Question about Husqvarna 23 Hp 48" Deck Yard Tractor
Repair the electric clutch on a Husquvarna Mower
When I turn on the mower deck the amp gauge starts to discharge and the mower blades stop
There is an electric clutch that engages the mower deck and it (or something in the wiring to it ) is shorted out and you will need to repair/replace it.
Or something is moving when you turn on the mower deck and shorting out a wire. Look closely at any movement occurring near any wires and I think you'll find your problem is a cut/bare wire.
You can cut and then splice the wire back together or just wrap it with electrical tape if the bare spot is not too big. Try to re-route the wires away from the pinch/rub point
Sep 16, 2017 | Garden
White z-200 pto switch wont engage mower blades, sputters and shuts motor off.
Electric clutch is going bad and mower doesn't have enough power to run the clutch. Clutch is running tight new clutch is around 270.00 dollars
Apr 11, 2012 | Oregon Scientific Electric PTO Clutch for...
I have a 60" Lesco
If it were me I would check the PTO switch with it running and use a dvm or test light to see if switch is working or defective , you could just have a bad wire connector at the switch or at PTO clutch ....look for discoloration or spread terminals, good luck
Aug 01, 2011 | Garden
Need a husquvarna user manual model 125L
the model number 125L is for a trimmer according to husquvarna and here is the link for that manual, http://www.husqvarna.com/us/homeowner/support/download-manuals/?query=125L&types=O
if you have a riding mower that link can help you locate a manual as well but you may need other numbers located on your mower. If Ii can help you please contact me.
Thank you.
Jun 26, 2011 | Husqvarna Garden
My Husquvarna Model 61 coils are not working I need a new coil where will i get an old chainsaw for spare parts for my machine now? I am in Sydney, Australia
check and search on E Bay mate, search for "Chainsawa' and "husquvarna", you should be able to pick up something cheap, also the coil from other Husquvarna models may fit, example, a 36 model coil, may fit a 61. A new coil is available from any mower and chainsaw shop, cost about $80.
May 31, 2010 | Husqvarna Chain Saw 20" Bar
Briggs & Stratton wiring, can it handle an electric clutch?
You might have a capacitor in line with the clutch motor that requires feed from the engine to allow the clutch to engage. I think the red lead is charging current to the battery plus post. Get yourself a 270962 repair manual and it will show you how to wire these things.
Apr 13, 2010 | Garden
How do you replace the clutch coils on an electric PTO husquvarna riding mower
I am going to presume that this clutch actually installs on the lower end of the engine crankshaft. There should be a bolt that goes up thru the center of the clutch into the shaft. There's probably a spring or rod that will hold the outside of the clutch solid. Part of the clutch will be turning with the engine when it's running and when you throw the switch to engage the clutch, the other portion is activated by the current to connect to the turning portion.
To get the old one off, you'll need to get under the mower with a socket wrench. These can be quite stubborn to break loose, as the engine will want to turn over as you turn the bolt. If you have a gear drive machine you may be able to let the transmission help hold the engine from turning, but that, too, is run by a belt, so it may slip. Worse case is to use an air impact wrench, which will apply pressure so fast that it will make the bolt turn without turning the engine. Good Luck.
Feb 16, 2010 | Oregon Scientific Electric PTO Clutch for...
I need an exploded diagram of a husquvarna clutch, where can i find one?
A Google search for "diagram husquvarna clutch" got this response among others:
http://www.partstree.com/parts/?lc=husqvarna&mn=HUV+4210+G+(2005-06)&dn=85550129
Aug 06, 2009 | 2002 Husqvarna CR 125
Husqvarna 23 Hp 48" Deck Yard Tractor Logo
952 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
