Question about Gateway 835GM (835GH) PC Desktop
Installed windows 7 on my Gateway 835GM. I now get a blue screen on start up that says BIOS is not fully ACPI Compliant; ***stop:0X000000A5 (0X00000011, 0X00000006, 0X00000000, 0X00000000) IS THERE A SIMPLE FIX FOR THIS MACHINE OR DO I TAKE IT OUT AND SHOOT IT????? THANK YOU..dive4au@yahoo.com
You can try running "Startup Repair" from the Windows 7 DVD. It should reinstall the kernel designed for the non-ACPI PC. If that does not work, try and set the BIOS back to it's previous state by using the original operating system CD your Gateway 835Gm came with from the factory.
Posted on May 30, 2010
  • dive4au May 30, 2010
    Re: You can try running "Startup Repair" from the Windows 7 DVD. It should reinstall the kernel designed for the non-ACPI PC. If that does not work, try and set the BIOS back to it's previous state by using the original operating system CD your Gateway 835Gm came with from the factory.
    I have performed both options and continue to get the blue screen and error...is there anything else that can be performed?????
The bios in this system is not fully acpi compliant
Guess your computer is not compatible with Windows 7. Reinstall windows XP run compatibility test from Microsoft
May 16, 2014 | Dell Inspiron 15 (N5050)
BIOS Acpi Not Compliant
You will need to go to the website for the motherboard manufacturer and download the updated drivers for that motherboard. This is common with all the changes that windows goes through in a life cycle.
Nov 23, 2011 | Computers & Internet
The computer has work fine since we bought it
first check your hard drive..... if you can backup your files then format it and reinstall the operating system.
Jun 01, 2010 | Toshiba L505D-S6947 Notebook
Dell 8300 not loading xp home with the blue screen of death
To resolve this behavior, contact the manufacturer of your computer to obtain a BIOS that is fully ACPI compliant.
To work around this behavior, manually install the Standard PC hardware abstraction layer (HAL):
  1. Restart the computer to restart Setup.
  2. When Setup starts again, press F7 (not F6) when you see the "Press F6 if you need to install a third-party SCSI or RAID driver" screen.
Windows automatically disables the installation of the ACPI HAL and installs the Standard PC HAL.
Dec 30, 2009 | Dell Dimension 8300 PC Desktop
Dell Inspiron 1100 Bios and ACPI
Please contact your system vendor for an updated bios. If you are unable to obtain an updated bios or the latest bios supplied by your vendor is not ACPI compliant, you can turn off ACPI mode during text mode setup. To do this, simply press the F7 key when you are prompted to install storage drivers. The system will not notify you that the F7 key was pressed - it will silently disable ACPI and allow you to continue your installation."
RESOLUTION
Manually install the Standard PC hardware abstraction layer (HAL):
1. Reboot the computer to restart Setup.
2. When Setup starts again, press F7 when you see the "Press F6 if you need to install a third-party SCSI or RAID driver" screen.
Windows automatically disables the installation of the ACPI HAL and installs the Standard PC HAL. You should also contact the manufacturer of your computer to obtain a BIOS that is fully ACPI compliant
Mar 16, 2009 | Dell Inspiron 1100 Notebook
Windows 2000 setup
if this problem comes in blue skin ,then u must tel me about ur motherboard?
Sep 19, 2008 | Computers & Internet
Acpi complaint - reg
I have located some info on this board. it was released as a "Medion" board
there is some BIOS and driver stuff available HERE
http://www.medionusa.com/ and select customer care.. you need the exat model no or the serial no of the PC to continue though.
Also http://www.treiber.de/ may me of assistance as I think they are the real manufacturer but as I cannot read German I cant really be sure. they have the link to Medion on their webpage...
HIH and please post back results
Jun 23, 2008 | Intel Motherboard
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
41
Jan 17, 2008 | Intel Motherboard
Problem istalling windows 2000 professional on a pc with intel d945gcnl motherboard
try to make bios settings default and make a proper installation
The bios in this system is not fully ACPI compliant. Please contact your system vendor for an updated bios. If you are unable to obtain an updated bios or the latest bios supplied by your vendor is not ACPI compliant, you can turn off ACPI mode during text mode setup. To do this, simply press the F7 key when you are prompted to install storage drivers. The system will not notify you that the F7 key was pressed - it will silently disable ACPI and allow you to continue your installation."
Dec 04, 2007 | Microsoft Windows 2000 Professional for PC
Gateway 835GM (835GH) PC Desktop Logo
226 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
