Question about Sta Rite STA-RITE CONTROL BOARD KIT - 42001-0096S
Sta-Rite Pool heater does not fire up. Error E01 displayed.
I have a Sta-Rite pool heater Model SR400LP with an error code of E01. Does anyone know what this code is indicating? Heater does not fire up after winter layup. Checked for obvious "winter" problems, (mice, wetness, etc.), but everything looks good. Need Diagnostic type manual or error code list or some point to start diagnosing.
    Top Expert:
  • Sta Rite Master
  • 5,080 Answers
Possible mice nest under top or ignitor bad
Posted on Oct 11, 2017
PartsCenter
  • 125 Answers
SOURCE: Pool heater not working
sounds like it is not getting enough water flow. Check to see that there is water going out of the heater. Here is a site you can check trouble shooting guide.
Posted on Feb 26, 2009
SOURCE: Sta-Rite SR400 heater displays error E01 and doesn't fire.
Resolved - the thermister was bad.
Posted on Jan 02, 2009
  • 83 Answers
SOURCE: pool heater
If the heater fails to ignite after three attempts, the heater will automatically go into Lock Out. This is a safety feature on the heater.
Things for you to look at to see what is causing the problem are the display panel and diagnostic lights. When you turn on the heater, is it reading the correct water temp? If not, the Thermister has gone bad and will need to be replaced. When you try to start the heater, is there an Error Code displayed? Which of the Service Lights are coming on when the heater will not light? If it is the Serivce System, that is usually low flow of water. You may have a dirty filter, skimmer or pump basket full of debris, or a valve not completely open.
If the Service System light is the one coming on, then you will need to take off the top two halves of the heater and turn over the Display Panel. There are diagnostic lights on the back side of the panel. There may be a red light next to any of the following:
AGS, AFS, SFS, HLS, PS or THERMISTOR
If there is a red light next to one of these, then that is what has malfunctioned. If you need an Owner's Manual for the heater, you can find one online at the following link:
http://www.inyopools.com/owners_manual/sta-rite_heaters_max-e-therm.pdf
Posted on Jul 08, 2009
  • 83 Answers
SOURCE: Sta-rite heater error code 126
The 126 is not an error code, but it maybe the temp of the water that the heater is reading. If the heater thinks the water is 126 degrees, it will not start at all.
If the heater is reading the wrong water temp, the problem is the Thermister, which is the sensor that is suppose to read the water temp. You will need to replace this sensor in order to correct the problem with the heater. It is really easy to do!
If you have a manual for the heater, if you go to the Replacement Parts Listing for the Electrical System, page 53 in the online version, the Thermistor is Item #9. It goes into the left side of the manifold in the to place, between the first two manifold bolts.
Posted on Jul 10, 2009
  • 83 Answers
SOURCE: sta rite 400na gives error code 05 after about 30 seconds
I am not sure if you have received an answer to the issue, or not, but just in case! An EO5 error code is an open stack flue sensor, or switch, There are two forms of the stack flue sensor, so you will need to know which one you have on the heater.
What this error code means is that the sensor "read" the flue temp to be over 500 degrees. Usually, it is just gone bad and reading the wrong temp.
Posted on Jul 14, 2009
Starite sr400lp runs fine no errors, however water to pool is not hot, or barely warm
soulds like maual bypass is stuck letting too much water flow through heater and doesnt have enough time to heat it the spring is probably stuck
May 11, 2014 | Pool & Spa
Starite sr400lp runs fine ,no errors however water to pool is not hot or even barely warm
With heater running put your hand by the exhaust and see if the air being expelled is hot. It will be if heater is producing heat. Depending on the size of the pool this heater can take some time to heat the water.
Capacitor needed
I don't know what capacitor you need but if it is part of the Sta Rite heater then I would call Sta Rite technical support at 888-782-7483 and they could likely help you come to a resolution.
Please let me know how this works out. Thank you.
Sep 02, 2011 | Sta Rite SR400LP Max E Therm Pool Spa...
What does R8 code mean on sta rite pool heater
These pool heaters have a very detailed and specific troubleshooting manual that will probably be the most helpful thing for you. They ask very specific questions about what appears on your heater and you will need to be looking at it to troubleshoot. Try walking through the troubleshooting guide below.
http://www.backyardcitypools.com/images/bwp/Max-E-Therm-Manual.pdf
Jun 24, 2010 | Sta Rite SR400LP Max E Therm Pool Spa...
What does R* mean
Where is this "R" if it is the one in the model SR400LP That is Rite, SR Sta-Rite, 400 is btu's in thousands, LP is liquid petrouliem or propane.
Shows r 5 code when power is turned on. sta-rite
The R5 is a sequence code in the boot up sequence where your error is occuring. There is nothing in the users manual for these pool heaters that explains this error. Your best bet, unfortunately, is going to be to call Sta Rite. Here is their customer service number: 1-800-831-7133
May 08, 2010 | Sta Rite Sr400na Max E Therm Pool & Spa...
Sta rite 400na gives error code 05 after about 30 seconds
Jun 14, 2009 | Sta Rite Sta-Rite Max-E-Therm High...
E01 fault and service light on
If you are still seeing the EO1 error code, turn over the display panel and see if there is a RED light next to a set of letters. Whatever the light is next to, that would be the cause of the error code.
Jun 08, 2009 | Sta Rite Maxi Therm 400k Btu Propane...
Sta Rite STA-RITE CONTROL BOARD KIT - 42001-0096S Logo
437 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
steve morris
steve morris
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
