Question about Viking 48 in Built In Professional Integrated Side by Side Refrigerator - VISB483SS
FRZ Temp lights, all of 9 bars on Controll Panels are flashing
I have Viking Pro (VCS483SS). The refrigerator is working well now, but temperature lights (9 bars on left side of controll panels) keep flashing after I touched something. I can't control temperatures lower or higher. I tried to power the refrigerator off and on then, but all 9 bars are still flashing and higher/lower temp buttons are not working. How do I reset the control panels?
  • 14 Answers
SOURCE: Fridge not cooling down
The most likely cause is a gas leak . Call a technician.
Posted on Jan 24, 2008
SOURCE: all lights went out in my refrigerator/freezer
I have this side by side Viking- The worst product I ever bought. Nothing but problems. If I can give anyone advise do not buy one.
Posted on Mar 10, 2008
Kgt1962
  • 59 Answers
SOURCE: I have a side by side Viking refrigerator and
Remove the center grill of the top grill and shut the power off and back on, the lights should reset
When the lights are working open the Ref door then close the freezer drawer, watching to see if the light in the freezer shuts off. It should shut off when the freezer is about 1" from closing. If it stays on until the door is fully closed then there is a problem with the light switch in the freezer.
Normally when you leave the doors open until the lights shut off, it should reset when both doors are closed
Posted on Mar 27, 2009
  • 13 Answers
SOURCE: Viking Wine Cellar Temperature Near-Freezing
Viking wine coolers are made by Marvel.They all had issues with freezing the contents. If you replace the electronic cold control system it will be fine.If you don't, it will freeze the wine popping the corks and leaking in the unit.If you get the parts from Marvell they are much cheaper.
Posted on Jun 01, 2010
  • 44 Answers
SOURCE: viking side by side makes very little ice
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Posted on Jun 06, 2010
How do we raise the temperature in our fridge and freezer?
Well, you didn't leave a model number, so I'll just give you the generic answer: If you keep pressing the Frz or Ref temp buttons, the temperature will cycle down to the lower limit and then pop back up to the upper limit and then repeat all over again. If not, look for up/down buttons, or +/- buttons.
Oct 21, 2014 | Refrigerators
"high alarm" freezer not freezing
Check condenser coil to make sure it is not clogged with dust and lint . Make sure condenser fan is operating. Hope this helps.
Dec 24, 2013 | Refrigerators
Refrigerator temperature light is flashing
Replace the temperature sensor. Here is the part to order.
The sensor is located on the coils in the freezer.
Nov 24, 2012 | Samsung RS2556 Side by Side Refrigerator
Temp on upper is getting colder while freezer on bottom is getting warmer
Sounds like bad settings. Sometimes, the temp setting(sensed in ref area) controls runtime, and the frz setting adjusts a vent whuch passes air from frz to ref area. try raising frz setting.
Nov 21, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My 7 year old GE Profile Side by Side will not get
Self Diagnostics
To enter Self Diagnostic mode, both temperature control panel displays must be illuminated. A display
can be illuminated by pressing an adjacent temperature adjustment button. When both displays are
illuminated, set the freezer and refrigerator temperature settings to 5. Simultaneously press and hold all
4 temperature adjustment buttons for approximately 3 seconds. A flashing 0 in the refrigerator and
freezer displays will indicate that the refrigerator is in Self Diagnostic mode.
For temperature control panels with single-digit displays, the COLDER temperature adjustment button
will increment the numbers up and the WARMER temperature adjustment button will increment the
numbers down. Use the freezer temperature adjustment buttons to enter the test code number in the
freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in
the refrigerator display. When a test code has been entered, the displays will flash to confirm the test.
Press the HOLD button for 3 seconds to begin the test.
For temperature control panels with 3-digit displays, the COLDER temperature adjustment button will
increment the numbers down and the WARMER temperature adjustment button will increment the
numbers up. Use the freezer temperature adjustment buttons to enter the test code number in the
freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test
code. Press any button other than a temperature adjust button to begin the test.
When testing has been completed, do one of the following things:
• Enter code 1 5 to completely reset the system.
• Enter code 1 6 to exit diagnostic mode. GSS manual
May 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Oven doesn't heat up to the right temp--lower oven Viking Pro
Adjust the knob to the actual temperature. There are usually screws inside toe back of the knob for this purpose.
Mar 23, 2009 | Viking DEDO205 Stainless Steel Electric...
Viking VCBB362
Press Display on
then press and hold Max Frz and Display off, you should hear 3 beeps and the compressor should start.
It may also be that when you turned the unit off you hit the showroom switch that is located up behind the top grill, the power off switch is also in here.
The easy way to tell the difference is see which one turns the lights off, the showroom switch will not affect the lights.
With the lights on switch the other switch and leave it for 6 mins to see if the compressor, if not repeat.
Dec 29, 2008 | Viking DDBB363 Bottom Freezer Refrigerator
Viking 48 in Built In Professional Integrated Side by Side Refrigerator - VISB483SS Logo
203 people viewed this question
Top Viking Refrigerators Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Audie Bogus
Audie Bogus
Level 1 Expert
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
