Question about Kenmore 15632 Built-in Dishwasher
Dishwaser not draining
We have a model 665 ultrawash that will not drain. WE tried doing the reset but it did not help. We took out all the water and visually checked but all looks OK.
  • Kenmore Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your problem...
Dishwasherdishwaser not draining - 2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on May 30, 2010
Water is pooling in my kenmore ultrawash and it won't turn on either. I need to know if there's anything I can do to drain the water because I think it's refusing to turn on on account of that water p
First unclog your sink drains and the drain hose from the dishwasher. Once you are certain they are clear... Then you can do a couple things to remove the water. dip it out, or siphon it out.... or perhaps use an electric pump.
Dec 01, 2014 | Kenmore 24 in. Elite UltraWash Built-In...
No reaction when start button is pushed on Kenmore UltraWash model 665 dishwasher. The clear /drain button works. No water filling
you have a bad water valve or bad user interface that's the long control in the front of the dish washer.
Dec 17, 2010 | Kenmore Dishwashers
My dishwasher is making a grinding sound when draining and i believe there could be something caught in the impeller, which is also stopping the water from draining completely. I took apart the pieces and...
Its sounds like you are trying to take out the drain pump to clear the impeller of broken glass ect... Make sure your taking out he right one, because the drain motor is the small on one, the bigger pump is the circulation motor and if you disconnect that tube you will end up buying a new sump/pump assemble. The drain motor should have a clip that you push down and while turning the pump clockwise to take off. Once off you will be able to clean it out. Please look at my quick tip also for some common drain problem issues
http://www.fixya.com/support/r7229617-quickest_way_fix_drain_issue_dishwasher
I wish you the very best! Please rate me "4 thumbs" if I helped you, thanks!
Dec 15, 2010 | Kenmore Dishwashers
Broken dishwasher?
The dishwaser has a Anti-Flood device (a polystireene block) on the floor of the dishwaser that activates a micro switch if any small amount of water is on the floor of the washer for any reason. This switch automatically puts the washer on PUMP OUT mode and does flash the error mode and does not work. Find out what causes the water on the floor and that will be the reason for not working...
Jan 17, 2010 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
I need the reset button sequence for a Kenmore Ultrawash automatic dishwasher Model # it is 665-15772990. My daughter was playing with all the lights and the only thing it will do now is drain.
I had the same problem and this fixed it:
- To clear the flashing light you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Jun 14, 2009 | Kenmore 24 in. 17032 Built-in Dishwasher
Dishwasher not filling with water
look in the dishwasher theres a little float plastic and round take your hand and pick iu and drop it if that float stuck up when dishwaser had water,,it will need a little help dropping back in slot...onthejob
Jan 18, 2009 | Frigidaire Dishwashers
Kenmore Ultrawash QuietGuard 3 Dishwasher not draining or rinsing
Not draining may either need new drain motor. or something is blocking the drain pipe.
Spots on dishes means you are using to much detergent or the wrong kind of detergent.
Your owners manuel should tell you what type to use.
Nov 18, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Hi Claire,
Are you using rinse aid?
that may help with the film.you may also have stuff down in the trap causing the water to drain slow.
Nov 05, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore Dishwasher 665.17979301 - Reset Sequence?
Try pushing the Sani-Rinse and Air Dry buttons back and forth a number of times.
Apr 20, 2007 | Kenmore 24 in. 15142 Built-in Dishwasher
Kenmore 15632 Built-in Dishwasher Logo
203 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
