Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Riding lawnmower will not start with key. I tried a new key switch and a new solenoid. I checked all safety switches and they checked out OK. I don't know if the wires for the solenoid are hooked up correctly, because I bought the mower used.
  • Brad Locke
    Brad Locke Oct 15, 2015
    How to connect a solenoid is not hard to do. I need to know if this solenoid is a three post or a four post. I know there is a lot of questions about to reconnect a solenoid. There are four post to deal with,two on top and two on bottom. The top two post are the largest.One post is for the battery + lead and the other is the starter wire connection,which is a + lead to the starter post. The bottom two have a spade type connectors. The red wire comes from the ignition switch and attaches to the first spade near the battery side of the solenoid,the other wire is the ground wire it connects to the spade connector near the starter wire,on the solenoid. If the solenoid is a three post,the same connections are the same for the starter. One wire the black ground wire,connects to the only spade connector. The only difference between the four post type solenoid and the three post,the solenoid has a ground to the frame using the ground wire provided. Hope this helps.Sincerely,Brad Locke
  • 66 Answers
Depend on the make and model of the mower....the safety switches usually are the seat, pto, shift lever, brake and clutch. If any of these are bad...the switch won't work. Can you cross the starter and have it start? With these safety switches....you can't just disconnect them to bypass. Most require a loop and running a wire from one side of the switch to the other will usually help you find the one causing the issue.
The solenoid comes in about 4 different models. Some ground to the frame and some don't. Not all key switches are the same either...we stock over 25 different switches and I could show you 7 that look identical but are different.
Personally I would start testing from the starter and work my way back...starter, solenoid, safety switches, starter switch. www.nnyparts.com
Posted on May 30, 2010
    Sergeant:
  • 344 Answers
Yes start testing from the starter on back, process of elimination.
Posted on Oct 15, 2015
My john Deere 110- 42" cut lawn mower ran out of gas and won't crank back. Noticed the parking brake is engaged but will still roll. What is my problem?
Hi Shannon, It's either fuel OR electrical, First check electrics, If it cranks but not starting......
How to test a solenoid....
How to test lawn mower solenoid
How small engine governors work....
How Small Engine Governors Work any governor setup
How to test lawn mower electrical safety switches....
Shows all safety switches disabled....
Disable all lawnmower safety switches
Apr 29, 2016 | John Deere Garden
Why after using my Kubota b2601 tractor I shut it off and when I went to start it all I get is one click
Hi Wilbur, The links below are YouTube videos that might get you out of trouble... Also there's videos down the right side of the links that may help as well....... I hope they help......... CHEERS....
How to test a lawn mower Key switch....
How to test lawn mower key switch
Apr 28, 2016 | Kubota Garden
Wont start
Hi John, The links below are youtube videos that might get you out of trouble... Also there's videos down the right side of the links that may help as well....... I hope these help......... CHEERS..
shows all safety switches disabled....
Apr 25, 2016 | Garden
Lawnmower TRY3.5PMLA - trying to find manual for this online as it currently won' start.
Hi Anonymous, I don't know if your mower is push OR ride on so the links below are youtube videos that might get you out of trouble... Also there's videos down the right side that may help as well....... I hope these help.........CHEERS..
https://www.youtube.com/watch?v=Xi3p465MN1E
Apr 24, 2016 | Garden
Why does engine cut back, even though the mower still cuts well?
Hi Anonymous, The links below are youtube video's, I hope this helps....CHEERS..
1st shows a craftsman mower with problems....
Craftsman Lawn Tractor stalling out
2nd shows a craftsman seat safety switch disabled....
Seat Safety Craftsman Disablement
3rd shows all safety switches disabled....
4thHow to test lawn mower electrical safety switches....
5th How to test a solenoid....
6th How to test a lawn mower Key switch....
Apr 16, 2016 | Garden
No power at all new selinod. starter checks good at shop new main relay new brake, blade, seat safety switches new ignition switch. can get power and started by running wire from one post to other on...
I would try cleaning grounds and all wire connections on solenoid, starter, etc. Get some emery cloth or a wire wheel and clean them well. Next, I would use a test light or a voltmeter and check voltage on small terminal on solenoid with key in start position. You may not be getting proper voltage to this terminal, thus not switching solenoid over. Also, try checking plug and harness connections on back of key switch for corrosion. Hope this helps.
Oct 01, 2013 | John Deere Garden
No power, new battery
Assuming that you didn't just aquire it, it's likely either a faulty solenoid or starter switch. If you just aquired it, it could also be a bad or disconnected seat or brake switch.
To test the solenoid, put a voltmeter between the chassis or battery NEG terminal and the small terminal on the solenoid. Does it have 12V when you try to start it? No? you need to test the start switch and the safety (seat and brake) switches. Yes? Check the voltage on the 2 large terminals on the solenoid. One should have 12V all the time, the other should have 12V when you try to start. Does it? Yes? bad or disconnected starter. No? bad solenoid. Testing the safety switches involves testing the resistance (ohms) of the switch. It should toggle between infinite and around 0 ohms as you actuate the switch. If it doesn't, it's bad.
May 15, 2009 | Briggs & Stratton Garden
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
653 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
