Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA D52W20 52--Delayed Power On and does NOT turn on now.
I have a RCA D52W20 52" Rear Projector HDTV that is experiencing “delayed power on”. For awhile the set was cycling 3 times before turning on after pressing the on / off button . Then it was working fine. However, now the set cycles 3 times and I do see a green light but is NOT turning on.
  • RCA Master
  • 8,457 Answers
U DM power supply board have dead capacitors,before the capacitors have some functions left,that why u able to recycles by pushing the power buttons 3 or 4 cycles to get power to the tv.U have tools,soldering iron,solders,and know to do soldering?Tries website like Tvrepairworld.com to buy a capacitors kit,that design to replaced in the DM power supply board.Look around and replaced these dead capacitors,it alway bulges up or puff up on it top.Ur tv will power up and as normal again.
Posted on May 30, 2010
I have an older model
rca entertainment series Gemstar tv and the power button when pushed turns green but th e television won't come on.Is the problem expense to fix or can it be done personally
Posted on Jun 14, 2010
  • 11,361 Answers
This model is known to have bad solder joints around the flyback transformer which the sub powers are generated, look for blown fusible resistors around the flyback legs.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 31, 2010
D56w20 wont turn on
this situation indicates that the unit has an internal problem, this can be 1 of a number of safety power shut down protection circuits employed in a modern projector television, only a person with experience in electronics service or an extremely determined person with some electronic test equipment has a hope of servicing the problem
Jan 09, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a 52" rca model D52W17. I turn it on and about 10-15 minutes later it just cuts off. Sometimes it trys to cut back on and then goes right back off. I smell nothing burning, screen looks fine when on...
without takeing mesurment i would be makeing a guess = there are some capacitors that could be going bad.. intermetant or delayed shutdown ussally means a overheating or failing component or bad solder connections.
Oct 13, 2010 | RCA HD52W56 52" Rear Projection HDTV
I turn on my TV and 10 minutes later it turns off by itself. What is the problem
generally this model shut it self down if anything major. possible reason for a delayed shutdown is bad capacitors. or loose connections. does the picture display any abnormalites before shutdown. does it come right back on when you push power button. any sounds or smells? how long has this been doing this?
When you turn the power on, the green power button goes off and on and the tv does not turn on. It was coming on at a delayed rate. Now it does not come on at all.
Replace the Three capacitors CP150, CP120 and CP114. You can get the RCA repai kit by that same name from www.tvrepairworld.com which contains the caps and the CD with instructions.
Aug 15, 2010 | RCA D52W19 52" Rear Projection Television
My Samsung is delaying turning on
Reason for your problem is that there is not proper power being supplied to the tv. Solution- on the power supply there is 2 capacitors 1 of which is exploded already. You would need to replace those with new ones. spotting and exploded cap, good caps are flat on the top and bad caps swell out.
current cap- 10v 2200mf
replace with -16v 2200mf or 25v 2200mf
repair will include soldering.
Apr 27, 2010 | Samsung SPN4235 42 in. Plasma HDTV
I have delayed power on with my HDTV RCA D52W20
Very common problem which is usually caused by the CP150, CP114 and CP120 capacitors needing replacement. You can get the repair kit by that same name from www.tvrepairworld.com which also has the Cd with instructions.
Mar 07, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Power Light on but no picture or sound
Can you tell me exactly what does the l
power led do when you press power? Also can you verify the model number of your RCA?
Jun 27, 2008 | RCA HD50LPW164 50" Rear Projection HDTV
Delayed Power Up
Probable regulated 12v power supply.....To help further....need
info....Model # and service # and mo /yr built off back of set..T.
Dec 21, 2007 | Televison & Video
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
536 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
