault. Here is another users suggested method to clear the fault.
Following some extensive use I switched it on one day to find that it hung on the Archos home screen and kept going in a loop. Luckily I could see the red HDD light flickering so knew that the Archos was trying to do something and that the HDD was recoverable. When I entered into the recovery mode I found that I had an recovery code (101) which indicates a HDD fault.
I used the following steps to recover the HDD:-
1. Connect the archos to the PC using the USB cable (the unit will start but will need to be shut down again by pressing the power button)
2. Press the power button and the 'lock' button together for a few seconds and you should get a basic recovery screen
3. Scroll down to repair disk and select
4. Click on done and wait for a few seconds and you will see the archos as a drive in 'My Computer' (Note that this does take a few minutes)
5. You now need to back up your data, movies, music, widgets etc as the next step is to format the Archos HDD which will wipe it all.
6. Disconnect the Archos, turn it off and then turn it back on again by pressing the power and 'lock' buttons together.
7. Scroll down to format disk and select. The Archos will now delete all files on the HDD and you will get a message asking to connect to a PC and install the update file. This is the firmware file that can be obtained from the Archos website. You'll also notice that the recovery code has changed from 101 to 108
8. Connect the Archos to the PC, wait for a few seconds and you will see the archos as a drive in 'My Computer' again.
9. Drag the firmware update file from your PC where you've downloaded it to directly on to the root drive
10. Click 'done' on the Archos and it will begin to update the operating system.
11. Once this is complete then there should be an update successful message, select done and the archos should restart giving you the nice bubble screen and asking if you want to enable USB.
12. Note that the Archos is now in a 'factory built' condition so you'll need to adjust settings etc according to your preferences.
13. You can now start the long process of transferring your files back to the Archos.
Jan 12, 2010 | Archos Internet Media Tablet MP3 Player
Archos 604 will not restart
i had this problem recently when charging on the DVR docking station, i switched it off, took the battery off, left it for a shirt time then pressed the reset, it took a few attempts but eventually it restarted
Aug 09, 2008 | Archos 604 Digital Media Player
Archos 404 does not work at all since using Archos Docking Adaptor
You should try to only chare your Archos only when it is completely dead and charge it fully then the battery will be regular
May 02, 2008 | Archos 404 Digital Media Player
Archos 704 wifi not starting up
If you enter recovery mode then connect to a computer, you can then use windows drive checker to verify the drive. If all is OK, copy firmware to the root then disconnect and reboot
Apr 09, 2008 | Archos 704 WiFi Digital Media Player
Canon Pixma Printer trouble
hi dear
try with this metode
Waste Ink Counter Reset. Manual for Service mode
1. Turn off the printer. And disconnect the printer cable.
2. Press and hold the POWER button, turn on the printer.
3. The indicator (L.E.D.) should be green.
4. Press and release the RESUME button , the indicator (L.E.D.)
should be orange.
5. Press and release the RESUME button again, the indicator
6. Release both buttons
oke try to print
thanks
cropp
Mar 17, 2008 | Canon PIXMA iP1600 Printer
MY ARCHOS PLAYER WONT WORK
Just watching a movie and my archos just froze in mid play , did a switch off to rest it and guess what it wont restart , ses ARCHOS in green at the start but wont reeboot have tried the reset button inside but no joy what so ever , any tips or advice 'or shall i just ship it back to Archos ....
Jan 05, 2008 | Archos 605 WiFi Digital Media Player
Archos 704 WiFi Digital Media Player Logo
129 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
Jim Goldsmith
Jim Goldsmith
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
