Question about Gateway FPD1565 (Black) 15 in. Flat Panel LCD Monitor
Gateway FPD1565 Monitor LCD, will not power on blank screen with slight flickering.
  • 11,361 Answers
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 30, 2010
Luxor 40 914 tvb
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 13, 2014 | Televison & Video
Erratic display
So your Gateway is brand new or a refurb?
Aug 02, 2008 | Computers & Internet
I've had my monitor for a year now and last night my screen went black. It flickered a few time before it completely turned blank. If you look closely you can see my desktop on the screen but it is almost...
pmeyers843, If in fact your LCD is only a year old, I would first contact Gateway to see if they could do some sort of swap-out with your unit whoose switch-mode-power-supply and/ or cold-cathode-fluorescent-tube power supply (called an inverter circuit) has failed prematurely. Yes, this does happen to a lot of monitors of all brands not just Gateway! But it is way more likely to happen after 36-48 months into the life of well used lcd monitors that have lots of "ON" hours use! I also suggest you pay a visit to youtube and view some videos of LCD repair to show what are some of the components that typically cause a failure similar to your's. Get back to me if you need more info. I hope that this helps to solve your BLACK SCREEN problem. I'mlouie12fix on fixya or lmistyrel@aol.com
Good luck. Bye for now.
Oct 01, 2009 | Gateway 19" Flat Panel LCD Monitor
Flickering screen (likea strobe light)
one check your refresh rate in windows boot the pc into safe mode if flickering is gone then lower your refresh rate if not replace lcd inverter board.
May 16, 2009 | Gateway XHD3000 LCD TV
Monitor goes blank after it comes on for two seconds
bad capacitors on the power board internal to the monitor they need to be replaced, let me know what you would like to do
Mar 22, 2009 | Gateway FPD2275W LCD Monitor
My Gateway mx7118 lcd flickers whenever screen is opened,closed,
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the laptop's LCD screen it means you have a backlight problem.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 13, 2009 | Gateway MX7118 Notebook
Monitor flickers on and off occassionally
it sound to be loosen connection from inside the latop..you must check the lcd cable and refix it tightly..try..i hve same problem that i fixed
Jan 04, 2009 | Gateway M320X Notebook
LCD monitor goes blank
It appears that the display resolution set in your display properties is out of the range that the LCD can display.
Try this.
Boot to the ENABLE VGA MODE by pressing F8 to get the Windows Boot Menu. If you can get to the desktop, then go to display properties, and see if you can change the resolution to higher settings and maintain video. (If the video blanks out, then it should revert to the previous setting in 15 seconds)
Aug 03, 2008 | Gateway FPD2275W LCD Monitor
Acer 1711 monitor won't power up
power supply of the monitor is the culprit.Generally defective electrolytics in primary section of Power supply.
Feb 18, 2008 | Gateway FPD2275W LCD Monitor
My Monitor flickers when computer starts
If "messing" around with the CRT connection on the back of the monitor causes it to work then I suspect there is some physical damage to. Specifically what connection/connector did you mess with? I can give you more advice if you give me more to go on.
Jul 15, 2007 | Gateway FPD1765 17" Flat Panel LCD Monitor
Gateway FPD1565 (Black) 15 in. Flat Panel LCD Monitor Logo
90 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
