Question about Whirlpool Dishwasher Water Heater Thermostat Control - 303282
Pliot will not stay lit - Whirlpool Dishwasher Water Heater Thermostat Control - 303282
  • 333 Answers
There is an ignightor, and a thermocoupling. The thermocoupling is a sensor that is used to tell if the pilot light is lite before it opens up the valve and lets a whole bunch of gas out.
The thermocoupler has a thin film on it from the gas burning. Take a piece of steel wool and clean it up.
Posted on May 30, 2010
Sw6p suburban won't stay lit. My 6 gallon hot water heat on my 2007 camper won't stay lit, I go and light the pilot light and it lights but I turn the gas up and it blows out please help
the thermal couple is likely bad .
when you release does pilot stay lit or only as long as you hold the button .
if it stays lit then the thermal couple is good
if it only blows out as you turn on the heat then its draft issue.
May 09, 2015 | Water Water Heaters
Water heater pilot light not staying lit
Check you have enough gas pressure. At least 19mBar when all appliances are working.
Dec 21, 2017 | Water Heaters
My water heater will not stay lit.
Make sure that you used the correct thermocouple. If so then you probably have a bad gas control valve. Also make sure that there is a drip leg in the gas line.
Good luck,
Marty
Dec 06, 2012 | Whirlpool Water Heaters
Pilot wont stay lit on waterheater. I replaced Thermocouple and that did not fix it. It will stay lit on vacation setting.
Most gas water heater problems can be fixed with yearly service that cleans burner and burner parts, checks gas pressure and bleeds air out of gas line, cleans air intake, and checks for venting and air intake problems.
Open following links for resources:
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/pdf/Attic-Ventilation-and-Pilot-Outage-in-Gas%20Water-Heaters.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Jul 27, 2011 | Water Heaters
Pilot won't stay lit
Possible thermocouple is defective. The thermocouple is heated by the pilot itself, the theory behind this safety design is so the main burner cannot come on, if the thermocouple won't stay hot, it reduces the chance for a huge gas buildup in the burner compartment and possible explosion.
I have also seen cases a pilot would not stay lit if the flue for the heater is blocked by a spider web, bird nest or other obstruction.
Check and make sure the flue/vent is absolutely clean and clear, if it is, then the thermocouple may be defective. If you have an electric pigtail on the thermocouple, the problem may be the electronics or circuit board.
Here is a link to a photo of a thermocouple
https://www.centraltrailer.com/cart/images/2631-3481.jpg
Dec 22, 2009 | Whirlpool Water Heaters
Rheem water heater will not stay lit
can you lit the pilot and if so will it stay lit
Sep 23, 2009 | Vanguard International Vanguard BY Rheem...
Pilot light will not stay lit
your thermocouple needs to be replaced. they are available at any hardware store.
Sep 16, 2009 | Water Heaters
I don't know how to restart my old bosch water wizard 10p, pilot light has gone out.
get a long stick match, a flashlight remove lower inspection cover, find thermocouple and pilot light will be next to it,turn gas valve to pilot light and hold down,stick the match in by thermocouple till the pilot lights and hold valve down till pilot stays lit,this may take a minute or more,then release gas valve and see if pilot stays lit, if not retry,if it wont stay lit,the thermocouple is defective and needs replacement
Jul 12, 2009 | Bosch & Tankless LP Hot Water Heater
Does not ligh (Or stay lit)
What is the model number and brand of the unit?
You can go to http://owneriq.net/ to find an owners manual for your water heater. If they don't have one, they will send you to the manufactures website where you can find one.
If the unit will not stay lit then it's the thermocouple on the unit. You need to replace it or you can try cleaning it with a small piece of emory cloth. If you put a new thrermocouple in and it still won't stay lit then it's the main gas valve that is either clogged or defective.
Mar 21, 2009 | Whirlpool Water Heaters
Pilot light has gone out. Need to know how to restart it.
You need to find out why the pilot is going out.First is the heater getting to hot?Look for a reset.If the pliot is giong out when you try lighning it then the thermocoupen is bad.That is the thing that senser the flame form the pliot.
Mar 09, 2009 | Water Heaters
Whirlpool Dishwasher Water Heater Thermostat Control - 303282 Logo
169 people viewed this question
Top Whirlpool Water Heaters Experts
Jim Goldsmith
Jim Goldsmith
jdthefixer
Mike
Are you a Whirlpool Water Heater Expert? Answer questions, earn points and help others
