Question about Vizio VP322 32 in. Plasma TV
Have model vp322 that will not power on,any ideas?
Some people have said its a power supply,could that be the problem
    Sniper:
  • 67 Answers
THAT IS THE PROBLEM!! Your power supply board needs to be REPAIRED not REPLACED, replacing the board will just make the problem happen again in two years or less, if you can use a screwdriver you can send me the board and I will repair it for less than it would cost you to do it yourself ($50) with the correct components. Email for further instructions! Cory Schindler cschindler24@yahoo.com
Posted on May 30, 2010
  • Rocky Jun 02, 2011
    Hi first you have to make sure it is the power supply and not something else. You have to check and see if there is power getting to the power supply and if there is power coming at of it. You can find parts for this TV at www.interliquidparts.com
3 Suggested Answers
SOURCE: where can i find a power supply for a vizio vp322
You do not need a complete power supply; I am not an electronis expert but I followed the instruction on the internet and now the TV is like new. The total cost of the fix was around $3.00. If you want further help let me know I can walk you through it; essentially all you need to do is replace about three capacitors. Trust me it is not hard, delicate but not hard to fix.
Email: 099grout@gmail.com Good luck,,,
Posted on Nov 22, 2010
  • 302 Answers
SOURCE: vizio vp322 No power, no amber light. Replaced
Hi the first thing I would ask is are you sure that power supply that you bought is good? If you are sure your power supply I would check the power filter that connects the power cord to the power supply to make sure there is voltage getting to your power supply. If that checks out the only other thing to check is the signal board. You can check to see if there is power getting to your signal board if there is then it's provably your signal board. You can find parts for that TV at http://www.interliquidparts.com/products-page?product_search=vp322&view_type=default
Posted on Jun 02, 2011
The sound on my vizio model no is vp322 hdtv10a comes on for a short time and then it goes off and the only time it will come back on is when I cut hte TV off and after a while and the cut it back on.
You may have a bad power supply, or the voltage regulators on the main board are flaky. It may be a bad capacitor, generally a visible difference from the other capacitors will indicate the candidate.
Vizio has a recurring problem with \'adjusable\' voltage regulators on their mainboards that produce the sub-5 volts components desire.
So, it is a component that is heat sensitive, has a bad / cold solder joint, or possibly the power supply capacitor that drives the sound ICs and amplifier.
Oct 27, 2014 | Vizio Vp322 Hdtv10a Crossover...
I have the Vizio vp322 hdtv10a that doesn't turn on,I opened the back panel and found that the capacitors aren't bulging.
Hello, might need a Main Unit or Power Supply by the sounds of it. Try out a company named ShopJimmy.com for parts. I have used them with great success in the past. I included a link to their site from your model page. Hope that helps!
TeeVeeMan2@gmail.com
http://www.shopjimmy.com/catalogsearch/result/?q=vp322
Sep 06, 2011 | Vizio L32 32 in. LCD HDTV
My vizio vp322 hdtv10a was on then just turned off all of a sudden. When i tryd to turn it on the vizio light comes on but the screen is still black.
You need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some where.If otherwise,
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help to rectify the problem, and do take care in handling the TV, because it contains high voltages...
Jun 24, 2011 | Vizio VP322 32 in. Plasma TV
Vizio vp322 No power, no amber light. Replaced power supply board still no power, What else can be affecting this tv?
Jun 02, 2011 | Vizio VP322 32 in. Plasma TV
I have a Vizeo vp322. first it would not come on at all so I found the bad caps and replaced them now after 2 months it will work for about an hour then shut off. it appears there are no bad caps. any...
You will have to check your Vs, Va and 5 volts coming off the power supply to make sure they are exact. The Vs and Va voltages will be posted on a sticker on the top of the display panel on the back side. You are treading into an area that does require technical ability to rectify or you will waste money on un-necessary parts. In most cases when caps are going bad they fatigue other semiconductors, usually on the Y sustain panel. Plasma power supplies are totally different from LCD when it comes to just replacing bulged caps. I recommend a qualified technician look at this particular problem for you.
Mar 25, 2011 | Vizio VP322 32 in. Plasma TV
My vp322 visio will not power on
Power supply in your TV went from bad to dead. You can remove rear cover and try to locate bad capacitors (they will have bulged tops instead of flat ones). Replace them and see if it's going to resurrect TV. If not - whole Power Supply board have to be replaced.
Regards.
Russ.
Apr 04, 2010 | Vizio VP322 32 in. Plasma TV
Vizio VP322 HDTV10A won't turn on
I replaced 3 capacitors and fixed this problem. They were 1-10v 1000uF and 2- 10v 3300uF electrolitic board mount capacitors. Easy to spot on the power board, the tops were bulged up. $5.54 later it works perfectly now.
Dec 17, 2009 | Televison & Video
My vizio wont come on its like its no power
The Vizio VP322 is notorious for having bad capacitors on the power supply circuit board. They will probably be bulging and may have electrolyte leaking. I replaced four bad capacitors (with a different brand just in case) and fixed it. Total cost under $10. A lot cheaper and better than replacing the whole circuit board which may contain the same "faulty" capacitors from the factory
Nov 29, 2009 | Vizio VP322 32 in. Plasma TV
No power will not turn on
Check the fuses. And the Vizio VP322 is notorious for having bad capacitors on the power supply circuit board. They will probably be bulging and may have electrolyte leaking. I replaced four bad capacitors (with a different brand just in case) and fixed it. Total cost under $10. A lot cheaper and better than replacing the whole circuit board which may contain the same "faulty" capacitors from the factory.
Nov 17, 2009 | Vizio VP322 32 in. Plasma TV
Vizio TV clicking on and off at startup.
I fixed this problem by replacing the power supply board. The model number for my board is EAY42539401. It cost me $55 plus shipping. A Google search for the board model number should bring up a few suppliers.
Oct 04, 2009 | Vizio VP322 32 in. Plasma TV
Vizio VP322 32 in. Plasma TV Logo
998 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
