Question about Dometic RM2620 Refrigerator
No cooling on 12v or gas
Have older Dometic RC160 refrigerator. Works good on 120V, but does not cool when plugged into 12v, or gas mode, burner works and blue flame.
  • 327 Answers
Hello,Depending on the age of the unit, it could have a compressor going bad on it, as the compressor gets hot the valves may not be seating correctly or may be burning out.
You may have also lost some refrigerant, but I am going to lean more to a bad compressor.
Thanks
Posted on May 30, 2010
Freezer gets cold frig is hot. I replaced theromister.did no good
If your Dometic refrigerator is a tri-power model (12V, 120V, lp gas), check all modes. It is not uncommon for these units to fail to cool adequately in 12V mode, as that mode is only for KEEPING things cold while on the road.
If the failure exists only in 120V mode, replace the 120V heating element. If the failure exists only in lp gas mode, replace the burner and make sure that the jet is clean.
If the refrigerator does not get cold in ANY mode, verify that the door seal is making good contact all the way around and, if it is, you'll need to replace the coil assembly. (They are available on eBay and Amazon at a fairly reasonable price.)
May 20, 2015 | Dometic RM2652 Refrigerator
Dometic RM2652 was working fine then stopped - no lights at the control panel above the doors.
Usually there is a short in the system when fuse is blown. Check the cord as sometimes mouse can damage the cord. It is a posibility.
Check power to the electronic board.
Jan 28, 2015 | Dometic RM2652 Refrigerator
I have a Dometic RM 2620 fridge, that won't cool. A squirrel got into wiring, I have taken care of wiring but will not work on gas or AC. Spark igniter will no spark either. Any ideas?
Since I don't know what does work I am kind of shooting in the dark.
Does the ac heater get hot ?
The spark ignitor is part of the control board. But won't work?
I assume that you have a user manual but I am including a link to download one.
https://www.dometic.com/f6e8a773-69f5-4624-9b35-54e8801da7af.fodoc
Note that there are three fuses. B (12V control) and C (120V Heater) on the control board and a thermofuse L located on the stack.
If L is good and everything else is good there should be 12VDC on J1 and at Fuse B
Sep 19, 2014 | Dometic RM2620 Refrigerator
Dometic Fridge Intermittent on 120V
the dometic fridge you mentioned was outsourced by Dometic and they are having problems. (unit 2652) call dometic at 18888674188 and give them your mod and serial number.
May 26, 2012 | Dometic RM2652 Refrigerator
We have a 1993 Wilderness RV with a Dometic refrigerator, brain box being of Dinosaur brand (which is ok - reaching 120 volts) Our question is on the front freezer door of the fridge is a strip plate...
Hi
Most of these mobile refrigerators can run on gas, 120v or 12v, your gas option is obviously OK, there should be electrical connections on the back of the unit which identify which cable are 12v and 120v.
Again most but not all units were multi option.
You will need to connect these points to the supply. To run this on mains 120v you will need to switch off the gas and 12v, similarly for 12v, no gas or 120v, and for gas no12v or 120v.
If you get the fridge to run on 12v remember that if it is on overnight it can reduce the battery charge.
The best options for these is gas or 120v when you have a mains hook up
Hope this helps
Gordon
Apr 18, 2011 | Dometic Refrigerators
Unit cools fine on 120V, selecting GAS CHECK light on.
Do you hear a clicking sound If not. there is a black box inside the out side door. Check the fuses in it.
Ken
Sep 23, 2009 | Refrigerators
My 3-way Dometic fridge works on gas but stopped working on 240V! ....Why?
With the 240V element diconnected, test it with an ohm meter to find it was open circuit. No heat! The 12v element still had resistance.
At the moment gas is still keeping my cool while I wait for a new element to arrive. ..... cheers
Sep 01, 2009 | Dometic RM2652 Refrigerator
Dometic rm2652 frige just stopped working, gas nor
Check 12V supply and fuses on lower board. If display functions okay, then look for yellow residue on back of refrigerator near burner. If yes, then cooling unit has leaked and needs to be replaced. See if recall kit has been installed, and check for 12V at both sides of limit switch. If no power on either side, then thermal link has blown, and need to be replaced, If 12V on one side, but not the other, than limit is tripped, and needs to be reset, by pushing button, or if not resetting, then replace, Check for obstructions to the bottom and top vent to make sure they are not blocked, On models with top side vent, check cooling fan for proper operation.
Aug 22, 2009 | Refrigerators
Dometic RM2193 Works on 120V, but not on gaz. I succeded in cleaning the burner jet and I get a flame. It ligth well now but the flame very small. The frig doesn't cool. Help ?
These fridges require that the control switches be in the correct position for the power source you want to use. If you try to operate the fridge on gas and have the electric 120V-AC switch on, all you'll get is the gas pilot light to stay lit. Also, when running on gas, the electric has to be off.
Here's a link to the manual for your unit. Print a copy and save an electronic one for future use, in case you lose your printout.
http://www.alcovr.com/DATA/MANUEL/DometicRefrigeratorModelsRM2191&RM2193.pdf
Hope having the manual helps you to get the fridge working on all the power sources you need! Best regards!
Jul 03, 2009 | Dometic RM2193 Compact Refrigerator With...
Dometic RM2620 Refrigerator Logo
323 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
