Question about Ovens
I have a white westinghouse oven model KF404GDW3 it is oven baking very uneven (center of cakes not cooked) Jeff
You will need to look at and replace the heating element or thermostat in your oven. Before you do that, flip your circuit breaker off and then turn it back on, this may restore full power to your oven
http://www.ehow.com/way_5933408_white-oven-not-heating-up_.html
Posted on May 30, 2010
  • Jeffery Crow May 30, 2010
    Michael, since the therm. is $177.00 and the heating element is $19.00 what are the chances it is only the heating element, is there a way to test it? Jeff
  • Jeffery Crow Jun 04, 2010
    Michael, I am not sure if you saw my secondary question, but if the therm. is $177.00 and the coil is $18.00 any ideas that would make (testing?) a better spending choice?
Kenmore 790.95662100 electric oven does not bake evenly. It seems to bake items until you get into the center of a cake or the center of something with mass. The same temp has previously cooked without...
Sounds like the thermostat is out of calibration. IE- you set the temp at 350, but the actual temp is only 275, resulting in undercooked food. I repair comercial restaurant equipment, and use an infra red thermometer to check actual temp in the oven, against the set temp.
Mar 27, 2011 | Kenmore 49222 Electric Single Oven
Why do cakes sometimes collapse while baking?
helllo dis.... There are many things that can cause cakes to fall in the middle.... Jumping, etc., around the baking area is unlikely to be a problem except with very delicate sponge or angel food cakes. More likely, cakes fall when the crust appears to be done, but the batter is not baked through the middle. An uneven baking temperature is a frequent culprit; check the temperature of your oven with a separate baking thermometer, and be certain that your oven holds a steady heat through the entire baking period. Some older ovens preheat properly, then cycle off and drop the temperature after 15 or 20 minutes, which causes the uncooked portion of the cake to fall.
Less likely but possible problems could be inaccurate proportions of baking powder or baking soda if the cake is made from scratch. This could occur with cake mixes if sour milk or buttermilk is used instead of regular milk; the additional acid in sour milk requires additional baking soda to rise properly. Eggs that are not beaten properly, or perhaps beaten too much for the type of cake being made, might also cause problems. Joe
Mar 12, 2011 | Tecnik Ovens
I have an bajaj oven and im trying to bake a cake and everthg i bake it the sides of the cake get baked and the middle portion remains raw..ive tried all the up flame,down flame and also both the up and...
if your oven is gas its is very difficult to make perfect baking of of the uneven heating,if your oven is elecric is with convection that one good compare to gas oven on an electric oven without convection, the advantage of oven the with convection is even heating.
Dec 24, 2010 | Ovens
My recipe says for cooking a xmas cake in 9" tin
The recipe is the one to follow, NOT stove. And always in center rack of oven. Too low burns underneath, too high burns top
Dec 18, 2010 | Siemens H 4680 BP KAT Stainless Steel...
I am using an old white westinghouse electric oven to bake a cake. I selected the right temperature which was between 150 and 160 cel. It started but I could hear the sound of a fan. I kept it on for at...
Either the temperature sensor has a problem (shorted so the control thinks the oven is colder than the actual temp) or a relay feeding the bake or broil element is welded shut and causing one of the elements to stay on. If the elements are still heating when the "ON" indicator is NOT lit, then you have a welded relay. You need the control board repaired.
Jun 25, 2010 | Philips Ovens
Large christmas cake what temperature and
Using a meat thermometer inserted in the center of the cake, the internal temperature should read 195-205F (or 90-95C) when it is fully cooked.
Nov 08, 2009 | Bosch Ovens
Simpson Evolution 904 wall oven cooks very unevenly
I agree, the heating is very uneven in our oven, however, when I calibrated the temperature with a thermocouple, I discovered that the temperature gauge was 25C too hot! That is, if I set the oven temperature gauge to 155C, it was actually 180C inside the oven! Taking this in to account, it is now much easier to cook things without them burning.
Sep 26, 2009 | Ovens
Uneven rising & baking in convection oven
I repair commercial cooking equipment for a living. When a customer complains about uneven cooking the #1 thing that these manufacturers ask is..... are they turning (180*) the baking sheets half way thru the cook cycle. #2 are they staggering the pans front to back & side to side. It's kind of a pain but, works for the commercial ones.
Jul 24, 2009 | Amana AEW3530DD Electric Single Oven
OVEN NOT BROWNING CAKES
put dynamite in container. if it blows up, too bad
Apr 12, 2009 | Jenn-Air JGW8130A Electric Single Oven
Amana Convection oven not controlling temp
I have just checked the baking guide in the manual and have found that it may not be us after all. (Maybe this is why they telll us to read the whole manual. Well, I never have) According to the cooking time for Baking, the range is very extensive. For example, an angel cake at 350 could take from 28-50 minutes, buscuits at 375-400 could take 8-16 minutes, layer cakes at 350-375 could take 25-40 minutes, pound cakes at 325-350 could take 45-70 minutes and fresh pies at 400-450 could take 35-60 minutes. Basically, the baking directions on the box means absolutely nothing to use Amana oven owners. We have no choice but to cook our food or baked goods until they are cooked, whenever that may be. :) Linda
Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
