Question about GE Adora GHDA654LBG Dishwasher
The water in the sink is returned to the dishwasher
  • 159 Answers
The sink pipes may be backing up or the washer outlet hose non return flap is not working anymore & water is back flowing into dishwasher.
Posted on May 30, 2010
Water backs up from the drain in my dishwasher and smells. what is the problem?
Two things can cause this problem:
1. The check valve in your dishwasher may be defective, allowing water and food debris to seep (or run) back into your dishwasher.
2. Your drain hose may not be "mounted up" the way it should be. Look under your sink. Look at how your drain hose is connected to your garbage disposal. If the hose runs down to the floor of your cabinet and into your dishwasher, that is wrong. Instead, it should be mounted up so that water from the sink and garbage disposal would have to flow up first to get into the dishwasher. If you do this, then even if you have a bad check-valve in the dishwasher, it will prevent the problem (or greatly reduce the problem) of dirty water flowing back into your dishwasher.
May 17, 2015 | Kenmore Elite Stainless Steel 24" BuiltIn...
Electrolux professional series not pumping water
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Aug 08, 2012 | Electrolux Frigidaire Professional Series...
My Frigidaire dishwasher has dirty water.standing in bottom. Dishes are not clean
Aug 08, 2012 | Dishwashers
Standing water in dishwasher
Jul 30, 2012 | Frigidaire Dishwashers
Frigidaire gallery dishwasher model#DGHD2433KF1 water droplets remaining on top lower water not draining all the way leaving an odori
Jul 20, 2012 | Frigidaire Dishwashers
Electrolux error code 1, how to reset.
Also got error code 01. Unplugged dishwasher, turned off water supply, disconnected water supply line at sink so it had slack to pull dishwasher out of built-in space, removed two wood screws holding dishwasher to counter, pulled it out onto floor, put it on blocks as reader suggested, tilted to side 45 degrees, water drained out onto rags. Then restored to upright, restored supply line and opened valve at sink, plugged back in, unit automatically reset, returned to built-in, reinstalled screws to counter. Worked like a charm. Took more time to read everyone's advice than to do the job (about 30 min.). Thanks.
May 20, 2010 | Dishwashers
Miele G858SCVi Plus dishwasher intake drain button is flashing and washer will not fill with water. We had a pluged drain and tried to use a plunger on it and water backed up into dishwasher. ...now it...
hi,
the unit will not fill with water until it will drain as it needs to complete the drain function before it can move onto the next step.
make sure the non return valve under the filter is properly fitted in the sump of the unit. then check the drain spigot under the sink where the drain hose connects to the sink u bend. This is the most common causes of a blocked drain.
Nov 28, 2009 | Miele 24 in. G656SCi Plus SS Built-in...
Non return valve
Has it always done this? If so it was an install issue. The tech should have put the drain above the drain with a loop to prevent backfill.
Jan 26, 2009 | Dishwashers
Water in the dishwasher after the the cycle is complete
Nov 19, 2008 | Whirlpool 24 in. GU1200XT Built-in...
Miele dishwasher g843 scvi water backed up on bottom of unit
When you drain the sink the water will go to the path of least resistance. Disconnect the dishwasher, cap the hole and see if water drains. If not then you have a plumbing issue.
Inside the dishwasher there is also a non return valve located in the sump. This should prevent water from entering the unit. Make sure it is in correctly.
Sgt 48
Jun 01, 2008 | Miele 24 in. Incognito G843SCVi Built-In...
GE Adora GHDA654LBG Dishwasher Logo
59 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
