Question about LG Washing Machines
LG WM0532HW washer: what is the proper position of the sensor
I have an LG WM0532HW wash machine and it has a Bracket assembly (4811ER3001A) that holds some sort of sensor (6501FA2462C), There is a flat end to this assembly that is plastic. I turned the machine on the side to replace the belows part, then I noticed the sensor sitting there kind of weird, looking like a robotic arm but just hanging there. So my question is: what is the proper position of the flat end surface? There is a similar protruding flat piece molded on the drum assembly that seems to match this. It is stationary and the only apparent reason is for it to transfer vibrations to the sensor. But where the sensor's end piece is (to the right as you look from the opening on the back), I do not think there is any chance doing that. On the other hand if it is supposed to be on the left it would really look awkward as design goes. I have a picture here: www.commercialtech.com/lgsensor.JPG
Is that the proper position of the arm assembly or should it be to the left of the protruding piece from the drum assembly?
  • LG Master
  • 2,355 Answers
It is an off balance sensor so that if the tub wobbles excessively it shuts the unit down. It rests to the right.
Posted on Mar 08, 2017
jsrock516
  • 5911 Answers
SOURCE: Door Latch has broken plastic tab
The door latch assembly comes as one piece. It would actually be much simpler to purchase the new latch and replace the whole assembly instead of trying to put pieces and parts back inside a latch that may or may not work after all your hard effort. If you decide to replace the latch, follow these steps: 1. Unplug the machine. 2. Remove the lower kick plate panel if you like (this can help you reach the latch from a couple of different angles). 3. Open door and feel around the rubber door boot for a wire hoop. At the bottom of the door open is a tension spring. Pull the spring apart and remove the wire hoop from the groove. 4. Gently lift the rubber boot from the groove around the door opening and push inside the machine so you can access the inside of the casing. 5. The door latch assembly is located inside the case on the right-hand side. There should be a couple of wire connectors going to it (remember how they come off). Be careful with the wires, they are small and can break. 6. Unplug the wire connectors and remove the three screws holding the latch in place from the outside of the casing. 7. There should also be a plastic retainer holding the latch in place. Remove latch from retainer. 8. Install new door latch by placing it in the plastic retainer, first. 9. Plug wires connectors in. 10. Re-install the three door latch screws. 11. Re-install rubber door boot around the door opening. Make sure it is properly seated in the groove. 12. Reinsert wire hoop. starting at the top of the door opening, carefully push the wire hoop into the groove and work your way all the way around the bottom where the tension spring would be. (A second set of hands to hold the wire hoop in replace would be handy at this point). 13. Pull tension spring apart and snap into groove. Done. Hopefully this will take care of your problems. Of course, you may not like the idea of having to purchase a whole new door latch assembly, or the effort required to remove and replace. But, it sure beats trying to rebuild the old one. I hope this helps.
Posted on Jun 11, 2007
  • 62 Answers
SOURCE: LG WFT1391TP Top Load Washer - Black Clay Pieces in Drum
Lint build up. good hot water wash with bleach should do the trick
Posted on Jan 03, 2008
  • 57 Answers
SOURCE: removing motor to replace belt for agitator
first unplug washer then there are 4 half inch bolts on the motor holding it to the frame take those out unplug the motor harness. then twist it out you may have to take the hoses off. then there are 3 torxs screws in the pump take them out and put new belt on same way you took off and then reverse the steps and you will be ok
Posted on Feb 16, 2008
  • 184 Answers
SOURCE: Kenmore 22932 Top load washer has excessive vibration at end of spin cycle
IF THE FLOOR IS NOT ABSOLUTELY STABLE, IT WILL MAGNIFY A SMALL VIBRATION INTO A LARGE ONE. PUT SOMETHING ON THE DRYER IF IT SETS NEXT TO THE WASHER, AND TURN ON THE WASHER INTO SPIN. IF THE ITEM ON THE DRYER SHAKES, THE FLOOR IS MOVING.
IF THE WASHER IS ON CARPET, REMOVE THE CARPET OR CUT HOLES IN IT WHERE THE FEET ARE SO IT IS NOT SETTING ON THE CARPET. THE CARPET AND PAD WILL BE TOO SOFT FOR THE WASHER TO SET STABLE.
ALSO, PICK UP ON THE REAR OF THE WASHER TO RESET THE AUTO LEVELING REAR LEGS. YOU SHOULD HEAR THEM MOVE AND RESET WHEN YOU SET THE WASHER BACK DOWN.
Posted on Apr 10, 2008
Caustic soda. Be careful to wear gloves. Fill tub with water, cold will do, put in about 100gms of soda and turn on a extra large wash cycle only. Don't let the water drain, allow to stand over night, then complete wash cycle. You will find that hugh amounths of lint come loose. Repeat if necessary. I now do this about once every two months. Another thing to remember is to always leave lid open when machine is not in use, this prevents musty smells.
I have become obbsessive in sorting out the problems discussed and am now looking for a service manual for a WF-T7014PP as i want to remove the pulsators to ensure ther is no lint stuck in there. If anyone can assist please mail to lesleyfouche@vodamail.co.za
Posted on Jun 25, 2008
LG wm0532hw starts it's wash cycle then stops with the code LE flashing. Tried to reset the washer already and it did it again after reset. Tried no laundry in the cycle to see if it was to heavy and same...
check out youtube.com, repairclinic.com or appliancepartspros.com search for motor sensor replacement or hall sensor replacement. easy repair. $20 part. 30 minutes time. a know issue on earlier lg washers. lg has enhanced the part to make it more durable. make sure you get an lg part, not an oem equivalent part. part no. 6501KW2002A
Mar 18, 2015 | LG Washing Machines
Error le lg washer wm0532hw
Most likely motor position sensor (also known as hall sensor). Under $20 part. Easy fix. Check out videos on repairclinic.com or appliancepartspros.com.
http://www.ebay.com/itm/LG-Electronics-Washing-Machine-Rotor-Position-Sensor-Assembly-6501KW2002A-NEW-/252990897358?epid=710134311&hash=item3ae76ebcce:g:az0AAOSwnLdWsMSa
Jun 21, 2017 | LG WM-0532HW Front Load Washer
How can I make the water drain from my LG WM0532HW washer with an LE code. BTW- it's had the hall sensor and the main board replaced already.
You can turn the power on, and hit the spin speed button, and then start it. It should drain out.
If your still getting an LE error, and already have replaced the Hall sensor, it's most likely the Stator. If you know your date of purchase, this is most likely still under the 7 or 10 year warranty. Meaning LG pays for the part (over $100.00+),
Mar 07, 2011 | LG WM-0532HW Front Load Washer
Lg tromm front loader washer wm0532hw shows oe error
that's draining error. check the filter cleanout behind lower left panel on front of machine; of course drain 1st via small drain hose. if thats o.k the drain pump itself may be jammed with debris or the drain hose could be clogged.
Jun 24, 2010 | LG WM-2277HW Front Load Washer
I have a LG WASHER,FRONT LOADER WM0532HW KEEPS FLASHING LE,THE DRUM WILL NOT ROTATE
LE stands for locked motor error.  The first thing you should try is simply unplugging the machine for 10 minutes.  If the problem continues the next most likely cause is the hall sensor.  To get to the hall sensor remove the back cover, then remove the wheel that is attched to the drum.  Undre that wheel if the stator (motor).  At the bottom there is a sensor that spans about three of the windings.  This is the hall sensor.  It is not very expensive.  If neither of those work you will need to replace the Stator (motor)
Oct 22, 2009 | LG WM-2277HW Front Load Washer
Wm0532hw error code LE comes up but only when loaded with clothes...when it is empty it runs fine through out the cycle.
HI. this is a major warning that is signaling an issue with the drive motor. it may be burning out or, the hall sensor could be faulty as well. check the following to address this issue further.
POSSIBLE CUASES
  • The connector (3-pin, male, white) in the motor harness is not connected to the connector (3-pin, female, white) of stator assembly
  • The electrical contact between the connectores, (3-pin, male, white) in the motor harness and 4-pin, female, white connector in the main PWB assembly is bad or unstable. Or the motor harness between the sator assembly and main PWB assembly is cut (open circuit).
  • The hall sensor is out of order/defective.
Jul 16, 2009 | LG WM-2277HW Front Load Washer
"le" on the LG WM0532hw front load washer errror
try unpluging for 45 seconds than hold in the selector knob for 10 sec. & plug back in
Feb 02, 2009 | LG WM-0532HW Front Load Washer
Lg wm0532hw front load washer
LG wm0532hw, can not turn on washer, it's not the plug, i try to reset it by unplug for 2min then plug it back. help
Dec 12, 2007 | LG WM-1832C Front Load Washer
Washing Machines Logo
420 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
