Question about ViewSonic G810 21" SuperClear CRT Monitor
Power supply for viewsonic g810 monitor has failed. What can I do to recover the monitor, or should I just throw it out? Thanks, dspman
MrDallasIT
  • 91 Answers
SOURCE: Power light blinking on and off
You will need to replace the below failed caps.
2 - 1000uF @ 10V
3 - 470uF @ 25V
1 - 470uF @ 10V
Posted on May 18, 2009
Suricatta
  • 92 Answers
SOURCE: ViewSonic VX910 monitor has a power supply issue.
Your monitor have a bad condensator in the PSU.
The only thing to do is to replace the Power Supply Unit (very expensive, more than a new monitor) or if you have electronic tools, found and replace that condensator.(cheaper way...)
or
Have you connected your monitor with a new power cord ?
Best Regards!
Posted on Jun 29, 2009
FixinFax
  • 3085 Answers
SOURCE: Need Power Supply for VP2130 Viewsonic Monitor
try ebay, i've found a few for Samsung monitors there.
Posted on Aug 04, 2009
  • 20 Answers
SOURCE: hi, my viewsonic va912b monitor disply 'no
Try this first. Unplug the monitor power. Let it set for a few seconds and then plug it back in. This corrects this problem most of the time. If that doesn't work, try doing the same thing with the video cable. Disconnect it from the PC and then reattach it. The connections may have gotten corroded and are not making a good contact.
Hope these help you. because beyond that you are looking at either replacing the monitor or the video card.
Rich
Posted on Dec 16, 2009
budmrtn
  • 11361 Answers
SOURCE: How to get the power supply out of the viewsonic
Please look at my pictures here: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VA721/
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VA903B/
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VE710B/
It is alomost the same as 902.
Mkae sure to use good caps such as PANASONIC FM or FC series from DIGIKEY.
Posted on Apr 22, 2010
Hello,I am currently using a Viewsonic VX2235 monitor. When I turn on the PC the monitor stays black and it takes turning the monitor on and off several times to get it to work. Would greatly appreciate...
The problem you are having is caused by a power supply board that is starting to fail. Parts called capacitors start to fail and the power supply does not start up as it should and requires power cycling to get it going. Most VX2235 units use the DAC-19M010 power board. Here is a link that shows how to repair the board by replacing the bad capacitors.
http://www.ccl-la.com/blog/index.php/repairing-the-acer-al2216w-lcd-monitor/
I hope this helps, if so please rate my solution.
BuddyMc
Sep 18, 2011 | ViewSonic VX2235wm LCD Monitor
My viewsonic lcd has no power. What seems to be the problem? thanks in advance.
Look for bad caps first and main AC fuse, yours is very similar to VA702.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Sep 16, 2010 | ViewSonic VA703B LCD Monitor
I have a viewsonic g810 21" crt and it will make a snapping noise and the screen will zoom in and back out. How do I fix it?
PLease press reset botton on your monitor display and see any different. hope you find a good result.
Jan 30, 2010 | ViewSonic G810 21" CRT Monitor
Unplugged monitor at one location and moved to a different location and the monitor will not work..... Tried a different monitor into the same PC and it worked fine. Viewsonic continues to go into power...
Sounds to me that it's a resolution problem. I think that the previous monitor that was hooked up to it last had a different resolution.
That or try restarting, it may need to install a driver.
Jul 10, 2009 | ViewSonic G810 21" SuperClear CRT Monitor
2 - 1000uF @ 10V
3 - 470uF @ 25V
1 - 470uF @ 10V
May 18, 2009 | ViewSonic VX910 19" LCD Monitor
if that is a new and have a waranty why did back to the store and need for the replacement if the monitor has a warranty ...so just bring that and need for replacement...
Jan 15, 2008 | ViewSonic G810 21" CRT Monitor
Screen has 1 solid bright vertical line
a mylar capacitor 0.22mf 100v may be shorted besides the flyback transfomer.
Sep 30, 2006 | ViewSonic G810 21" CRT Monitor
ViewSonic G810 21" SuperClear CRT Monitor Logo
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
