Question about RCA HD61W66 61" Projection HDTV
Not turning on now
I have an rca hd61w66 and the convergence fuse blew because of broken solder joints on the flyback. i resoldered the flyback and replaced the fuse now when i turn it on there is a high pitched whinning noise and it turns itself on and off. no picture at all. green led on power button flashes like 1 then 6 or 7 flashes. any help ? thanks
  • RCA Master
  • 5,138 Answers
Shorted Hori output Transistor CK it.or a 2 leggit transistor behind FBT resolder around the Hori circuit theres a cap that has poor solder connection in that circuit that will cause it also.
Posted on May 30, 2010
My mom has a RCA HD61W66 and the picture was showing red, blue and green "lines and shadows" as if the picture was warped. It has now stopped showing a picture at all but the power is working....
The flyback transformer has solder cracks around the pins and most likely blown the FL231 Micro fuse to the right of the flyback.I would inspect the flybacks solder. The FL231 and the CL230 and DL231 should also be replaced ( near the flyback) You can get the ITC222 Convergence option missing repair kit from www.tvrepairworld.com under the RCA repair kits. The kit contains the parts and the CD with repair instructions
Sep 15, 2011 | RCA HD61W66 61" Projection HDTV
Convergency has gone out of sync, went to try to realign but the convergeny setting was not listed in the tools menu.
Thats usually caused by a blown FL231 Fuse and a blown DL231 diode that blow when the flyback transformer develops solder cracks around the pins. The repair is to first resolder the flyback then replace the FL231 fuse and DL231 diode. You can get the RCA / GE convergence option missing repair kit which has the parts and repair instructions from www.tvrepairworld.com
Jul 09, 2011 | RCA HD61W66 61" Projection HDTV
Rca bday61w66 convergence board removal
Different possibilities:
1. Bad hv circuit (flyback)
2. Bad connections on flyback & the little fuse next to it
3. Bad fuse near tuner
4. Bad picture tube
This tv is known to have any of these problems.
I believe the solution is: number 2.
I have had a few of these with burned up convergence boards, but it is rare. If you replace one, you must replace both if it has 2.
Check for rings around the flyback solder joints and the little brown fuse next to the flyback (3 are in a line).
Good Luck!
Apr 28, 2011 | RCA HD61W66 61" Projection HDTV
The fl231 fuse blew 3 days after i replaced it so problem is obviously steming from somewhere else. I keep seeing solder joints that need to be resoldered, can you elaborate.
The reason the fuse keeps blowing is because of bad solder joints on the flyback transformer,resolder all flyback cnnections and you should be good to go.
Jan 28, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My convergence keep going out, I replaced the convergence twice. I have a rca hd52w59 modle
When you say replaced the convergence twice, are you refering to the convergence boards or the FL231 fuse? If its the FL231 fuse unless you replaced the DL231 and CL230 plus reflowed the solder on the flyback it will continue to keep blowing untill the 3 parts are replaced together and the flyback gets resoldered. If you replaced the convergence boards then try resoldering the flyback.
Nov 27, 2009 | RCA HD52W59 HDTV Projection Television
I have a 3-yr old RCA HD61W66 projection TV that has a convergence problem. While watching the TV, there was a "flash" and the picture convergence went out resulting in a picture that was curved and had 3...
The cost about $300 parts and labors.U can do the repair ur self about $100,but require ordering the parts in the net.Must take the tv aparts.Have to desolder the parts,put in the parts correctly and resolder it.This website for the Net ordering parts.Tv Repair World.com.
Sep 08, 2009 | RCA HD61W66 61" Projection HDTV
R52wh77 3d raunbow picture and no convergence option in menu. Should I get a new TV?
there are 3 fuses in a row next to the flyback
transformer.solder all the pins on the flyback
and replace the middle fuse.check the other 2
fuses.this is very common with RCA.
Jul 18, 2009 | RCA HD61W66 61" Projection HDTV
Convergence problem hd61w66 problem #2
hello take the back off the tv look where the power lead plugs in to
you should be able to see a glass fuse get a mulitmeter and test it if you change the fuse and it blows again you have a dead short in the circuit good luck
shaun
May 14, 2009 | RCA HD61W66 61" Projection HDTV
I have an rca hd61w66 and the autoconvergence is not working. Is there anything that I can do or is there something that maybe I'm not doing?
If the convergence is way out fl231 is probably open (its a .4 amp fuse) the fuse goes bad because of the bad solder connections on the flyback. solder flyback connections and replace the fuse. the convergence should be back to normal.
Feb 02, 2009 | RCA HD61W66 61" Projection HDTV
Convergence nightmare
If this is a ITC222 chassis then you need to check the fuses that are near the flyback. I would also unsolder all the pins on the flyback and re-solder them as the factory lead free solder tends to crack and cause issues with the convergence. Re-solder it with common 60/40 solder you can pick up from Radio Shack or other places.
Jun 25, 2008 | RCA D52W19 52" Rear Projection Television
RCA HD61W66 61" Projection HDTV Logo
160 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
