Question about Canon PIXMA MP830 All-In-One InkJet Printer
What do I do to correct error code 5010 - Canon PIXMA MP830 All-In-One InkJet Printer
SOURCE: Error code 5010
comme caz.... si po agiustare sta mer...????
Posted on Dec 25, 2007
komguy
  • 2306 Answers
SOURCE: error 5010
On a Canon machine 5010 is a scanner error, stuck, light burned out, etc.
Posted on Sep 09, 2009
solofixya
  • 34 Answers
SOURCE: canon mp-830 error code 5010
That code is a scanner error. The scanner unit can not detect the home position or the scanner unit warming up is not done properly at power on. Most of the time the Scanner unit needs to be replaced.
Posted on Nov 11, 2008
  • 214 Answers
SOURCE: Error code 5010 and 5C20
on't know this error code, but this info might help
With thanks to a canon tech Ok Well again I will repeat this answer with a titch more detail.
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs replacement. A Pixma MP830 would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidently, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model. And its always a paper path error or purge unit.
I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow.
Procedure to reset Printer canon MP145 and Canon MP160 with Error Code Message for Printer Canon MP145 and Canon MP160, you can find error code message the end of this post:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Unplug cable power. (for MP145 / MP150)
6) Turn Off Power. (for MP160)
Error Code :
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
Posted on May 14, 2009
  • 523 Answers
SOURCE: ERROR CODE 5010
Hi Friend,
kindly follows the below 2 steps
1.Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
2.The MP510 may require repair
Unfortunately, the issue you describe seems to indicate that your product requires repair service. Canon has excellent service options and we are eager to provide any assistance you may need.
Regards,
Ayyasam
Posted on Jun 01, 2009
What are the error codes on my printer,5010 & 6100?
The 5010 error indicates a scanner error. The scanner unit cannot detect the home position, or the scanner unit warming-up is not done properly at power-on. On the LCD, "Scanner is not operating correctly." is displayed.
The 6100 error indicates a logic board error. The check sum value is incorrect in the ROM check at hard-power-on.
Fixing these errors is more expensive than replacing the printer. Sorry.
Fixing F
Feb 05, 2015 | Canon PIXMA MP830 All-In-One InkJet...
How to clear error code 5010 on canon pixma mp460 all in one printer
Check the manual that came with it for the answer to the codes.
Jul 20, 2014 | Canon PIXMA MP460 All-In-One InkJet...
MY PRINTER SHOWS 5010 CODE HOW DO I CORRECT THIS PROBLEM PLEASE ?
Error code 5010 indicates carriage lift mechanism error. That means that the carriage did not move up or down properly. You need to replace PR lift shaft assy, Sheet feed unit, Logic board assy, Carriage lift sensor unit. Before replacement of the logic board assy, check the waste ink amount (by service test print or EEPROM information print). If the waste ink amount is 7% or more, also replace the ink absorber kit when replacing the logic board assy.
Feb 21, 2011 | Office Equipment & Supplies
Error code 5010. what is it and how to correct
There are several reasons to get this 5010 error in your printer but the most common one will be you would have caused this after pulling the printer to bits to fix a blockage. You can fix this issue by inserting the ribbon cables from the scanner into the circuit board properly.
Thank you !!
Jul 03, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Error code 5010
Canon only lists three 4-digit error codes for the MP500: 1700, 1851, and 1856. After much research and finding many other MP500 owners getting this same strange code, I have come to conclude that it's the code of DEATH. Sometimes you may get strange codes if using compatible ink cartridges. Unless you can get the printer to reset and clear, the only other thing to try is to go back to the Canon driver download page and reload the correct driver: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=11995
Apr 25, 2010 | Canon Pixma MP500 All-In-One InkJet...
Printer will not print, error code 5010 is
5010 is a scanner error, either worn out scan lamp or sensors. Canon only replaces the entire scan assembly, if you like I can get part number and price.
Jun 23, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Error code 5010 for cannon mp460 printer
Hello, The error 5010 refers to a scanner issue, make sure all the connectors are seated and all flat cables running to the scanner unit are firmly seated, turn printer back on and the error should clear. I hope this helps.
Nov 10, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Re: Error Code 5010
Call Canon technical support.
Dial 1-866-261-9362, Monday - Friday 10:00 a.m. - 10:00 p.m. ET (excluding holidays).
See also a previous related question here! (a scanner issue)
http://www.fixya.com/support/t1232529-error_code_5010_cannon_mp460_printer
Sep 02, 2017 | Canon PIXMA MP460 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
1,930 people viewed this question
old marine
old marine
