Question about Panasonic Panafax UF-490 Plain Paper Laser Fax
Comm. code 400
I am unable to transmitt & the receiver tells me that they don't have a problem with anyone else, but I still get the comm code 400
  • 33 Answers
The 400 code is some cases is due to incorrect transmission levels, try turning of memory tx and send directly, or could try adsl filter on the line if needed, there are things that techs will be able to adjust if necessary
Posted on Jun 15, 2008
What can I do about a Gree Ductless A/C Unit with error code E6
It's newly installed. Why won't the installer troubleshoot and repair?
Communication line is just that. It will communicate via millivots or milliamperes. Voltage present must be induced, directly or indirectly. Shielding will help if it's grounded but if the installer did not ground then there's your problem. Higher voltage lines in contact with the communication lines will induce voltage into your comm line. Time to get a light and start looking for some of these things if you can't get your contractor / installer back out.
Mar 21, 2017 | Heating & Cooling
Solve E6 error code on Gree Ductless 12000BTU Heat Pump
New installation should be covered by your contractors. Maybe BBB or local TV station (although I hate all the individuals involved) could help. You might try asking how long the contractors intend to stall before you are forced to resort to the media.
To answer your question, the common wire should be at ground potential. That means zero volts relative to your local ground (cold water pipe or other provision. If you can't trace it, the contractor should be able to. If other circuits are normal, it's in that line which should be off of it's own breaker.
I can't tell anymore than that without seeing your entrance.
Sep 01, 2014 | Heating & Cooling
My dodge journeys cd player say
My cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix this
Jan 03, 2012 | 2010 Dodge Journey
I have error codes flashing on my thermostat..it is an american standard model the manual for the therm. has ACOT900AC43UA on front..says to find addedum 18-HD32D2-1/69-2009 for codes i cannot find it...
Error codes from American Standard Pub 18-HD32D2-8, which is a one-sheet document that came with my American Standard air-conditioner:
29 = not listed
129 = not listed
80 = HPCO Fault - problem is in outdoor unit - Desscription: High Pressure Monitor Fault (hard lock out, cycle power to reset)
91 = Communication Inactive Fault - problem is in air handler - Descriptions - COMM Bit Master Clock Error, COMM Heat/Cool Demand Error, Serial Motor Communication Inactive Error
91 = Communication Fault - problem is in furnace - Descriptions: Blower motor no COMM response, Inducer motor no COMM response, Loss of heat/cool demand, Loss of clock signal
91 = Communication Fault - problem is in outdoor unit - Descriptions: Loss of Heat/Cool Demand Message (COMM), Loss of Bit Master (Clock Signal)
91 = Communication Fault - Description: Comm line is dead and no bits have been received.
By the way, I do not recommend American Standard. I've had mine 14 months and it just blew up - the entire control panel blew. My advice to you - think about a different brand.
Nancy
Scottsdale, Arizona
Aug 22, 2010 | American Standard Heating & Cooling
Panasonic Panafax UF-790 Fax did not complete logging into memory. Comm. Journal comm. 212 What do I do?
its a receiving error code means a computer was trying to fax you and it didnt connect properly
Nov 12, 2009 | Panasonic Panafax UF-790 Plain Paper Laser...
Units don't comm. with each other.
Check your PL DPL code, YOu will need to program both radios the same way.
go here for the owners manual.
http://www.dxclube.com.br/files/Motorola_talkabout_T5000_5500_User_Guide_EN.pdf
Jul 11, 2009 | Motorola TalkAbout T5000 2-Way Radio
Incoming Fax Error
Maybe depends on poor phone connection from this sender, caused by bad line or a transmitt problems. In faxsettings All fax, change "error correction" to off and "V34" faxspeed to slow, this will help.
Nov 10, 2008 | HP LaserJet 2840 All-In-One Printer
ERROR MESSAGES
nthemba- all the error codes you see indicates phone line condition or error at reciving fax's end. For more details you can refer to
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu02549&lc=en&dlc=en&cc=us&product=79477&rule=17804&lang=en
Sep 10, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Rx comm error 200082 on receiving fax Ricoh aficio 222SF
I have Dell Monolaser MFP1125, can not send and receive fax
Aug 04, 2008 | Office Equipment & Supplies
Faxman.comm win error
i have a x3450 printer i can't get faxman.comm off my computer. i can't use it please tell me how to remove.it is causing me a promblem.
Apr 15, 2008 | Lexmark X3350 All-In-One InkJet Printer
Panasonic Panafax UF-490 Plain Paper Laser Fax Logo
299 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
