Question about ASUS Terminator P4 PC Desktop
My Computer, Asus was can't started to Windows ,
My Computer, Asus was can't started to Windows , I repair it by Clean the Motherboard and other system and it can, but one month later, it can't started to Windows again. What is the best solution for repair My Computer?
  • 570 Answers
Please save your backup if you can and then format your computer.After formatting your computer please install a good anti virus
Thanks.
Posted on May 30, 2010
I have a asus motherboard it restarts on starting windows screen I've tried to boot in safe mode that doesn't work
That means there is a problem in the booting environment of the system. This usually results from a virus attack that changes the booting environment. The best way to go around this problem is to slave the hard drive to another desktop computer, access it and make a data backup. By slaving the hard drive i mean, connecting it to a working computer but do not let that computer to boot from your hard drive because it can not. Boot form the working computer so that you can be able to see your hard drive in the 'my Computer" menu as drive E of D or F depending on how many partitions are available.
After making a backup, take it back to youe ASUS motherboard and perform a clean installation of an operating system. This should fix the restarting problem.
Mar 25, 2012 | ASUS Computers & Internet
Error code:6006
Welcome to fixya. If the computer is still booting to windows and can access the internet,you just have to download the 6006 repair tool and here is the link
Download Error 6006 Repair Tool.
If it did not resolve the issue or your computer wont be able to boot to windows normally or cant access the internet anymore,you have to contact ASUS for a repair technician.
Hope this helps.:)
Sep 11, 2011 | ASUS P5PE-VM Motherboard
Driver vga for windows seven fror motherboard Asus a7v400-MX SE Thank you.
Hi.I only inform you that asus a7v400-mx motherboard have no support for windows 7 version.only windows xp below. to get all driver just click this link http://support.asus.com/download.aspx?SLanguage=en-us&m=a7v400-mx+se
Jun 03, 2011 | ASUS A7V400-MX Motherboard
Ihave ASUS M2N68-AMSE2 nmotherboard- on starting up, my computer shows ASUS green screen for ages and nothing happens, I press reststart, motherboard boots up and starts windows
hardware related issue, check your bios settings to see if halt on errors in enabled, also disable
the ASUS splash screen, you should be able to see the initial boot error..
Feb 19, 2011 | ASUS M2N68-AM SE2 Motherboard
Motherboard does not BOOT to windows
If you are running anything from windows XP upwards inc Vista
then you must re-install the operating system when you change the motherboard.
From your description that is the problem you are encountering.
You could place your windows disc in the cd rive and tell the computer to boot from that and try a "repair install"
If successful you will loose no date but will be asked to re-register with microsoft.
If your windows disk is original and not meant for an OEM computer that will not be a problem
Aug 30, 2009 | ASUS P5N7A-VM Motherboard
Help!!!!! I can't login to windows :@
Inset and boot from windows CD after all drivers etc loaded asks what you want to do Install repair etc
Press R for repair and follow instructions you should not lose files but ir should enable you to start computer
Oct 05, 2008 | ASUS P5B-E Motherboard
Not installing windows xp with asus k8v-mx motherboard
Sounds stupid but I have seen it happen. Make sure the cd in the first in the boot sequence in the set up. If that dont work make your c drive first. Give it a shot, may work..I love asus
Sep 23, 2008 | ASUS K8V-MX Motherboard
ASUS motherboard ap5pl2-E driver
sometimes, driver CDs get damaged. But don worry, all you need to do is 1st try to clean the CD with a clean cloth wet wit tap water and clean it again with a dry cloth. If still your PC can't read from the CD, try downloading the drivers directly from the Manufacturer's website.
Hope this helps.
Apr 18, 2008 | ASUS P5PL2 Motherboard
Once installed Asus A8N SLi will not boot up in Vista 64 bit
Link: http://support.asus.com/download/download.aspx?SLanguage=en-us
Make sure that you have the lastest Firmware installed in your BIOS.
Also run Windows Vista Upgrade Wizard before installing Vista to check for compatability.
Note: Vote for me......
Jan 27, 2008 | ASUS A8N-SLI Motherboard
Mobo will not boot system
I think the main problem with this is that there has been a significant enough hardware change for Windows to deny booting up. You should always back up on the previous pc, reformat and expect to have to do a clean installation and re activate Windows. Did you check in the bios that the time, date and HDD settings are correct. There may also be a driver conflict as the old motherboard drivers etc will still be on the HDD. Try this also My computer>properties>advanced tab>Start up and recovery settings, then on System Failure make sure Automatically Re-Start is unticked, as this should then bring up on your next boot a BSOD giving you a clue as to the problem. Keep trying
Nov 03, 2006 | ASUS P5LD2-VM Motherboard
ASUS Terminator P4 PC Desktop Logo
74 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
