Question about Boating
I need ignition switch diagram for 1997 Mercury 200HP EFI Nitro series Boat.
    Top Expert:
  • 45,204 Answers
Posted on May 30, 2010
I have to pat throttle to get the boat to go but not everytime it seems like its starving for gas. 2000 mercury 200hp
Hi Elaine.
Have a good look at the fuel lines and the primer tube, sounds like it could be drawing air ? or maybe the fuel filter could be blocked?
Good luck......
Mar 14, 2016 | Boating
1997 Nitro bass boat 640 LX. Where can I get an owner's manual?
Boat Manuals Now Available Free From Vessel Vanguard ...
www.passagemaker.com/.../boat-manuals-now-available-free-from-vesse...
Nov 14, 2013 - Boat owners are often frustrated by the diffi. ... I need complete operating manual for 2001 Nitro 175 Sport Fish ski boat. Peter Swanson April 6, .... I am looking for a Manuel for my Italian made 1997 AquaViva Frontier 6 meter cruiser. Thank you,. Jeff ... Have purchased 1989 Pro Craft Stalker 180 Bass Boat.
Aug 26, 2015 | Nitro Boating
Boat motor won't start. battery fully charged
The kill switch keeps the ignition from firing but doesn't keep the motor from spinning over.
Jul 07, 2012 | Nitro Boating
Have a 02 Mercury 200hp ME200L motor. Work fine
I would say its the coil from the "heat sink" that it goes through after shutdown. The mechanics probably can not duplicate your "ON WATER" conditions in a shop. They probably take off the hood cover for access, run it in a tank without the load of the boat, or just use the "Muffs" with no resistance on the prop or engine at all.
You may also be fuel starved. The checkvalves in the fuellines may be allowing the fuel to siphon back to the tank. The engine takes off good until the float chambers run dry, then you are trying to pull the fuel up and there is a lag. When you are "Working with the throttle" you are regulating the throttle opening to match available fuel. Also check the fuel screens if a Tech has not done so. Would be interested to know outcome.
Aug 02, 2010 | Nitro Boating
Yamaha 200hp out bord wiring diagrams(for boat)
Hello. your best bet is to go to any good book store and get the repair manual for that engine. it will run you about twenty dollars but, you will use it time and time again, I know I do. Joe
Mar 22, 2010 | Cycling
Not getting gas to motor on 150 efi,engine will try to turn over
need year and make? Tools(1) A compression gauge (2) a spark gap tester.(3) A Clymer service manual for your engine. (you can purchase from your local dealer). I know all these are expensive but if your going to be a outboard owner you will always need them. Troubleshooting (1) check compression. without the year and make I'm giving you a average numbers. Look at your Clymer manual for specific specs. all cylinders need to be over 100 lbs and equal each other within 5 lbs.(2) check spark. use a spark gap tester all cylinders should jump a half inch gap. if you have good compression and good spark, fuel is the problem nine times out of ten .Ethanol gas is proven to stay stable in fuel systems for only 30 days in 90 + degree heat. Drain gas tank,clean fuel lines replace primer bulb and replace all fuel filters. Yamaha has a gravity filter under engine cowl clean it. Finally replace spark plugs, I know spark plugs probably don't look bad but this is a outboard. Fresh spark plugs means less resistance for the ignition system. The ignition system is week compared to automotive. Test drive boat, if the problem is still there then there is further steps to take. Again I don't know the make so I guessing what fuel injected system. Pull out your clymer manual. what is great about the Clymer Manual for Novice techs is it gives detailed info on your outboard. Troubleshooting tips and teaches you how your outboard works. without the test information I would guess the electric fuel pump. but test everything first because a mercury efi fuel pump will set you back 600.00
Sep 15, 2009 | Nitro Boating
Now low end power on 200HP EFI Merc
sound like a throtle positioning sensor but you need to change your spark plugs first always if you havent already
Jun 04, 2009 | Boating
Boating Logo
241 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
