Question about KitchenAid 24 in. KUDP01FL Built-in Dishwasher
After wash, there is still food particle remain i.e. coffee grind
  • 159 Answers
It is normal for food particles to remain,Just not on the dishes! If there is coffee grains then i dont think it's heating the water.
Posted on May 30, 2010
Why are black particles being dispensed into the hot wqter from my Keurig coffee maker? How can this be corrected?
Hello, Irwin -
Those "small gritty black particles" are most likely coffee grounds which are so small they slip into the hot water and eventually the brewed coffee.
The grind size of your coffee may be too fine. Drip coffee method coffee makers, including the Keurig, require medium or medium-fine grind coffee.
Source of information:
Coffee Grind Size: Why It Matters and What You Should be Using, by Taylor Martin, December 22, 2015
CNET Best Products
https://www.cnet.com/how-to/coffee-grind-size-why-it-matters-and-what-you-should-be-using/
You may wish to check your coffee maker to determine if coffee grounds leaked into the space between the k-cup and the k-cup holder:
https://www.youtube.com/watch?v=jZrQhlQpLbs
Best wishes.
Mar 12, 2012 | Coffee Makers & Espresso Machines
Bosch classixx dishwasher saying check water also not washing or spining
Bosch dishwashers have a food filter to catch food particles. You have to clean it occasionally, or it plugs up and stops water flow. This could be your problem. (Most other makers use a little grinding blade to finely chop the particles so they can be sent down the drain.)
Oct 04, 2010 | Bosch 24 in. SGS43C12 Classixx...
Food particles remaining on dishes after cycle is complete.
Hi
While putting dishes in the washer and obstructing the spray ams which causes food particles to stay on dishes. After loading dishwasher and pushing in baskets ,be sure the spray arm doesnt hit any of the dishes causing them to not clean properly. If that doesnt work or is definately not your problem try removing the spray arm and seeing if it has food inside of it. Some times they get food build up in them and need to be flushed out.
However the other causes for this problem are…
Not enough water entering dishwasher (check level after fill... Should be slightly below bottom wash arm)
Water filling but draining during wash cycle. Check toward end of wash cycle but before drain. See if water level is diminished from start of wash cycle.
New 'water saver' dishwashers are notorious for having smaller water jets, and thus easier to stop-up jets. Check the jets on all wash arms to be sure they are cleared of food particles.
Another way to check the wash arms is to manually position them at specific locations, momentarily run the dishwasher for a few seconds, then open the door to inspect the location of the wash arms. Do this three or four times to eliminate the possibility of coincidence.
If the wash arms do not move from the location that you put them, the most likely cause is food particles stopping up the water jets. These jets not only clean the dishes but also the water pressure they generate turn the arms inside the dishwasher to properly distribute water pressure on the dishes.
Sometimes you can dislodge and remove food particles stuck in one of the jets with a toothpick or other small probe. Others require that you remove the arm(s) and get a little more creative. I use compressed air to clear mine, but not everyone has access to compressed air, so use whatever you can to remove the food particles.
Simply dislodging them from the water ports is usually not effective... As soon as water pressure is applied, the particles return to the jets and stop them up again. The real fix in this instance is to completely remove the food particles from the arm if you can.
Let us know if you want to know something more else please accept the suggestion.
Thanks for contacting Fixya.com
Apr 14, 2010 | Maytag 24 in. MDB8600AW Jetclean II...
Dishwasher overflowed, garbage disposal still works. Ran the dishwasher and noticed food and debris shooting back into sink thru garbage disposal. Water was on floor. Upon completion of full cycle, water...
Before loading into the machine you have to remove food particles. Washer will wash the greasy surface. If particles are left in the dishes, the same will find entry to the drain system. Check the drain filter in your machine. Clean them. Mostly problem will be solved!
Apr 08, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
Kitchen Aid Dishwasher about 5 years old. It seams to grind up the food but does not get rid of it so the food particles wind up on the dishes.
sounds like you need a new chopper blade located under the the cover the spray arm attaces to. when you get to it you will notice the scxreen plugged
Nov 03, 2009 | Washing Machines
Film and food residieu remains on upper rack
Hi, is the wash arm underneath the upper basket turning freely and is it not blocked with any food particles? I've had items out of my dishwasher with a similar problem and it's been when the upper wash arm has been blocked or a spoon has fell through and prevented it from turning and washing properly.
Good luck.
Oct 04, 2008 | Kenmore 24 in. 16352 / 16354 / 16359...
Food odor builds up if dishes not washed daily, even though we rinse evrything thoroughly before loading dishwasher. No water remains at bottom - nothing appears to be stuck in drain. Any thoughts?
No matter how well you rinse wares, some food particles will always go into the machine. Sometimes these particles can build up and lead to what you describe. I would start by inpecting the wash tub area; remove screens, remove wash arms and clean as needed. You are looking for any residual food soil which would harbor bacteria. If all else fails, follow your nose!
Once everything is as clean as you can make it, then purchase a product for cleaning/deliming your machine. One I know of is called "Dishwasher Magic" which should be available at most appliance repair stores. Run this through the machine on a long or heavy cycle. Once complete, run a second cycle with nothing but water to rinse any lingering chemistry.
Lastly, for a 3rd (and final) cycle, add a cup of bleach to kill off any remaining odor-causing bacteria. But, DO NOT SKIP THE RINSE CYCLE mentioned above.
This should take care of the problem,
Kermit
Aug 23, 2008 | LG LDF6810 Built-in Dishwasher
Food particles on washed plates
Sometime food particles stick near the door gasket. First, try changing the DW soap brand.
Nov 16, 2007 | Hotpoint 24 in. FDW60 Free-standing...
KitchenAid 24 in. KUDP01FL Built-in Dishwasher Logo
131 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
