Question about Jetway M1531S 15" Flat Panel LCD Monitor
Display only works intermittently, used as second monitor, might not have proper drivers.
  • mwhitcombb May 30, 2010
    I'm still having a problem with adding a second monitor to my setup, it's a Jetway a 15" monitor TFT Lcd monitor, and works only intermittently. I'm running windows xp with a nvidia geforce 7900 gs. by "intermittently" I mean the screen will flash on for half a second and then go black. I've been unable to use it as a default monitor, the same problem happens. Thanks!
    very helpful, thanks guys.
  • Jetway Master
  • 13,433 Answers
Hello
The problem monitor, have you tried using it alone with the computer? Does the problem persist when the problem monitor is only connected monitor on the computer?
If so, then the power supply of the monitor is most likely faulty, but can quite easily be repaired by replacing any bulky or leaking capacitors on the power supply board inside the display or by purchasing another external power supply (depends on the monitor, most use a internal power supply, so you just have a cord that goes into the monitor.)
When and if you take the monitor apart, stay away from the 200 - 600 V big capacitor on the power board, it may hold voltage even after being unplugged for a long period of time.
Posted on May 30, 2010
  • 4 more comments
    Ok, well, it looks like the monitor is working, but is very, very dark. When I turn it on then off it looks "on" and has a normal brightness but then instantly looks dark (at night I thought it was off). When I shine a bright light on it, I can see the screen, but I'm not sure what settings I can change so it doesn't go into it's dark screen mode. Help!
  • Ekse May 30, 2010
    okay, that sound like the back lights would need to be replaced, if that doesn't solve the problem, then the issue is on the inverter / power board (in todays monitors, they are the same board)
    To check if its a setting problem, open the Menu / set up, with the buttons on the display, find the factory reset or reset from the menu and do it.
    if the problem persists its a internal hardware fault in the display, most likely the back light tubes / lights need to be replaced entirely, if the issues remain, then the problem is the power board.
    A LCD monitor repairer will be able to test another working back light to confirm if the issue is either the lights or the board, if the issue is the board the technician will be able to repair / replace the faulty components from the board to repair it.
    I wonder if repairing the back lights on this monitor would be cost effective, I could buy a 19" monitor for about 120$ what would the repair on something like this cost, any ideas?
    Thanks!
  • Ekse May 30, 2010
    Well, I purchased a faulty display 17" from ebay for 9 dollars, It had a cracked screen but the back lights where fine. It also had the other internal components in good shape.
    So I could take those back lights from that 17 " monitor and swap them on another 17" monitors back lights. so that repair would cost me 9 dollars.
    As for the power board, for the repairer, it will not cost much to repair, it will be a very cheap repair, he will of course charge you for the parts, time and knowledge.
    Components like capacitors only cost around 0.2 $
  • Ekse May 30, 2010
    120$ for a 19".. I personally wouldn't buy that as new.
    Try your luck with this one? http://cgi.ebay.com/1-DELL-1907FP-19-INC...
    if your really lucky you might get this one for the price of shipping.
  • Ekse May 30, 2010
    note that you can swap out backlights from amonitor to another, but the boards, mainboard, powerboard will be different. you will need to replace those parts with the same or otherwise OK parts for that model.
    also note that the power board itself can be repaired, it is quite simple board and this can be repaired cheaply by a trained professional.
  • 4,737 Answers
You are right when you say that "might not have proper drivers". In most cases, this is driver issues. But before doing that, check the "refresh" rate. Sometimes, this is also a hidden culprit. Your choice is to update the video card driver. If you let me know the video card you are using (the one where you second monitor is connected), i could help you better in finding the drivers for you. Please let me know how you would want me to help you. If at least you can tell me the video card name let me find the update link for you. Awaiting your response. Good luck and thanks for using FixYa.
  • 8 more comments
    it is an Nvidia geforce 7900 gs. the monitor will come on for a second especially during the boot up, or when I turn it off and then shake the mouse, but then goes black.
    I've searched for a Jetway driver, and went to their site, but I couldn't get a driver it said "No download, for you." weird. The darn thing seems to want to work, but isn't, I went through all the refresh rate settings for "display 2" and the monitor would flash on then off. Do you have an idea what driver I could get? like a generic one or something?
  • Lebanon Raingam
    Lebanon Raingam May 30, 2010
    When I say "Drivers", I don't mean the monitor drivers, but the driver for your Geforce 7900 graphics driver, You can download from this link from the Nvidia website. Here's the direct link GeforceNvidiaGraphicsDriver, you'll need to select the operating system type you are using,
    Option 1
    Like this,
    Produce type : GeForce
    Product Series : GeForce 7 Series
    Operating System : Select your O.s.
    Language : Your choice, by default is "English"
    Option 2
    There's a feature with which you can let the application automatically find appropriate drivers for you. I recommend this.
    For you monitor, it's alright, you don't need driver. Good luck once again.
    ok, I'm trying that, I'm downloading the driver now, but it seems to me that this monitor (which is an older one) might need a driver specifically for it. Perhaps Nvidia creates drivers for monitors which may be out dated? I hope this is the case. If this nvidia update (which I am currently downloading), doesn't work what is the next step?
    thanks,
    mb
  • Lebanon Raingam
    I hope you've set one of the monitors as "Default". If not do so by going to the display options. Don't worry, just let me know. I think you don't have another video card, do you? Let me know, so that I can help you better.
    I don't have another video card, I did download the nvidia driver, and I'm having the same problem, the jetway monitor will flash for a second and then go black there is two ports on the nvidia card for seperate monitors. It's strange to me that the monitor would work momentarily but then go black, must be a driver or software issue. I tried the monitor on the main monitor port and the same thing happened, it won't work as the default, apparently.
  • Lebanon Raingam
    This is another strange thing again. Anyway, swap the ports and check if it helps or not.
    okay, that didn't work at all, and then it seemed that envision montior my primary wouldn't go back to the default, tell me again how to select it as defaut, I have it as number one in the mulitple monitor setting right now. Any other driver solutions you could think of? I don't think the monitor is broken but it doesn't work when I swap it to the main video output, just flashes and disspears.
  • Lebanon Raingam
    I am afraid when you say "it didn't work at all". Didn't you see any effect when you swap the ports? Isn't the other monitor working on another port? I don't understand, please clarify once again.
    Now let's proceed with complications, you have to let me know the refresh rates of both monitors, resolutions, monitor type (name and model), Graphics card - onboard or add-ons, Operating system (with bit, x86 or x64). Awaiting your response.
  • Lebanon Raingam
    Still here waiting for your response, if you can, please let me know, it's been almost two hours now. Thanks.
Acer AL1916W monitor driver for mac os x
Drivers specifically for the monitor are not needed to use the display. It should work fine right out of the box. If you are not seeing anything on the display, ensure that the power is plugged in and the connection from the monitor to your computer is inserted properly on both ends.
Sep 05, 2016 | Acer Computers & Internet
I tried to use my acer as a second monitor and it is connected to my GTX 550 Ti graphics card just like my Benq monitor. Whenever I turn on my computer the acer monitor shows the acer logo and then s
Incorporating a second monitor is a great Idea, I've used three to four on my workstations for many years. Setting up multiple monitors involves more than just hardware, the card manufacturer's software and operating system is involved. Since you didn't note the OS, I'll assume Win7. First, simply right click the desktop, and select "Screen Resolution" to see a page headed "Change the appearance of your displays," below which show be a graphic that shows both monitors with a number "1" and "2" on each. Arrange them by dragging and dropping them to reflect your physical arrangement. Then, select the fourth drop-down titled "Multiple" Displays" and select "Extend desktop onto this display," then click the "Apply" button followed by the "OK." button. If your hardware and drivers are set up properly, you should have everything working at this point. Your Nvidia software should have installed a control panel item that you can use to make tweaks to your system. You can also contact Nvidia technical support for more detailed, OS-specific assistance.
Jan 17, 2015 | Acer 23" LCD Widescreen Monitor S230HL BD
LG M197WDP, used as a monitor with a Windows 7 computer. Intermittently the monitor goes black for 15 to 20 seconds then the picture returns. I have checked drivers etc all up to date. Anyone able to
Could be a hardware issue, If the screen has a power light, does it change coulor (often green to orange) when the problem happens. If so its the screen inst getting any signal. It could be a connector or cable.
Nov 01, 2014 | Computers & Internet
Ford airbag code 54
94+ AIR BAG DIAGNOSTIC TROUBLE CODES/CLEARING
Code Component/Fault Description
No Air Bag Indicator - Inoperative Indicator Circuit
Continuous Air Bag Indicator - Diagnostic Trouble Code Timed Out, Diagnostic Monitor Disconnected or Inoperative, or No Ignition Voltage to Diagnostic Monitor.
12 Lost Battery Feed
13 Air Bag Circuit Shorted to Ground
14 Primary Crash Sensor Circuit Shorted to Ground
21 Diagnostic Monitor Not Mounted to Vehicle Properly
22 Safing Sensor Output Circuit Shorted to Battery Voltage
23 Memory Clear Circuit Improperly Grounded
24 System Disarm Failure or Internal Diagnostic Monitor Fault
32 Driver Side Air Bag Circuit High Resistance or Open
33 Passenger Side Air Bag Circuit High Resistance or Open
34 Driver Side Air Bag Circuit Low Resistance or Shorted
35 Passenger Side Air Bag Circuit Low Resistance or Shorted
41 RH Radiator Primary Crash Sensor Feed/Return Circuit Open
42 LH Radiator Primary Crash Sensor Feed/Return Circuit Open
44 RH Radiator Primary Crash Sensor Not Mounted to Vehicle Properly
45 LH Radiator Primary Crash Sensor Not Mounted to Vehicle Properly
52 Intermittent or Repaired Lost Battery Feed
53 Intermittent or Repaired Air Bag Circuit Shorted to Ground
54 Intermittent or Repaired Primary Crash Sensor Circuit Shorted to Ground
61 Intermittent or Repaired Diagnostic Monitor Not Mounted to Vehicle Properly
62 Intermittent or Repaired Safing Sensor Output Circuit Shorted to Battery Voltage
63 Intermittent or Repaired Memory Clear Circuit Improperly Grounded
64 Intermittent or Repaired System Disarm Failure or Internal Diagnostic Monitor Fault
72 Intermittent or Repaired Driver Side Air Bag Circuit High Resistance or Open
73 Intermittent or Repaired Passenger Side Air Bag Circuit High Resistance or Open
74 Intermittent or Repaired Driver Side Air Bag Circuit Low Resistance or Shorted
75 Intermittent or Repaired Passenger Side Air Bag Circuit Low Resistance or Shorted
81 Intermittent or Repaired RH Radiator Primary Crash Sensor Feed/Return Circuit Open
82 Intermittent or Repaired LH Radiator Primary Crash Sensor Feed/Return Circuit Open
84 Intermittent or Repaired RH Radiator Primary Crash Sensor Not Mounted to Vehicle
85 Intermittent or Repaired LH Radiator Primary Crash Sensor Not Mounted to Vehicle
Rapid Continuous Flashing of Air Bag Indicator (No Diagnostic Trouble Code) Both Primary Crash Sensors Disconnected Assembly Plant Mode
TROUBLE CODE CLEARING
1. Follow the diagnostic procedures to service the fault condition flashing on the air bag indicator prior to code clearing.
2. Cycle the ignition switch to OFF and then to RUN.
3. Observe air bag indicator prove-out (six ? two seconds) followed by diagnostic trouble code (52-85) flashing completely one time.
4. Locate the Diagnostic "Trouble Code Clear" Connector (grey connector). located underneath the glove compartment, left side (06010) containing Circuits 631 (T/R) and 57 (BK).
5. Use a jumper wire to short Circuit 631 (T/R) to Circuit 57 (BK) or to another good ground. This short must be made after the diagnostic trouble code flashes completely one time, but before the warning light stays on continuously.
6. Hold short until air bag diagnostic monitor tone sounds (approximately five seconds).
7. Release short on Circuit 631 (T/R) to Circuit 57 (BK). This short must be released within 25 seconds after the diagnostic monitor tone sounds.
Diagnostic trouble code is now cleared from memory. Next highest priority diagnostic trouble code stored (if one exists) will begin flashing.
The codes and clearing proceedure above are to be used as a guide, NO claims are implied as to the correctness or accuracy of either.
Sep 11, 2013 | Cars & Trucks
ViewSonic 19" flat screen monitor goes black - intermittently
There could be a problem with your display card settings or the display card itself. If you are using Windows operating system, make sure that you have the monitor driver installed for that specific monitor. This is to ensure that Windows only allows settings for which your particular monitor was designed.
Let me know if I can assist you any further regarding this.
Best wishes,
Graemevm
Jun 12, 2009 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
My hp w1907 monitor is constantly auto adjusting every 1 or 2 seconds. Make it stop.
Good morning! Auto adjustment occurs when resolution or refresh rate of the display changes. Check your display setings in OS. Set them properly according to product operations manual. Update your display adapters driver. Also check your VGA card or motherboard display port & try using a different cable. try pluging the monitor to a different computer or plug in a different monitor with your motherboard or VGA cards display port. best regards
May 03, 2009 | HP w1907 LCD Monitor
BENQ FP737S Monitor shows "No Signal Detected" on startup
first problem could be the hdmi cable you are using is loose or broken.second, the display mode you selected was wrong, try to go to desktop and right click and choose nvdia control panel and choose the nview display mode to use,select the only use one display(single)and apply.
Jan 27, 2009 | BenQ FP71E 17" LCD Monitor
Can not get card to display on the monitor
Have you set your system to use a second monitor? Right click the desktop and choose Properties. In the Settings tab, click the 2nd monitor and check the box that says Extend my windows desktop onto this monitor. If that fixes it, please rate me accordingly. If not, let me know and we'll try something else.
Jan 17, 2009 | ATI RAGE XL (8 MB) Graphic Card
Setting up dual monitors with vista
1.both monitors work in single mode ok.
when you start the nvidia contol panel under the display heading
you have setup multiple displays. What does this say.
are you using the nvdia drivers or the cards oem drivers ?
plug one monitor in then start the computer when that monitor works ok , turn off and plug in the other ...
hope this helps
Dec 31, 2008 | Computers & Internet
LCD monitor goes blank
It appears that the display resolution set in your display properties is out of the range that the LCD can display.
Try this.
Boot to the ENABLE VGA MODE by pressing F8 to get the Windows Boot Menu. If you can get to the desktop, then go to display properties, and see if you can change the resolution to higher settings and maintain video. (If the video blanks out, then it should revert to the previous setting in 15 seconds)
Aug 03, 2008 | Gateway FPD2275W LCD Monitor
Jetway M1531S 15" Flat Panel LCD Monitor Logo
76 people viewed this question
Top Jetway Computers & Internet Experts
john smith
Iqbal Husain
Iqbal Husain
Starnley Johnwells
Starnley Johnwells
Are you a Jetway Computer and Internet Expert? Answer questions, earn points and help others
