Question about Belkin 4-Port USB Hub
Problem with deviceBelkin F5U404 hub
I plug a Belkin F5U404 hub into an HP box with Windows/7 64. The hub is recognised, but a device plugged in to the hub is not seen.
Any Thoughts?
5 Suggested Answers
  • 102 Answers
SOURCE: Belkin 7 port hub will not work with imac & leopard
Try any other power outlet source on the wall. Are you using the same adaptor to power up the new usb hub?
try the adaptor that came with the new usb hub. Most likely its the power source either the adaptor of the hub or usb hub or the wall power supply. Its strange that the new one is doing the same thing?
Let me know!
Posted on Dec 22, 2007
  • 3 Answers
SOURCE: my computer does not recognise my Belkin 7 port hub.
sometimes the power it gets from pc fails but if it is powered alone check outlet or strip
Posted on Oct 05, 2009
SOURCE: Belkin F4U017 7 port USB
I just had the same problem and was able to figure our a permanent fix.Judging by the date of you post, I'm guessing you've already remedied this problem one way or another. But just in case you haven't or someone else is having the same problem, I'll go ahead and post what to do. First, make sure you leave the USB hub plugged in right now so that Device Manager lists what it thinks is the Bluetooth device. Go into Control Manager > Hardware & Sound > Device Manager. Right click on Bluetooth device that is showing up in error. From the dropdown box, select Properties. Click the Driver Tab. Click Uninstall. Check "Delete the driver software for this device." Click OK. Unplug your USB hub for a few seconds, then plug it back in. Windows should now recognize it as a "Generic USB hub." You should be good to go. Just remember not to install that update again or try to update the driver for the Generic USB hub. If you do, you'll end up with the same problem. I hope this helps someone out there.
Posted on Jan 10, 2011
ib_yang
  • 1098 Answers
SOURCE: Belkin 7 Port Hub has power (red light is on). Has
Hi.
I would like to know if you have tried hooking up this USB device to a different computer. There is a possibility that this hub is underpowered that it why it is no longer recognizing the usb devices.
Since the hub is still warranty, I suggest that you send it in for a replacement or repair.
Thank you!
Posted on Feb 04, 2011
Does the F5U237 work with windows 8.1
It looks like Belkin stop support on certain models of Belkin, even thou you don't state the version model. But if you have a chance, visit this microsoft website which explain that it's not compatible with Windows 8.1
http://www.microsoft.com/en-us/windows/compatibility/CompatCenter/ProductDetailsViewer?Name=Belkin%20N%20USB%20Wireless%20Network%20Adapter&vendor=Belkin&ModelOrVersion=F5D8053&Type=Hardware&tempOsid=Windows+8.1
Oct 19, 2014 | Belkin (F5U237) 7-Port USB Hub
I purchased a Belkin 4 port USB hub today and connected my Seagate external hard drive. Unfortunately my computer, Toshiba Satellite L655D, doesn't recognise the hard drive when located within the...
This is likely due to power consumption, if a hub doesn't have it's own power adapter, then it is drawing bus power from your computer, and will not have enough power to drive larger devices.
May 07, 2011 | Belkin Electronics - Others
Usb drive not recognised
First of all THe Belkin F5u237 is not a USB Drive. It is a USB Hub. If your running Windows XP it should see any device connected to the hub. If it dosen't see anything connected you may need to add the power supply to the hub.
Dec 14, 2010 | Belkin (F5U237) 7-Port USB Hub
Belkin F4U017 7 port USB hub Connected to a Windows Vista 64bit computer Windows updates are automatic When plugged into the computer, Device manager reports the hub as a "Bluetooth Radios: Broadcom...
Sep 24, 2010 | Belkin (F5U237) 7-Port USB Hub
I have an Belkin (F5U237) 7-Port USB Hub that is not compatable with windows vista. Is there a fix for this?
if Win7-64 is installing this hub as a "Broadcom Bluetooth Device" or some such nonsense, heres a fix that has FINALLY worked for me...
START > CONTROL PANEL > HARDWARE AND SOUND > Device Manager.
Plug in your hub, and when it pops up under bluetooth radios with an error, right click, then select properties.
Under properties, select the DRIVER tab, then select UPDATE DRIVER.
It should prompt you to choose between "Search Automatically..." or "Browse my computer..."
Choose "Browse my computer for driver software."
It should bring up a location box to search, but there should be an option below the box that says "Let me pick from a list of device drivers on my computer."
Select this option.
This will bring up a list of drivers available.
UNCHECK the "Show compatible hardware" box!!!!!!!
Then browse until you see (Generic USB Hub). Select the first driver on this list and it will work.
The windows generic driver file that works with my hub is in:
C:\Windows\system32\drivers\usbhub.sys
If the above solution doesn't work, you can try to navigate to this specific driver file during a manual installation. Good luck.
Mar 15, 2010 | Belkin (F5U237) 7-Port USB Hub
WD My Book 1TB not recognised by belkin modem router USB storage
I have a work around for this.
In the detail of the Belkin manuals it says you can attach up to 4 USB storage devices via a USB HUB.
I had an old Hub so I Connected the HUB to the router and the Maxtor to the HUB --- It worked :-) It came up in a few seconds.
At first I powered the HUB but later took the power out of the hub and it still worked ;-} However when I used a different HUB it would not work without power to the HUB.
The HUB I use is an old Belkin 4 port Tetra Hub. The newer 7 port Belkin HUB (5 Rear 2 Top) only worked with the HUB powered.
Hope this helps untill Belkin Upgrade the Router sofrtare.
Apr 07, 2009 | Computers & Internet
Bought HP S20 New in box on Ebay......installed software......powered up and linked USB......message "communication with scanner lost" cannot rectify
I use an older USB Powered Hub between my computer and the S20 scanner, a Belkin I found at a garage sale for $2 works fine. It is only rated for USB 1.1. The S20 is a USB 1.1 device. My computer was "too fast" with its USB 2.0 ports and it looks like I needed to "slow it down". There is no way it will worked plugged directly into the computer, but plugged into the hub, and then the hub plugged into the computer, it is very reliable.
Windows XP had nothing to do with it, from what I can see. I had Windows XP on a previous computer with only USB 1.1, and ran into the problem when I got a computer with USB 2.0 ports.
Jan 03, 2009 | HP Photosmart s20 Film Scanner
External Harddrive Ignorance...
I've seen this happen with hubs being connected to external hard drives before.
Do you have a free usb port on the back of your computer you can plug it into?
That should fix the problem.
Jun 11, 2008 | Belkin (F5U233-APL) 4-Port USB Hub
Not sure
Every plug and play devices are compatible with Vista.Vista have a huge range of drivers under its hood.So there is no doubt on that belkin usb 2.0 lighted travel hub is compatable with windows vista
Oct 21, 2007 | Belkin (B5U034) 4-Port USB Hub
Belkin 4-Port USB Hub Logo
623 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
