Question about SimpleTech SimpleDrive 160 GB External USB 2.0 Hard Drive
I cannt used my external hard drive
My hard drive is not detect from my computer
    Habit-Forming:
  • 61 Answers
Try to plug in another usb port
Posted on Jun 14, 2010
Samsung external hard drive
!! You have failed to provide a detailed problem. !!
External hard drives are plug-and-play devices used to store music, video and data files. Once the drive is connected, the computer checks its systems for the appropriate drivers, loads them, and the external drive is ready to use. If the computer does not recognize the external drive, plug it into another computer to ensure the drive is not corrupted. If the drive is good, a few simple steps should help re-enable the drive for use.
Switch the power button to "off." Disconnect the power cord from any extension cords or power strip, then re-seat the power cord into the hard drive. Connect the cord directly into an outlet and power up the drive. If the drive is powered and still not working, check the data cable. Power down the hard drive and disconnect the data cable from the computer. Wait 30 seconds to one minute. Reconnect the data cable and power up the drive. If the drive is not detected, power down the hard drive and connect the cable to a different port. Power up the drive. If the drive is detected but not working, check for a missing driver. Click on the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Select "Device Manager" and double-click "Disk Drives." Right-click the yellow exclamation point and install the missing driver. Close the Device Manager. If the drive is detected but not working check to ensure it has an assigned drive letter. Disconnect all devices connected by USB cables from the computer. Reconnect the drive's data and USB power cables directly into the computer. Click on the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Click on "Disk Management," right-click the external hard drive, click "change drive letter and path," and click "Add." Assign a drive letter. Avoid using A, B or C (C is usually assigned to the computer's internal hard drive). Click "OK" close the window. If the drive is detected but not working, check whether the drive is in sleep mode. Disconnect all devices connected by USB cables from the computer. Reconnect the drive's data and USB power cables directly into the computer. Click the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Select "Device Manager" and double-click "Universal Serial Bus Controllers." Double-click the first instance of "USB Root Hub" or "Root Hub." Check for the hard drive. If the drive is not visible, move to the next instance of "USB Root Hub." Continue checking each instance until the hard drive is located. Once located, click the "Power Management" tab and uncheck the "Allow computer to turn off this device to save power" box, click "OK," then close the Device Manager. Power the computer down, wait 30 seconds to one minute, and power the computer back up to ensure the drive is detected.
Jan 29, 2013 | Samsung G2 Portable External HX-MU064DC/...
External drive not picked up on computer
External hard drives not only provide additional storage space on a computer system but also allow data to be conveniently transported from one computer to another.
These drives typically plug right in to a port on the computer and function without any additional setup; however, if you are running into trouble where your external hard drive is not being detected, you must troubleshoot the situation to determine why the drive appears to be missing.
Check the USB connection running from the hard drive to your computer.
If the USB cable is not seated securely in the port, the computer will not detect the external drive.
Disconnect the USB cable from the computer and plug it into a different USB port. Occasionally, a USB port will fail to function with some hardware and changing the USB connection may correct this issue.
Switch from a USB to a Firewire cable connection, if possible.
The USB port on the hard drive may have died; if so, changing to a Firewire connection will resolve this issue.
Install the driver for the external device from the installation disc provided with the product. Older computer systems may require you to manually install this driver.
After inserting the installation CD, follow the prompts from the installation wizard to install the driver on your computer.
Restart the computer.
If you connected the external drive while the computer is powered down, it may not recognize the device when you turn on the computer.
After restarting the computer, connect the external drive to the system.
The drive should now be detected by your operating system.
Connect the external hard drive to a power source and then plug it into your PC computer using a USB or Firewire cable.
Log on to your PC computer using an account with administrative privileges.
Open the Start menu and click on the "Control Panel" icon.
Open the "Administrative Tools" folder and then double-click on the "Computer Management" icon.
Select "Disk Management" from the list of options on left side of the window.
Right-click on the drive you want your computer to recognize and select "Change Drive Letter and Paths."
Select a drive letter for the external hard drive to be recognized as and click "OK."
The drive will now appear in My Computer.
Hope this helps.
Nov 22, 2012 | Samsung G3 Station Desktop External Drive...
I have a Hitachi external USB hard disk 320 GB. it was working fine at may laptop but when i tried using it with computer, the Windows cannot detect the USB Drive. i tried it with 2 computers. but its...
i have a Hitachi external USB hard disk 320 GB it was working fine at may laptop but when i tried using it with the computer ; the windows cannot detect the USB Drive . i tried it with 2 computer . but its still the same .pleas help i badly need my files
Dec 05, 2010 | Hitachi USB 2.0 to IDE 1.8" Aluminum...
My external hdd from bytec is not recognized by my computer. What shall I do?
Try to use direct connection to your computer. Using IDE cable.
If your comp can detect, means your external casing problem.
If not detect, your hard disk problem
Jul 09, 2010 | BYTECC ME-740 Aluminum 3.5" Hard Drive...
I was able to use my Hitachi xl 1000 external hard drive on my computer and I wanted to be able to use it for my Macbook Pro as well but as soon as I used it for Time Machine Backup I wasn't able to use it...
If the MAC formats the external hard drive then the desktop cannot see any files on the hard disk even though it detects the external hard drive.
If you format the external hard drive using the Desktop computer and format it in FAT32 then the MAC can read and write to this hard drive and the desktop PC can also read and write to the external hard drive.
MAC computers can read and write on PC formatted disks but not the other way around.
Jun 29, 2010 | Computers & Internet
I have a Maxtor One Touch 4 Mini 120GB External USB 2.0 Hard Drive, I've previously used it multiple times in the past, importing AND exporting data. For some reason though after using it on one computer...
try testing it in another computer. if you have the same problem. then there might be an issue with the drive.
to recover your data. unplug external drive from the computer and open the external hard drive case. remove the hard drive inside. with you computer off and disconnected from the wall open the case to your computer. look and see how the hard drive inside is connected in your computer and add the external the same way. you might need a cable to connect it. you can simply disconnect the cdrom and plug the hard drive instead. make sure the external hard drive is not touching any electronics inside the pc. now you can turn on the computer. give the computer a minute to detect the new drive and assign a drive letter. navigate to my computer and select the newly added hard drive. copy and paste all the data you want to save. after everything has been backed up format the external drive to clear any bugs that may be causing it to be recognised in its case.
when finished remove the hard drive, plug in the cdrom, close the case, plug back into the wall, and return external drive to its case.
Feb 28, 2017 | Maxtor OneTouch 4 Mini 120GB External USB...
External hard drive not detected
Check your jumpers on the hard drive. DON'T leave it connected very long if the jumpers are not set for master / slave (furthest away/ closest to the IDE port on the computer or it can mess up the circuit boards on one or both drives! If you are using only one hard drive, set the jumper(s) for "cable select" (often abbreviated CS). If it still doesn't detect the drive, the drive may not have an "active" partition on it. You can solve that by booting to your OS installation CD -- assuming you have one!
Feb 02, 2010 | Western Digital Elements powered by WD 320...
Drive cannt be detected by laptop
Ok what this sounds like to me is that the partitioning table or MBR have been corrupted and it only recognizes part of the partition. I would suggest downloading the ultimate boot cd, at www.ultimatebootcd.com. Burn it to a CD and boot to the CD . Try partedmagic and i think the app inside parted is Testdisk, if i remember correctly, alot of time it can recover data pretty effectively with that failure.
Let me know if this helps.
Sep 22, 2009 | Trekstor DataStation maxi m.u SATA 3.5"...
Can no longer recognize my external hard drive
I cannot get my computer to detect my external hard drive. It worked fine before? Now i get this clicking sound.Please help.
Nov 15, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
External hard drive cannt detect
Could you let me know, what happens when you insert the External HD in the USB port............and also go to Device Manager and check if their is any Yellow exclamation mark across USB Controllers......if so, then Right click and uninstall all the USB ports and Restart the Computer.......If you see a RED mark, then just Right Click and Select Enable.....just follow the steps as given....and let me know...Take care
Jul 31, 2008 | Computers & Internet
SimpleTech SimpleDrive 160 GB External USB 2.0 Hard Drive Logo
171 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
