Question about Liebherr KGBN 3846 Premium BioFresh Bottom Freezer Refrigerator
The fridge and the bottom freezer are working fine. However there is a lot of ice developing at the bottom of the (bottom) freezer. Although we recently de-frosted the freezer and removed the ice (water), the ice has re-occured quite fast. This does not look right. Any advice?
  • 120 Answers
There is only 2 things if you dont have an ice maker inside your door is not sealing all the way around or the drain is cloged with ice and everytime the ref goes into defrost the water leak into the fzr unplug for 2 days that shoud fix it
Posted on May 30, 2010
Why does my daewoo fridge freezer works intermittently ?
You either have a faulty thermostat, a loose connection or most likely a build up of ice inside the freezer. I had the same problem. Almost replaced fridge. Took all the food out one day, took out the racks and disassembled bottom and rear and found a two foot log block of ice inside air return. Removed ice everything works perfectly.
Jul 22, 2014 | Daewoo Freezers
Ondesit fridge fridge freezer biaa134fh fridge not cold
It seems lots of people have the same problem with this appliance....including myself......I took the drawers out of the freezer.....removed the iced up plastic cover which houses the fan assembly.....some water had settled in the bottom and froze, therefore stopping it from turning.....just spin it and it with start up again.....hope it helps ;)
Mar 13, 2014 | Indesit BIAA134F White 9.5 Cu Ft Fridge...
Ice in refrigerator
Usually a blocked drain at the rear just above the bottom shelf. Use a plastic drinking straw to clear the hole. Could just be condensation if you are in and out of the fridge a lot.
Aug 07, 2012 | Frigidaire FRT17B3A Top Freezer...
My Samsung RB195BSSB bottom freezer model has recently developed an issue. The freezer will warm up to 21 degrees and not hold the previous temperature. Fridge is fine. Ice maker may not be making ice...
This sounds like there is a build up of ice on the evaporator. this will block the air flow and allow temperatures to rise.
The problem could be with;
\ the defrost timer
\ defrost heater
A technician can solve this for you
Mar 24, 2011 | Samsung RB1955 Bottom Freezer Refrigerator
Fridge and freezer works fine-not iced up but
Ya, if compressor is working cond. fan also works. Reduce thermostat sett.
Nov 10, 2009 | Amana ABB1927DE Bottom Freezer...
Fridge not working properly on kenmore bottom freezer model 596.7
I have a similar problem, although I have no cooling in the fridge section. Had a repair man indicate that the electrical panal(pcb board) needs to be replaced. It is on order ($200). Sure hope that is the issue. To me, it appeared that the freezer fan(which cools the fridge) was not working. Whether that is the result of a faulty electrical panal is yet to be determined. Good luck!
Aug 12, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Fridge wasn't cooling but freezer was working, now both aren't
Hi,Your husband did good job, after cleaning and vacuuming, did freezer (bottom) have excessive ice?, if there's excessive ice in bottom, after cleaning, you have a defrost problem, but if there're no ice in freezer after cleaning, you got freon (gas leak) , there's a condensate loop, that passes through ref. body, from compressor that naturally develop, freon leak after few years, by rusting, normally it can be by- pass. vacuum and refill with freon, if there's no freezing, but compressor running, you'll need a mechanic, you got a freon leak. good luck.
Aug 10, 2009 | Amana ABB1927DE Bottom Freezer...
Top Freezer works fine but there is no ice building up in freezer the bottom fridge not cooling properlyThings are not as cold as they should be
Remove the back panel from the freezer to verify no ice behind the freezer panel. Look inside the air vent on the freezer panel for ice buildup. Make sure the freezer control is set to minimum not coldest freezer.. Make sure the freezer fan motor is working.
May 28, 2009 | Electrolux Refrigerators
Liebherr KGBN 3846 Premium BioFresh Bottom Freezer Refrigerator Logo
517 people viewed this question
Top Liebherr Refrigerators Experts
Charles T Nevin
Charles T Nevin
Shehu Pro
Shehu Pro
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
