Question about EliteGroup P4M800-M7 Motherboard
Computer restarts constantly - hard drive tests show it is good. Constantly getting various stop errors, etc.
    Scholar:
  • 77 Answers
Thank you for your question.
In this instance is difficult to give a clear answer as there could be numerous problems to correct. I will list some from my experience that may give you somewhere to start.
1. Type the stop errors you mentioned into "Google" with the word "meaning" and this may give you some explanations what the codes mean.
2, Overheating - Check the fins of the CPU heatsink for dust build up, clean/clear carefully with a soft paint brush or use an air duster.
2. Check the all connections on the motherboard are "seated" properly, with the power off and the power cord removed from the system.
3. Run a "free test" on the Computer at a site such as PC Pit Stop. Follow the link and select the "Overdrive" option, it will lead you to the free test section.
4. Depending on how long the Operating System has been in place, it may be overloaded with "rubbish" from general operations, you may need to consider a "reformat" of the Hard Drive and a clean install of the Operating System.
These are some opening suggestions, good luck with it.
Kind regards
Could you please take a moment to vote, it helps to know that I am on the right track with my answers.
Posted on May 30, 2010
  • Kevin
    Kevin May 31, 2010
    My apologies, the link is
    http://www.pcpitstop.com/betapit/default...
    Go to the "getting started" paragraph towards the bottom of the page, sign in "anonymously" no need to create an account, unless you wish to do so.
  • Kevin
    Kevin May 31, 2010
    PS: Thanks for voting, appreciated.
    Scholar:
  • 119 Answers
Sometimes this can be caused by an overheating situation. Itunes, RealPlayer, Windows Media player, etc. require a lot of processing power to decompress and decode music files, which can cause the processor or hard drive to get hot.
If your CPU is running at over 60 degrees. You might be at risk of burning it out. Some systems shut down automatically when the temperature reaches an unsafe level. Every few weeks I open my system unit and clean the fins on the heat sink that sits under the CPU. When they collect dust it restricts the airflow and prevents proper cooling. You can use a can of compressed air (look at your local office supply store) or an old toothbrush. I just did that on my system and the CPU temperature dropped by ten degrees!
Posted on May 31, 2010
My G5 freezes constantly. What can I do.
Try running Apple Hardware Test on the machine (it's one of the discs that came with the machine.) Also, if it's freezing by showing the spinning rainbow cursor (beachballing) you may have a failing hard drive. That wouldn't be uncommon for how old the machine is.
Feb 24, 2015 | Apple PowerMac G5 Dual Mac Desktop
Why is my computer screen (win7) constantly jumping?
you have a virus maybe a trojan, replace hard drive & reinstall windows
Nov 12, 2014 | Computers & Internet
Hard drive clicking and computer constantly rebooting, will back up CDs or reinstalling BIOS work?
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical extension or fan lead can cause you problems
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU make sure its securely seated and has thermal grease might be getting to hot
another possible reason could be a memory dump you might be running to many programs at the one time putting to much strain on the CPU central processing unit
hope this helps you
Mar 07, 2012 | Computers & Internet
Gateway nv7915u error message i'm getting is pxe-e61 media test failure check cable pxe-m0f exiting broadcom pxe rom no bootable device--insert boot disk and press any key but when i do that nothing...
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty.First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Next - to check if the harddrive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an USB mass storage device and you cannot open the various folders and fileson this drive, then this confirms the hard drive is faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Nov 04, 2011 | Gateway NV7915u Notebook
I tried to download windows 7 on my ACER 5351, and near the end the laptop restarted. It came up with this error code : Cannot boot from CD: Code 5. When I took the CD out, the following error code...
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty. Next - to check if the harddrive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an external hard drive and you cannot open the various folders and files,this confirms the hard drive is faulty. Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Aug 11, 2011 | Computers & Internet
Gateway 450rog computer constantly restarts
remove all other devices hooked to your pc except for the basics, mouse and keyboard. then try the last known good configuration. press F8 before it boots to windows then choose known good configuration.
Mar 31, 2010 | Gateway 450ROG Notebook
Problem in startup
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty.
First - re-seat the hard disk and reboot the computer. If this does not work then reboot and go to the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Next - to determine if the hard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a working computer's USB port. If this computer cannot see it as an external hard drive and you cannot open the various folders and files, this confirms the hard drive is faulty.
The hard drive needs to be replaces in the laptop and Windows installed and the laptop's device drivers and your programs etc to get a working laptop again.
Dec 26, 2009 | IBM ThinkPad R51 Notebook
My ibm thinkpad r51 is not starting up just keeping giving me error message and it doesn't recognize the hard drive in boot. I have to take the battery to stop the system trying restart the window again...
It appears the hard drive is faulty.
Does the hard disk LED flash when the laptop boots up?
Go into the BIOS configuration and see it the hard drive is detected, (then Startup - Boot - and look at IDE HDD0 it should list the make and model of the hard drive).
If the hard disk is detected it still could be faulty. To test the hard drive, remove the hard drive and connect it to an USB hard drive adapter and connect it to a working computer's USB port.
If the computer sees this as an external hard drive and you can open the various folders and files then the hard drive is OK and the fault could be the disk controller on the laptop's motherboard.
If the hard disk is not detected the it is faulty and you need to replace the hard drive in the laptop and install Windows etc. to get it working again.
Jul 15, 2009 | IBM ThinkPad R51 Notebook
Disk read error, please help
If it was dropped on the floor, more than likely, that spinning hard drive is damaged and has failed. The computer caqnnot load the operating system. You will definitely have to replace the hard drive, and hope the data is recoverable. Keep in the mind, the hard drive is constantly spinning, and any shock at 30G's or more can be fatal.
Picture moving a turntable while its playing, accept, instead of spinning at 33.3 rpm's its spinning at 5400 rpms, faster than most car engines......
Good luck.
Dec 16, 2007 | IBM ThinkPad T43 Notebook
Mac does not recognize...
Haskel, Have you tried a different USB wire? Constantly remove of the cord can wear down the contacts/something is on the contacts? Check that I'll get back to you if I find anything relevant. Good Luck, Tim
Feb 07, 2007 | SimpleTech SimpleDrive Portable USB 2.0...
Open Questions:
See all EliteGroup P4M800-M7 Motherboard Questions
EliteGroup P4M800-M7 Motherboard Logo
170 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
