Question about Frigidaire PLD4375RFC Dishwasher
Dosen't seem to get enough water in machine - Frigidaire PLD4375RFC Dishwasher
  • 159 Answers
Are you on tank water or mains pressure?
some washers have to be told wether they are going to be using high pressure or low pressure.I would make sure all the filters in the dishwasher are taken out & cleaned very well & i would check any filters in the inlet hose that connect to the taps for any clogging.if that does'nt work you may have a faulty inlet valve.
Posted on May 30, 2010
Bosch maxx 1000
The fill valve may be clogged or defective
Oct 14, 2017 | Bosch Washing Machines
Ice maker water dosen't work
HI CHECK WATER SUPPLY FIRST.WELL ICE MACHINE FIRST.ITS ON RIGHT?LEAVER DOWN?IF ALL GOOD CHECK VALVE.GOOD LUCK.ALI
Jun 25, 2012 | kenmore.com
My mastermind 708 dosen't spin after wash cycle.It spins fine in the wash cycle but dosen't drain water or spin in the spin cycle.Pease help
Your empty pump filter is blocked with debris. If it can't evacuate all the water then it wont allow the spin cycle to start. Locate the filter (probably behind a little door at the botton of the front of the machine). Remove, clean and remove the debris, re-fit and all will be well
Jul 01, 2011 | Westinghouse Washing Machines
The middle and top spray bar does not seem to
Is there enough water getting into machine. I it fills until the float shuts off water valve the the pump or motor may be bad.
Jul 10, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Wash cycle water level
the water needed needs to just come up right under the door this is how much water they use cause they use a tumble wash to clean the clothes
low water preasure is a problem but also make sure both water inlets are being used (hot and cold) even if you dont have hot attach a y hose the machine needs both inlets in use
these machines use very low water usage but they still need a fill up point
Dec 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Hotpoint WM64 doesnt seem to be taking in enough water
Close your faucet valve & unscrew your hoses to check screens on hoses & machine. Clean out well. Refit, check for leaks. Water shd be in good pressure. If this is not the problem change your inlet valve, it is easily done. Suggestion: use powders for front loaders.
May 08, 2008 | Hotpoint WMA32 Front Load Washer
Candy Nova CD112 dishwasher
not enough water in machine
do you have hi or low pressure
when machine is washing try adding a extra litre of water manually eg milk bottle or jug
note the sound of washer before and after
if this improves then that is problem
Feb 22, 2008 | Dishwashers
Not enough water
run the machine empty. if the water comes to the bottom of the glass window, you're fine. No you don't need to see the soap suds either, too musch soap will cause the machine not to function properly and won't spin out all the water
Nov 15, 2007 | Kenmore 44832 Front Load Washer
My Tricity Bendix won't work
Check out the water inlet solenoid valve if this is clicking then it is probably the water level pressure switch which appears to be controling the flow of water mechanicaly dependent on whether the water is high enough in the machine and therefore giving enough pressure to close the switch .This may be stuck closed.
Oct 17, 2007 | Tricity Bendix 24 in. DH102 Free-standing...
Frigidaire PLD4375RFC Dishwasher Logo
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
