Question about NEC PowerMate 2000 PC Desktop
I NEED TO KNOW WERE TO BUY AC POWER INPUT AND DC POWER OUTPUT AND MORE MEORY AND HOW MUCH MORE I CAN I INSTALL CAN I UNSTALL 1024 OR 512.
    Scholar:
  • 113 Answers
Ebay would be my best bet for the AC adapter. As for more memory go to Crucial.com and that would be the best bet for finding out how much memory you can have.
Posted on May 31, 2010
Need to know input, polarity and voltage to ensure I have the right adapter.
Complete Guide to Using the Correct Charger or Power ...
www.groovypost.com/.../choose-right-power-adapter-charger-phone-lap...
Jun 24, 2013 - If the device has a DC input of +12V / 5.4A, get an adapter that has a DC output of +12V / 5.4A. If you have a universal adapter, make sure it has the proper current rating ... Ideally, you'll have the same voltage, current and polarity on your ......or hdmi on my laptop .can you say what's the reason for the same.
How to select an AC to DC power adapter - ApogeeKits
www.apogeekits.com/power_adapter_selection.htm
An explanation of regulated versus un-regulated AC to DC voltage power adapters. ...voltage output power adapters and how to use this information to select the right one... Some (more expensive) DC voltage output power adapters have voltage ... Care should be take to ensure that the maximum input voltage of the load ...
AC/DC Power adapter ' Laptop Parts 101
www.laptopparts101.com > Laptop parts
Dec 26, 2008 - It's very important to use the right adapter for your laptop. ... Polarityon the new adapter's plug must be the same as on the original ... AC/DC power adapter voltage and amperage ..... I have purchased an non-hp dc-dc convertor (150W), 12Vinput, 19V output. .... So the cable component has to be replace.
Determining Proper A/C Polarity - Galen Carol Audio
www.gcaudio.com > Resources > How-To's
Jan 10, 2016 | Computers & Internet
What is the power output of ac dc adapter in jensen jta 460? Can this adaptor be changed with 220volt ac dc adapter with required dc output?
For Any Adapter:
As long as the Voltage and Power output of the power supply (wall outlet or other) matches the input requirements for the adapter whether 110V or 220V.at enough amp output; and
IFF the dc output of the adapter is exactly the same voltage and has for amps at a minimum matches the maximum amperage requirement for the input of the device, any of them will work, as long as it has the right connector with the correct polarity needed for the device!
Or, in other words...
Supply Output V = Adapter Input V
and
Adapter Output V = Device V
Adapter Output A(min) >= Device A(max)
Aug 27, 2015 | Computers & Internet
Do I need to replace the battery and buy a converter, or buy a completely new one? Is it completely broken?
Normal the high input voltage should influence the output voltage. The120V AC to 9V DC will be blown, but with a bit of luck, your Crosley cruiser will be ok. Only if the power convertor is poorly made, the high voltage could have gone through the convertor and then it damaged everything in the cruiser. Try a new 9V power supply and see what it does.
Jan 19, 2015 | Crosley Audio Players & Recorders
I mistakenly connected energy source at the AC inverter output .Inverter is 5KVA cyberpower inverter.After correcting the connection, It cannot switch from DC to AC( fault signal is displayed on its...
John,
It's shorted out, either replace the part or buy a new one.
If you need UPS, Surge, or Power Related help don't hesitate to contact me!
Daniel • daniel@psihq.com • Power & Systems Innovations • 800.260.2259 • www.psihq.com
Sep 24, 2013 | Cybernet Systems CyberPower DC to AC...
I need a user's manual for Voltcraft Fast Charge Delta Peak model MW3610HC. I believe it is a battery pack charger. It is a Europian product that requires a U.S. AC adapter. I want to know what size...
SPECYFIKACJA :
  • V detection
  • Cigarette lighter plug
  • Double output
  • Discharge function
  • Dla Ni-Cd/ Ni-MH battery
  • Input voltage: 230V AC, 50Hz, 13.8V do 24V DC
  • Output :
  • Dla 230V AC or 24V DC input: 5.6V DC (4 celle) do 11.2V DC (8 cell)
    • Dla 24V AC input: 5.6V DC (4 celle) do 8.4V DC (6 cell)
  • Output regulowany : 1,000/2,000/3,000mA
Sep 04, 2011 | Vacuums
I need to replace the power adaptor for a Maxtor One Touch 4 500 GB. I need to know the volt and amp output for it. PN:9NT2A4-500
Power Adapter for Mactor OneTouch 4
AC Input : 100 AC - 240 AC (50/60HZ)
DC Output ( V/A ) : 12V / 3.5A
Output Power : 42W
Apr 17, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
Power supply/ no output voltage
Actually i haven't fixed the problem as yet but i did find some info that would help me to fix problem.
I went to google and entered keyword,,, Electronic parts,,there came up a page,,and i went to several manuf sites till i found a replacement transformer,,then i disassembled the power supply and am now waiting for a replacement transformer.
Sep 21, 2008 | Boston Acoustics MicroMedia Computer...
Can anyone tell me if the 12 volt powersupply is 12 volt AC or DC ?
Model HER-48-12010
P/N: 68300021-0013
AC Input
DC Output
Sep 20, 2008 | Compaq S 200 Flatbed Scanner
Power supply
if you are in usa, you need 1-468-809-11 POWER UNIT input ac 110 volt and output 8.5volt dc
and if you are in uk, then
1-468-811-11 POWER UNIT input ac 220 volt and output 8.5 volt dc
bye.
Sep 08, 2008 | Sony ICF-CD855VSIL Clock Radio
NEC PowerMate 2000 PC Desktop Logo
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
