Question about Malibu ML600TW - Low Voltage Power Pack - 600 Watt - With Timer and Ground
Tonight the lights don't come on
Everything was working fine but tonight the lights didn't come on. I have power to the outlet and the timer seems to be working. what's up?
Open following for Power Pack troubleshoot checklist and warranty information and other tips to keep power pack working longer:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on May 27, 2011
MITSUBISHI WS55907 Diamond 1080 TV bought in 2000 was powered off, unplugged, for a year. Turned the set on with remote last night and worked fine, had very crisp picture.
Your TV was waiting between 2000 and now to suffer power supply failure. It is very frustrating to go from everything working perfectly to nothing.
Oct 31, 2016 | Mitsubishi WS-55907 55" Rear Projection...
I just moved into a new house and it has lighted sidewalk and lighted flower garden its all ran through a malibu timer the timer seems to work fine but when on theres no power to the lights anyone hav
1) Copy following link for troubleshoot resources and tips
2) Outlet has power if dial is turning.
Install new trippers.
See if override works.
Change bulbs.
Match bulb wattage to watt rating of transformer.
Feb 28, 2013 | Malibu Hardware & Accessories
Installed 8 low voltage lights with a malibu digital 120w timer 2 months ago. The timer does not always work. I'll unplug then power up the system and then the lights turn on. Never had this problem...
Timer is not identified:
Open following link to see low-voltage digital timers and then add a comment if needed:
Page also has links to warranty information, and list of advisories so power pack lasts longer.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#digital
There are 2 likely suspects: Bad timer, or electrical problem.
There is no repair for bad timer, but timer has warranty through the manufacturer/ Malibu.
Electrical: Since power pack worked correctly before, then outlet probably has correct polarity, but I always suggest checking outlet with circuit analyzer.
Also plug lamp into same outlet and see if there is flickering that would indicate loose wire. Wiggle circuit breaker and see if lamp flickers. Move the outlet and see if lamp flickers.
Outdoor outlets get loose wires because of exposure to temperature and dust and moisture. Replace outlet and don't use the quick connects, instead use screw terminals.
If possible, move timer to different outlet on different breaker and see if problem persists.
Oct 05, 2011 | Hardware & Accessories
Using Lowes mechanical timer in Hadco TC654-15 landscape lighting transformer. Have tried 3 timers now and timer clock does not work when plugged into the transformer. if I bypass the timer, low voltage...
Always a good idea to check outlet with cheap circuit analyzer.
And move timer to different outlet to see if difficulties are outlet-specific.
Try timer at neighbor's house.
Having 3 defects in a row is unusual.
There are no repairs for defective timers.
Timer clock motors stop working for many reasons, bad manufacturing of plastic gears and power surge and dirt and reversed polarity among the causes.
Using household plug-in timer is typical solution since clock modules are not sold separately.
Following link gives tips for having low-voltage power pack last longer, in case you decide to buy Intermatic-Malibu from Home Depot:
Aug 31, 2011 | Hadco TC151-12TP Accessory Transformer
Need instruction manual for outlet timer#59732 Model#DT300 125v/60Hz 8.3amp/1000watt resistive. Only other #s isee 227259
Open following links for possible DT300 manual:
I don't see load rating in manual, but 1000Watt would be typical for timer with 2-prong outlet.
http://waterheatertimer.org/pdf/DT300-series-manual.pdf
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#DT300
If manual is not correct:
Other folks have asked for DT300 manual, but didn't like provided manual.
Timers can have many different numbers, and different timers can go by same number:
1) Add a comment with link to in-focus photo of timer posted on Flickr, for possible identification.
2) Open following link to help identify timer:
http://waterheatertimer.org/Woods-timers-and-manuals.html
Aug 07, 2011 | Woods 17321 Outdoor Power Strip Timer with...
My hp f4280 printer don't have power to on.
hi misssim31, if the printer is not turning on..there might be a possibility that the power module is already faulty. if the power module light is lit up (the green light on it) try to plug the cord into different wall outlet and if it didn't worked..change the power cord and the module..and still if it didn't worked then the port on the back of the printer where you plugged the power cord is no longer working.
if you have any further question..dont hesitate to reply..
thanks
May 29, 2011 | HP DeskJet F4280 All In One Printer InkJet
Came back from week long vacation (was working fine when we left) Went to start it tonight and doesn't work? seems like it is dead?
check for power at the outlet that it is plugged into under the sink,, one of the GFI outlets could have tripped or is broken.
c...
Feb 21, 2011 | Jenn-Air Dishwashers
I have a Woods Outdoor Lighting timer - model no. 961012, with a 3 outlet powerblock that I have connected 2 lighted Christmas decorations. I had it set for dusk to dawn, and everything was fine until I...
http://waterheatertimer.org/Woods-timers-and-manuals.html#yard-stake
If this is not your timer, add a comment.
A number of folks are writing in about dusk-dawn-timers flashing.
The manufacturer suggests turning photo-eye away from all lighting when installing timer.
Always aim photoeye toward dark region of yard.
I would unplug the timer and let it reset.
Try timer again, turned away from lights so there is no feedback.
Put black tape over photeye and see what happens.
If timer still doesn't work, then timer is defective.
Maybe photoeye circuit was overwhelmed by intense light converted to electrical input.
I test timers, and 4-6% arrive defective, and most last just a season or two, and then you buy another, but the price is affordable.
Local Home Depot sells the GE 15107 outdoor yard stake or wall mount.
I bought one tonight for testing.
It has no photo eye
It has a dial timer where you set exact on-off times by moving plastic segments on dial perimeter.
For example set timer for ON at 5:30 and OFF at 6:00 am depending on your latitude north or south.
geno_3245_189.jpgphoto eye on yard stake timer
Dec 16, 2010 | Woods Outdoor 3 Outlet Yard Stake With...
One year outdoor lighting (300V #135708) Transformer not working
You need to disconnect the lighting load completely from the transformer and check it's output. If it is dead unloaded, replace the transformer. If it seems to work now, then some part of the lighting circuit has probably shorted out. If there are several circuits coming to the transformer, attach each one separately and recheck for power. When one is attached that kills the output, investigate that circuit. Check for any broken lamps first, then the wiring must be opened at each lamp location to check for a local short circuit. A somewhat tedious fix. Hope this helps!
May 24, 2010 | Intermatic Malibu 300W Power Pack...
Htr-5730 yamaha reciever
try another outlet sounds like you may have a short in either your power cord/supply or your outlet is acting up with the wiring
Feb 22, 2008 | Yamaha HTR-5730 Receiver
Malibu ML600TW - Low Voltage Power Pack - 600 Watt - With Timer and Ground Logo
126 people viewed this question
Top Malibu Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
jdthefixer
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
