Question about Krups Espresso Novo 2000
Krups Novo 2000 ~ water isn't flowing. I bought this used at a yard sale, and I must say it looks as tho it was hardly used at all. Today I plugged it in, turned the power switch to on until the temp light turned off (as instructed via manual). Then flipped the flow switch on. Nothing. I let it run for a few minutes (maybe 2-3) and there was alot of vibration but no coffee. No steam either. It doesn't look corroded nor even used enough to be corroded. Vibrates like crazy (i've read that is normal with this model). Any suggestions? Thank you in advance!
  • Krups Master
  • 1,280 Answers
If the pump is bone dry sometimes they refuse to pump. In the past I have found some soft tubing that will fit over the water inlet where the tank plugs in. I then fill the tube with water and pressurise it with my mouth while operating the pump. Often this is enough to prime the pump and start it pumping. The downside with a machine that old will probably be lack of new group head seals, you will probably find they are obsolete.
Posted on May 02, 2017
SOURCE: Krups 867 boiler steam leak
Save yourself the trouble, buy a $1.99 frother at Ikea.  Makes the cleaning process easy - that's what I use at home, never used the steam wand on my machine.
To use the frother, just heat up the milk and froth away.  Pretty easy.
Posted on Apr 04, 2008
  • 3 Answers
SOURCE: Krups Orchestro 889
the o ring of the upper and lower pistons should be replaced
Posted on Aug 10, 2008
prittykitty
SOURCE: krups cappuccino manual
Don't know if your still looking, but if you go in the customer service section of the Krups website (krups.com) and ask them for the manual they will email it to you. Or, email me and I can send it to you!
Posted on Nov 11, 2008
SOURCE: Water steams away and nothing drips into the caraffe
I had this problem too and finally found a fix for it.
I don't know if the cause of this issue is the same for everyone experiencing the problem, but the issue for me was hard water. The fix is to run vinegar mixed with water through the machine quite a few times, until it starts to run normally.
If you do have hard water issues, it's recommended that you run vinegar or citric acid through the machine about once a month, to keep deposits from building up.
Posted on Jan 27, 2009
  • 12 Answers
SOURCE: need a manual for a Krups Novo 3100 pro crema
You need to find the model number usually starts with FME.
Look on line at http://www.krupsonlinestore.com under customer service.
Posted on Nov 18, 2009
No coffee is coming through, I guess it needs descaling. How do I do this? Note my machine does not look like the one in the picture. It does have KP2000 on it though!
remove every thing filter holder ecc then try again do not do any descaling as yet you may block the system even more first get the water to flow and make sure you clean all the filters be for hand good luck
Feb 10, 2016 | Krups Espresso Novo 2000
XP2280. Where can I obtain an owner's manual?
Krups XP1500 Instructions ' eHow
www.ehow.com > Home
Krups XP1500 Instructions. The Krups XP1500 is a coffee machine and espressomaker with a 10-cup coffee capacity, pause and serve feature, non-stick ...
KRUPS XP1500 USER MANUAL Pdf Download. - ManualsLib
www.manualslib.com > ... > Coffee Maker > XP1500
Translate this page View and Download Krups XP1500 user manual online. Krups XP1500: User ... Coffee Maker Krups ESPRESSO COMBI XP1600 User Manual. (51 pages).
Krups 867 Instructions For Use Manual - ManualsLib
www.manualslib.com > Brands > Krups Manuals > Coffee Maker > 867
Coffee Maker KRUPS ESPRESSO NOVO 2100 PLUS Instructions For Use Manual ...Coffee Maker Krups XP1500 User Manual ... stronger brew than regular grammablecombination ber to NEVER open the coffee, espresso, and coffee.
Jun 20, 2012 | Krups XP Coffee Makers & Espresso Machines
I have an Krups Novo 4100 Programatic. The pressure builds up and is then released into the overflow tray. I can get it to work by running through the citric acid and cleaning the shower but only for...
Hi
In the filter carrier (the handle thing) is a small o ring. I think it keeps the filter pressurised which helps create crema. After a while the o ring gets pulled out of shape and doesn't let anything through. Remove the screw in the top filter, pull out the steel filter, the plastic disc under that (might need to pry it out) and you will see the mis-shaped o ring. You can get a replacement from an appliance repair place. I have just read today that you can also just leave it out - but you will need to tamp the coffee (squash it down) more. Hope this helps.
Nov 10, 2010 | Krups Espresso Novo 4000
No instructions with game. Bought at yard sale. No instructions were included. Can I download a set of instructions?
You can go to Hasbro's website and download game instructions. As of today (July 2012), I found Operation (2000), which looks just like the original, here: http://www.hasbro.com/common/instruct/Operation_(2000).pdf
Aug 14, 2010 | Milton Bradley Operation Skill Game
MASS AIR FLOW SENSOR? 1991 Dodge Stealth RT
Yeah sound like the Mass Airflow sensor (MAF). This is one of those items you really shouldn't get at a junk yard.
Apr 21, 2010 | 1991 Dodge Stealth
Same Problem - no water goes through in either mode
remove screw in centre of group head and remove valve and spring, clean and reinstall.
Sep 21, 2009 | Krups Espresso Novo 2100
I need a 2-cup filter
GOOGLE "2 cup filter for Krups espresso Novo 2100"and your problem will be solved.
Jan 29, 2009 | Krups Espresso Novo 2100
Krups Espresso Novo 2000 Logo
360 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
cyfred
Level 1 Expert
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
