Question about Whirlpool Refrigerators
Whirlpool side by side: Inside Freezer part turns burning red!
Whirlpool side by side: Freezer side on left, down on the bottom--could see some sort of coil turning bright red with heat through a venting area--the way we noticed was it was making snapping noises--thanks for your help.
    President:
  • 949 Answers
What you saw was the heating element. It is partially visible through the louvers in panel behind the shelves.
In a automatic defrosting refrigerator there is a defrost timer that will cycle this heater on for about 10 - 25 minutes every 8 to 10 hours. This heat will rid the evaporator coils of the frost that builds up so you do not have to manually defrost the unit. When the frost melts, it will hit the heater and sizzle almost like bacon frying.
You just happen to have the door open during one of these defrost cycles.
Nothing to worry about.
Posted on May 30, 2010
Ice forming at bottom of freezer
I had a problem with Ice forming in the bottom of my freezer on my whirlpool side by side freezer-refrigerator. Turn out to be a plugged drain in the bottom of the freezer. That drain goes into a tray under the whole unit. During Defrost, condensate drops from the contents of the freezer on to the bottom of the freezer and goes through a drain tube to a pan underneath. Should that drain tube become plug and the water is left standing in the bottom of the freezer, it will turn back to ice after the defrost cycle is over. Once the drain tube is clean out, the problem goes away.
Oct 20, 2014 | Whirlpool Refrigerators
I have a Whirlpool Refrig. model GX5FHDXVY04. The freezer is working properly but the refrigerator is not cooling. I noticed frost on the inside back panel of the freezer. I turned the temp down in the...
Many of frost-free fridges use fans to move a controlled amount of air into the upper or side cooling chamber, check for non-working fan or a stuck or malfunctioning damper control. Keith L.
Mar 02, 2012 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
How to change water filter?
Hi
Find the indication light, located at the top of the Whirlpool refrigerator just inside the door. This tells you when to change your water filter. A green light indicates the filter is good and a red light indicates you need to change the filter.
Find the filter knob. It is usually located at the base of the refrigerator in the kick plate or grill.
Turn the knob a quarter turn to the left to unlock the filter. Pull out and remove the old filter.
Add a new filter and push in. Turn the filter a quarter turn to the right to secure it in place.
Reset your filter indication light inside the refrigerator. Press down and release the switch five times within 10 seconds. The filter indication light should then turn green.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 07, 2011 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
Freezer frozen on bottom and frige cold on bottom only. No airflow coming from vents inside freezer or top left of frige, freezer and frig warm at the top. Model is a ED25QF
check to see if fan is running in freezer if it is you may have a defrost problem if not replace the fan its the evaorator fan that is in the freezer
Mar 08, 2010 | Whirlpool ED5FTGX Side by Side...
Water Filter
most whirlpools have the filter located in the bottom kickplate, right below the freezer door. turn counter-clockwise and toward you to remove. if it has never been removed before, they are hard to get out the first time.
Jul 24, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
WHIRLPOOL TOP FREEZER ET1WTKXKQ01. NOT COLD ENOUGH
You need to look inside the freezer at the rear wall cover and see if it is frosted over. If your refrigerator is not defrosting that can cause the refrigerator side and the freezer side also not to cool to the desired temp.
Mar 30, 2009 | Whirlpool ET1WTKX Top Freezer Refrigerator
Hissing inside the freezer
This is 100% normal, the element is there to get red hot and defrost all the ice off the freezer Evaporator, if you touch it you'll burn your finger. It's called a defrost element and comes on for upto 30mins every 6-12hours depending on the timer. Without it the freezer would be a block of useless ice cheers
Mar 27, 2009 | KitchenAid Refrigerators
Whirlpool Side by Side Refrigerator
hi- there might be a switch inside freezer to turn the ice maker on and off- it will be located on the upper left corner-
Nov 22, 2007 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
27 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
