Question about Whirlpool Duet GHW9150P Front Load Washer
Fh code I'm getting the fh error code on my washer. There is no clogs in the water lines if i doe the test cycle then it will usually let me run a load of laundry but if i try to run another load i get the error code fh. So i then run another test cycle and it usually works again but now it won work that way either. I'm wondering if you have any suggestions. thank you E
  • 15,935 Answers
FH error indicates that either you have no water coming into the washer, or very little water. Since you can see it filling, the error indicates low flow. A flow meter
in the unit detects if 10.5 gallons fills the tub within 8 minutes; yours must not be. This will turn off the inlet valves and the error code will be displayed. Check the following:
- Make sure you don't have a siphoning problem. This occurs when there is no air gap for the drain line at the standpipe. The standpipe is the drain pipe at the wall where the washer drain line is placed. With no air gap, a vacuum is created, and water will begin to drain from the wash tub prematurely. To prevent this from occurring, follow this advice:
•The standpipe should be 2 inches in diameter to allow a sufficient air gap between the top of the standpipe and the drain hose.
•The standpipe should be a minimum of 34" from the floor, and should not exceed 72 inches in height.
•DO NOT seal the top of the standpipe. Many consumers seal the standpipe in the belief that this will prevent overflows, or get rid of drain odors. This often creates more problems than solutions.
•DO NOT place the drain hose too far down into the pipe. Water stays in the drain trap area of the standpipe. If the end of the drain hose rests in this area, no air gap is created, and this can also cause siphoning. 4 to 6 inches is sufficient.
•The drain hose length must not exceed 10 feet in length. Excessive drain hose length can cause drain problems and back wash.
- Verify Drain Pump operation. Unplug the washer and take the lower panel under the door off by removing the three screws under the bottom edge. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. Open the pump access and remove, once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there's nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
- Verify Flow meter operation and that the Pressure Switch hoses are intact and connected properly. Remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The flowmeter will be located on the left-hand side of the washer (facing from the front) between the inlet valve and dispenser. It's a small white plastic device with hoses attached. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a hose attached. There should be a tech sheet directly behind the panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics, how to locate the components mentioned, and the specific measurements required in determining if the components are good or bad.
"F/H" indicates that either you have no water coming into the washer, or very little water.
If you have NO water coming into the wash tub after 30 seconds the error code is displayed. Check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, and after 8 minutes, 10.5 gallons of water has been detected by the flowmeter, but there has not been a detected a Pressure Switch trip, the inlet valves are turned off and the error code is displayed. Check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions: http://www.fixya.com/support/r587481-prevent_washer_siphoning
- Verify Flowmeter operation.
- Verify the Pressure Switch hoses are intact and connected properly.
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. If not, click on the following link to check the pump for obstructions:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
To access the Flowmeter and Pressure Switch - remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The flowmeter will be located on the left-hand side of the washer (facing from the front) between the inlet valve and dispenser. It's a small white plastic device with hoses attached. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a hose attached.
There should be a tech sheet directly behind the panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics, how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 18, 2010
I was getting the F H error code on my washer. I hit cancel twice to clear the code to see of a cycle restart would remedy. Now the wash cycle is stuck on 45 min. remaining & the cancel button is no...
The FH error code on your Kenmore Elite washing machine is an indicator that there is a problem with incoming water. When there is little water coming into the machine, the FH code will appear and the washer will stop. There are a couple of common problems you can check while you are resetting the FH error code. You will need to remove the power supply to the washer to reset the code.
  • 1 Look for the "Pause/Cancel" button on the washer control panel. The button will be below the digital time clock and to the lower right of the wash cycle selector.
  • 2
    Press the "Pause/Cancel" button twice to cancel the wash cycle. Unplug the Kenmore Elite washer from the wall outlet.
  • 3 Check for kinks in the water supply hose while the washer does not have power. Turn off the water supply spigots and remove the hoses from the back of the washer. Check the port screens at the hose connections for sediment buildup and clean as necessary.
  • 4
    Connect the water supply hoses back to the washer and turn on the water spigots. Plug the washer cord back into the wall outlet.
  • 5
    Select the wash cycle and press the "Start" button.
  • Apr 29, 2013 | Washing Machines
    I have a Epic Z Model # mhwz600tw00. When I select a wash cycle and press "start" it shuts off. It will complete a "spin" cycle without any issue. I checked the supply hoses and...
    Hello Jeff,
    Does the machine just shut off or do ya have a error code when it shuts off?? Typically when it will not fill with water for what ever reason their is FH error code. In addation to that since the cold water was clogged,very likely what ever caused it to clog up also has clogged the filter screen on the water inlet valve where the hoses attach to,to check/clean the screen remove the hoses and usea small screwdriver to pop out the screen and check/clean it. If ya find that the screen is clean ya may very well need to replace the water valve.
    Be sure to get back to me and let me know about what error codes come up and i could help ya to better narrow down the trouble with your washer.
    Thanks for using Fixya,
    Gene
    Feb 29, 2012 | Maytag EPIC MFW9700S Front Load Washer
    FH IS FLASHING ON THE WASHER AND IT HAD STOPPED WORKING ONLY 5 MNUTES INTO ITS CYCLE
    The FH error code means the computer on the control board didnt detect any water entering the washer..sometimes it doesnt detect the water entering because the filter screens on the water inlet valve are clogged with sediment and water is having a hard time entering the washer.
    The filter screens can be checked by turning off water at the faucets and disconnecting the fill hoses from the back of the machine and pop the scrrens out of where the hoses connect at the washer and check for blockage in them. If they are found to be clean check the water coming out of the hoses before connecting them back to the washer...if the screens are clean and water pressure is good out of the hoses the part of the washer called the FLOW METER would need to be replaced
    GENE
    Sep 11, 2011 | Maytag EPIC MFW9700S Front Load Washer
    FH appears
  • 2
  • 3
  • 4
  • 5
  • If the error code come back you will probably have to change the water inlet valves. No hard to do and you can fdo this yourself
  • Dec 14, 2010 | Whirlpool Washing Machines
    Keep getting FH beeping problem...even with NO detergent...anybody got an idea? tried running a cycle in sanitation, with cup of bleach to see if its clogged due to my well water high in iron...
    "FH" is a No Water Detect error.It is an indication that you either have no water coming into the washer, or very little water at all. Check whether the water taps are turned on sufficiently, the inlet hoses are not kinked, the water inlet valve is not clogged, you don't have a siphoning issue, and/or the drain pump is working.
    Thank you !!
    Jul 15, 2010 | Whirlpool Washing Machines
    Error code FH on my AWM, what does it mean?
    Thank you !!
    Jul 12, 2010 | Whirlpool AWM8163 Front Load Washer
    Getting a code F then H
    Hi, "FH" is a No Water Detect error.It is an indication that you either have no water coming into the washer, or very little water at all. Check whether the water taps are turned on sufficiently, the inlet hoses are not kinked, the water inlet valve is not clogged, you don't have a siphoning issue, and/or the drain pump is working.
    Apr 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    A few seconds into a wash cycle the letters F H flash and beep and the cycle won't continue. what does this mean??
    fh means fill hose make sure that water is comeing out of each hose by detaching from washer and filling a bucket. does water come out of hot and cold? check and make sure your fill valve washers are not clogged with sand. if neither of these things fix it I believe you have a bad flow meter. take the kick panel off by removing the 3 torque screws look to the right side you will see the tech sheet. read the fh error code. let me know how it goes. Do you have flood stop hoses if so get ride of them right away they cause a ton of problems with all washers.
    Jun 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Error FH Maytag front loader MR@9700sQ1
    Your drain is clogged, not the one in the wall where the drain hose goes, but the internal drain, you have to use a 7mm quarter inch drive socket and a 2 inch or longer extension. There are three screws at the very bottom of the washer which must be removed. When standing you cannot see these screws, you have to lay down and look under the washer, between the feet of the washer to find them. Once the bottom cover is removed there is a "cylindrical box" thing with a front cover, the front covers is simply screwed into the cylindrical box housing, unscrew it. Warning, there is a lot of water in here so don't be sitting when you remove it. When you get it open you will discover that this is the internal filter, you'll find small socks and coins and god knows what else in here. Now follow the drain line out and feel it from the outside by pinching it to see if it is clear, if it is clear it should compress quite easily if it is clogged remove it and **** it out with a wire hanger. Reassembly is the opposite of disassembly. This should fix you error message. And buy the way if you remove the top cover there is a "Technicians Manual" stored inside the washer under the top cover that describes some of this procedure and defines all of the error codes.
    Apr 16, 2009 | Maytag EPIC MFW9700S Front Load Washer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    Dan Webster
    Dan Webster
    Sal DeAngelo
