Question about Home
Air switch is not working on the tub but when I blow into it it turns on what is up
  • kiellys Jun 01, 2010
    what I found was that after I had replaced the air switch I still had the same problem. But after changing out the electronic panel with the new switch box and some new wiring I got the pump to work thank you for the tip
    Scholar:
  • 81 Answers
If you can blow into the tube to turn your unit off and on then it sounds like the button assembly itself has zonked out. Those button assemblies by themselves are almost if not totally impossible to get by themselves. Depending on the color of your tub or if that is even an issue at this point, purshase an In-sink-erator air switch package and your local Home Depot/Lowes, and carefully cut open the package. I believe your options are chrome or white and you want to be able to return it without hassel if you need to. There are different kinds if button assemblies but generally all accept the same size air line. As a simple test, plug your new assembly into the line without installing it and see if it works. If it does and it fits your existing hole you have it. Be sure you only hand tighten the locking nut as it is plastic and if you break it it is NOT replaceable and you own what you bought. Also, In-sink-erator may now have different colored button assemblies available, so check that out too. Don't lose your original receipt!
Posted on May 31, 2010
My jacuzzi bath tub will not shut off.I have reset the breaker, blown out the plastic line and air is coming out the other end but still wil not shut off. We have only used this tub 2 or three times. Any...
It sounds like your pump in turning on/off with an air button on the top of the tub.
The pump not turning off could be either a bad air button, not sending enough air through the tub to operate the air switch in the motor or it could be a back air switch in the motor where the air hose attaches to it.
Take a large straw and blow into the air switch and see if you can operate the air switch on/off.
If it will turn on/off then you know you have a bad air button on the tub however, if you cannot get it to turn the pump on/off then you know you have a bad air switch in the motor.
Rod
US Parts Center
888-521-6183
Feb 26, 2013 | Home
I have the sa9592-02 bubble tub and my push button to start bubbles dose not start the moter
it sounds to me like the air button may not be working. You may have a small hole in the bellows which is the part that sends the air down the air tubing to the air switch in the motor. If there is not enough air being pushed down to the switch it will not activate the motor. You need a new air button or a new air switch in the motor. Pull the pump out and plug it into an outlet. take a straw and blow into the air switch while the pump is plugged in. it the motor turns on then you know you need an air button on the top of the tub. If the motor does NOT turn on then you need an air switch for the motor.
Feb 21, 2011 | Maax Calla 6042 Bathtub - 101058-000
I have a Jacuzzi tub and the vacuum switch will not turn the tub off. I had to turn the breaker off.
if when you push the air button it will not turn off the pump, it may be the button that is bad on the top of the tub or the air switch located in the motor.
take the pump out and plug it into an outlet. get a straw and blow into the air switch with the pump plugged in still. if it comes on then the button on the top of the tub is bad. if it doesn't come on then the air switch is bad.
Feb 16, 2011 | Jacuzzi Home
On off switch isnt working,i have to unplug tub to turn it off
When you push the air button and nothing happens it could be the air button is bad or could indicate the air switch in the motor is bad.
pull out the motor and plug it into a wall outlet. take a straw and push it onto the air switch, where the air tubing was connected, and blow into it.
if the pump comes on then you will need a new air button on the top of the tub. If however it does not come on then will need the air switch that is on the motor to rectify the problem.
Feb 08, 2011 | Jacuzzi Home
Our "whirlpool" tub jets do
sounds like it may be either the air button or the air switch (on motor).
pull the pump and plug into an outlet. take a straw and blow into the air switch where the air tubing was connected. If the pump comes on then you know the button. If the pump doesn't come on then you will need to replace the air switch on the back of the motor.
Feb 07, 2011 | Home
I puh the button on my whirlpool tub and it doesnt start anymore
This sounds like either the air button is not working or the air switch in the back of the motor has quit. You need to find out if the motor operates. If the motor comes on then it is a process of elimination. Check the air switch in the back of the motor and see if you can turn the pump on/off by blowing into the air switch with a straw. If it comes on by blowing in the switch then the air button is bad. If it doesn't come on then the air switch is bad.
Jan 11, 2011 | Home
I filled the tub, pushed the start button and all worked just right. When I went to shut it off it wouldn't shut off. I tried repeatedly. Finally had to get out of the tub and unplug it, (couldn't find any...
Sounds like either the air button on the side of the tub has quit working or the air switch in the back of the motor is not working.
Take the pump out. Get a straw, plug the pump into a working power outlet, blow into the straw into the air switch (where the air tubing was connected) on the motor. If the pump comes on/off when blowing into the straw then the air button on the tub is bad. If the pump will not come on or turn off when blowing into the air switch with the straw then the Air Switch is bad.
Jan 08, 2011 | Whirlpool Home
Hi my name is taariq i need find a part for my tub i have a whirlpool tub and i have switch that turns on the pump and it has a ruber tube comeing from the pump and runs to a switch on my tub i got to push...
this is a common problem. it will either be the air button on the side of the tub or the air switch located in the back of the motor. take the tubing off the motor and use a straw to blow into the switch. If you can get the motor to turn on/off then you know you have a bad air button on the side of the tub. if it doesn't come on then you know the air switch is bad.
May 20, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Maytag pav2300 wont stop filling up. New timer
After the water fill, Switch off the mains, allow little water bleed through the hose that goes to the level switch. As the water flows try fixing into the level switch block.
Clean the water drips to dry and switch on the m/c. It should be alright since you say that the switch is OK when air is blowed!
Apr 01, 2010 | Maytag PAV2300 Top Load Washer
Frigidaire GLWS1339EC Washer Overflowing
Do not blow to the switch. Blow from the switch to the tub. The blockage is soap scum in the air bell on the side of the tub. You may have to run a small wire into the tub area where the air hose attaches on the side of the tub.
Dec 05, 2009 | Frigidaire Gallery GLWS1339EC Top Load...
Home Logo
192 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
