Question about Sony VAIO VGN-CS110E/W NoteBook
My computer prompts me to go on hybernate because the battery is not compatible or not installed..
  • Sony Master
  • 4,924 Answers
Right click on the desktop..go to screen severs ..and there to power savings..in there remove any settings that will get it to sleep and put it never on all the line down ..including on battery mode..and willnot prompt you anymore untill its shuts down from lack of power in battery mode..and will stay on for ever until shut down manually in adapter plugged mode
Posted on May 30, 2010
Clock stops when the computer sleeps
Have tried replacing or asked a technician to replace the "cmos" battery? also have you tried to disable this mode, and leave hybernate to see if it happens? also what is the date and time when you resume? what is your time zone as well? let me know.
Apr 21, 2014 | Acer Aspire 5600U all-in-one desktop
1525 wont come out of hybernation and the battery wont hold a charge either. Ive tried removing the battery, pushin the power button, lettin it die n try bootin up. Its stuck in hybernation, help me...
Hybernation is one of the worst idea's that microsoft has come out with, it usually ends up corrupting windows making it useless. The only option is a fresh install of windows, and I recommend the hybernation feature be disabled. The battery may start to charge when the new operational windows is running, if not! replacement needed.
Apr 14, 2012 | Dell Computers & Internet
My emachine isn't starting up after hybernation, unless i press the power button and reboot. Why is this?
When your system goes to hybernation it creates a file on the root drive called hyberfil.sys in most instances this file gets corrupted and is causing the computer not to wake up from hybernation.
You would have to try and delete this file so that it will re enable the normal hybernation wake of your computer, here's how to do it:
http://helpdeskgeek.com/windows-7/windows-7-delete-hibernation-file-hiberfil-sys/
Just have to reverse the process to re-enable hybernation.
My recommendation would be to just disable Hybernation and just let the computer go to sleep if you're going to leave it idle.
Hope this helps!
Aug 03, 2011 | E-Machines eMachines Desktop PC
Gone into hibernation - can I retrieve
When your laptop goes into hybernation, all files are saved as they were. As soon as you re-start your computer, it will open all files and programs as they were before hybernation started, so YES, you can retrieve everything as it was before.
be sure the computer ios plugged into a charger, to be sure the batteries are charged.
Please, let me know how it goes.
Alex
Mar 21, 2010 | Computers & Internet
Stand by and hybernation option is not coming on
Try to install Lenovo Energy/Power management and try to configure it there. You have to install the energy driver and the software for you to configure it. You can download it from: consumersupport.lenovo.com. Just eneter your serial number and every driver for your computer model would be there
Feb 21, 2010 | Lenovo 3000 Y410 Laptop
Hp pavilion dv6000 notebook is not starting after putting into hybernate mode , black screen, all leds on the panel glow, but notebook doesnt boot
Thats the first problem of that model.They first dont want to go out of hybernate mode after that the wifi will not work and after that the video of that computer will be dead.I had like 30 HP Pavilion dv6000 and i just hey them nov but i can repair them.!!!
Nov 10, 2009 | HP Pavilion dv6000z Notebook
IBM T23 Laptop went into hybernation when battery
Are you going to use hyernation again...it takes lots of space and may freez your computer if you do not have a space use safe start and look at c: and see how big is the hiberfil.sys do not delet it if you are going to use it again if not try to disconect. temp. by typing "powercfg -h on"
Hope that work for you please post your outcome
Sep 13, 2009 | IBM ThinkPad T23 2647 Notebook
My A105 Toshiba Satelliet is stuck in hybernation and will not come back on
hi dear
oke ...try to remove the battery from your notebook, try on with only adaptor
after normal you can put your battere again
thnks
cropp
Mar 17, 2008 | Toshiba Tecra 8100 Notebook
Samsung V25 Laptop When it is powered up nothing is showing on the screen although the power light is on and you can hear a noise. This has happened before and it just came on.
One way to make sure the system is still working, remove the Batery, then plug the power adapter only and turn the computer back on, normally if the laptop goes into Hybernation mode and the battery is low on power this can happen. If that fixes the system then you can do a safe shutdown and re-install the battery and turn your laptop on and it should come on, the fact that you mentioned this has happened before makes me believe it is Hybernation issue. Good Luck.
Jan 07, 2008 | Samsung V25 CXTD 2000 Notebook
Random Hibernation
this sounds like power settings options.
what i can suggest now is that......................
go to the Power Options in the Control Panel and do the following.
  • first uncheck the hibernate option on the hibernate tab
  • use your computer and see if the problem re-appears, go to the control panel and on the power option, select Never to all options when using battery or ac power.
cheers...............
Oct 24, 2007 | Sony VAIO VGN-N130G/W Notebook
Sony VAIO VGN-CS110E/W NoteBook Logo
76 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
