Question about Sony STR-DE575 Receiver
Receiver shuts down after 5 to 10 minutes of operation
When the problem first started,I could tap it on top and the solenoid would trip turn it back on. Now it stays off for some time - perhaps because a faulty component needs to cool down to restore the circuit of which it is a part? Or not. This affects all inputs - not any particular one.
  • 86 Answers
Take a pair of pliers on make sure all capacitors or srtaight and not leaning to the side.
Posted on May 30, 2010
Excape no crank
Starter or Solenoid sounds like it is getting hot and shutting down,will it start back up after sitting for awhile to cool down?
Nov 11, 2013 | 2002 Ford Escape
1999 Dodge caravan, rattled a bit before i shut it off, now not starting, tried jump start but it's not even trying to turn over
Starter or solenoid. My neighbour the 'car whisperer' tapped mine with a hammer and it worked for a few more trips. It eventually died away from home.
Sep 29, 2012 | 1999 Dodge Caravan
My hotpont aqurius wml 560 has a problem once you have loaded the machine closed the door set your cycle press start the door locks and the led illuminate but nothing happens it normally starts to pump in...
g'day, sounds like the solenoids in the back aren't letting water in. The solenoids are what the hoses are hocked onto. They are like an electrical tap. These are not pumps, water is only pumped out of a washing machine. Some reasons why water is not coming in: - Taps are not turned on (Keep it simple), turn taps on. -Hot, or cold solenoids are not working. (Lets hope chances are only one has broken). Swap cycle options, try just hot, or just cold options. If one works and not the other, a solenoid is not working. just put either hot or cold on the solenoid that is working. Note, some new machines only have one hose at the back, this is because they heat the water internally - like dishwashers. If this is the case, a new solenoid can be purchased and installed. -Another reason might be that solenoids aren't getting power. This cold be because the trip switch in the door. A common problem. Think of the trip switch just like the light in the fridge. When door is opened, switch is opened. If u can test machine on spin cycle ie, the machine spins, then this is not the cause. Some appliances even have switches on soap draws so check that out aswell. hope this helps
Aug 07, 2011 | Washing Machines
Trips and switches off
Hello Fixya customer,
Thank you for your question.
The best way to fully isolate the fault is to disconnect all the speaker wires, and verify that there are no strands of wire shorting between the speaker terminals on the rear of the unit.
Turn the volume all the way down, full CCW, and if it goes into shut down with the STBY light blinking then there is a fault in one of the amplifier's.
Thank you for using Fixya, and if I can be of further assistance please ask.
May 01, 2010 | Onkyo TX-SR706 Receiver
Set keeps shutting down .this amplifier shuts down in about 30 seconds after turning it on
It could be that the amp's overload protection circuit is being triggered by a feedback loop or other problem, such as a shorted or bad cable connection. Turn off the power and unplug the receiver. Look for problems, starting with shorted speaker wires or cables. Then make sure the receiver's not still hot (wait 5-10 minutes to let it cool), and remove obstructions or anything blocking the top vents. Plug it back in and power up again. Immediately change the Source selector to something unconnected, and turn the Volume DOWN just in case there's a feedback loop (hum/squeal/noise that can overload things and cause the protection circuit to trip again). If you can see the display, go to a low level (around -50dB should be fine) before the delayed speaker amp output clicks on. Then carefully switch back to the problem source -- if that's the problem, switch off again immediately and re-check all of the cable connections at both ends, the receiver and the source component.
Make sure you don't have a feedback loop due to a recording device feeding back a signal. All VCRs and CD/DVD-recorders should be hooked up to the VCR, DVR or TAPE/CD-R "IN/OUT" jacks with IN being connected to the cables marked OUT on the deck and vice versa. (That confuses even us experienced guys sometimes!)
Also, no MONITOR video or audio outputs should be connected to the recording decks, nor should the TV outputs be fed back to the recorders. The same goes for the digital IN/OUT jacks for CD recorders; use only the same number IN as OUT for each component (For example, Optical IN/OUT #4 and #5 are the two digital IN/OUT pairs on the Denon AVR-380X series.)
Jan 28, 2010 | Yamaha HTR-5850 Receiver
A/C unit turned off- didnt realize we had a mat covering the unit
If the breaker had tripped, you'd detect some looseness in the trip switch, even though it may not appear to be tripped. Once you have identified the correct breaker, trip it to OFF and then back to ON. Also check at the unit; it will either have a service disconnect, a fused disconnect or a circuit breaker at the wall. Compressor units have a thermal relay that causes them to shut down on high temperature. Let the unit cool down thoroughly. If this is the issue, and you are standing close enough, you may hear it reset when it cools. Usually, cool down occurs in 30 minutes or less. Try it again, but don't leave it unattended until it has made it through several cycles and you are confident that the unit is back to nornal. If any further issues develop from this incident, shut the unit down, trip the circuit breaker for the unit to off and call a serviceperson.
I hope this gets you going again!
Best regards, W/D
Jul 11, 2009 | Amana Heating & Cooling
Charging the Tom Tom - unit shuts off with car charger plugged in
your rechargeable battery inside has a limited life and has to be replaced when this problem happens.
May 28, 2008 | Tomtom GO 510 GPS Receiver
Receiver shuts down after loud bang
You said Unit is enclosed!! Does that mean it is inside something? Receivers & Amps need to have a clearance above them so air can circulate, otherwise you'll have an overheating problem. You also might have some of your wires crossed which will cause the Amp to shut down. Look at all your connections and make sure they're correct, including speaker wires.
Sep 22, 2007 | Audio Players & Recorders
Sony STR-DE575 Receiver Logo
64 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
